samsung ln40b530p7fxza light up problem
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: samsung ln40b530p7fxza light up problem
    As long as you do all your work without the power connected, you're ok. I mean, you are going to take that inverter board out before you work on it right... It will be disconnected at this time.
    • Horty24
      • Oct 2011
      • 54
      OK so I got the inverter transformer and tried to install it. I believe I burned one of the connectors on the inverter board.
      So here is a rookie question. What is the best way to remove all the solder off without burning the main board contact? also is there a place where I can maybe jump a wire from the transformer pin to another location to get it to wire up?
      Ill post pics here soon.
      • Horty24
        • Oct 2011
        • 54
        ok here are the pics
        this is the one I replaced.
        after.
        Soldered side.
        This is the one I believe I burned the contact on invereter board.
        Maybe its just a bad solder job? I could not get all solder off.
        • Dgtech
          E. Technician
          • Apr 2009
          • 1462
          • Steeler
          It should be ok. Hook it up and try it. Lets see where we're at.
          • Horty24
            • Oct 2011
            • 54
            OK so I tried it and I get the same sypmtons. On for two seconds and off for 4 seconds and repeats the cycle. So I'm back to square one. I think my solder job stinks so Im going to take it to work and redo it.
            • Horty24
              • Oct 2011
              • 54
              #26
              OK So, I desoldered the transformer again and used a desolderin wick to get the holes nice and clean. re-inserted the transformer, and re-soldered it and whala....
              It worked. Thanks DGtech for commenting on my post.
              So sympton was the tv would turn on for 2 seconds and off for 4 seconds while the sounds stayed on.
              The find: burned inverted transformer.
              Fix: Replaced the transformer. Picture comes back on and does not turn off.
              Thanks Bad caps for this forum.
              • Tubafore
                • Sep 2012
                Originally posted by gmzombie
                just to update replacing both inverter transformers fixed the tv. it now turns on and i can see it again.. thanks for your help.
                Hey Zombie or Horty,
                Sorry for reviving a year old thread, but I had the same issue, same TV as you. The board has been pulled to replace the offending transformer.
                Just a practical question now... do you remember how you reattached the back light leads into the underside of the board when you reinstalled? Those filaments coming from the back lights are awfully delicate.
                Just resetting the board in its old position doesn't reconnect the lights, since they need to be clipped in.
                Thanks for any assistance!
                Best, Tubafore
                • Tubafore
                  • Sep 2012
                  Hey Zombie or Hortie,
                  Best, Tubafore
                  • Alup
                    • Dec 2011
                    • 14
                    #29
                    sorry to dig, I had a tv come in with a similar issue. I tested the diodes and i replaced the transformers and it still acts like its just not sending the power on signal. any ideas?
                    Nevermind, I retested my transformers and 1 of the new ones that i put in was bad.
                    • Alyssa
                      • Mar 2013
                      • philippines
                      #30
                      hi! can anyone help me to send me an invitation at elektrotanya.com? Thank you. here is my email address annlim@ymail.com
                      • Tvsamsung
                        • Mar 2013
                        I do have the same issue (ie tv goes off after 5 sec) on the same tv LN40B530P7NxZA but I could not find anything burned on the board. I am clearly not an expert but everything seems to be fine. I should add tha the tv does not go on anf off but off after a few seconds !
                        Any idea ?
                        • tibimakai
                          • Jan 2012
                          • 3680
                          Old thread I know, but I have the same problem.
                          I would like to ask about the blue transformer.
                          The blue transformer should show the same thing as the white ones?
                          Only two of the pins are going toward the CCFLs and the resistance it's a bit higher then the other transformers.(1161, 1171, 1168, 1165 and the blue is 1201)
                          One of the transformers was reading 1062 only and another had one winding open. These two I will replace, but I'm not sure about the blue one.
                          All three transformers have two output windings and the blue one only one.
                          • sputnikoff
                            • Feb 2016
                            • 203
                            • canada
                            #33
                            I also have burned transformer will replacing it only cause new one to fail?Do i have to replace ccfl units.Where are lamps available from?
                              http://www.ccflwarehouse.com/
                              If the lamps are worn out, they draw too much current and cause transformers to burn out.
                              Worn out lamp will have blackened ends, or pink glow when is on.
                              http://s807.photobucket.com/user/bud...?sort=3&page=1
                              • sputnikoff
                                • Feb 2016
                                • 203
                                • canada
                                #35
                                Thanks great forum,great help.
                                • sputnikoff
                                  • Feb 2016
                                  • 203
                                  • canada
                                  #36
                                  Is transformer failing due to tubes or just being driven too hard by back light settings?I have same issue top transformer gone(qgah02095).I guess just replace transformer and see what happens.I checked caps and diodes and removed display screens and inspected all 14 tubes all look good.
                                  • claudem
                                    • Aug 2008
                                    #37
                                    Hi,is it possible to remove the bad transformer for test purpose and putt back the board?
                                    at least i will know if something else is deffective?
                                    • wyrmzr72
                                      • Oct 2019
                                      • 8
                                      As much as I hate to dig up an old thread, I'm new here, so I believe I'm limited to posting on old threads for now...
                                      I'm looking at this same TV; won't power on, red standby light blinks once when you hit the power button. I unplugged the cable from the power board to the main board to test voltages, and the back lights came on. The voltages at the power board seem to be correct, but I do believe I've got 2 leaking caps, in this case leaking out the bottom and not bulged at the top.
                                      I did plug the main board back into the power board, even did so with all other cables disconnected (T-Con, audio, power switch). No back lights that way, of course, and plugging the power switch in just lets me know the system is remaining in standby.
                                      So I'm wondering whether the main board is overloading the power board, or whether the power board just isn't putting out enough amperage to run the main board?
                                      • tvtimmy
                                        • Mar 2015
                                        • 1160
                                        • usa
                                        #39
                                        Post pictures of the boards.
                                        • nomoresonys
                                          • 12086
                                          • U.S.
                                          #40
                                          Replace the 2 caps for starters, it may be your only problem.
                                            09-07-2024, 05:50 AM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • Kaar3l
                                            Samsung QLED QE65Q7FNAT only standby light
                                            by Kaar3l
                                            TV: Samsung QLED QE65Q7FNAT
                                            PSU: BN4400940A
                                            MB: BN94-12832K
                                            I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                            09-24-2024, 01:35 PM
                                          • DXseekerMO
                                            Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
                                            by DXseekerMO
                                            Hello everyone!
                                            Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
                                            Symptoms:
                                            1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
                                            2) TV does not appear to turn on
                                            3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
                                            4) "Power on" terminal on Power Supply has 3.26v
                                            5) "A13V" terminals have 12.9v
                                            6) Stand-by test jumper on Power Supply has 12.9V
                                            7) Optical audio jack on Main Board illuminates
                                            8) With stand-by...
                                            06-09-2021, 12:19 AM
                                          • ChristianBr01
                                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                            by ChristianBr01
                                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                            04-23-2025, 01:48 AM
