Toshiba lcd error codes
  • billansor
    • 85
    Hi
    Do we have a section in this forum that is for error codes on the various manufacturers??
    I have a three blink code on a Toshiba 32HL66 set..
    It would be nice to have the error codes for Toshiba if available..
    Thank you for your time
    Bill
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Toshiba lcd error codes
    Most service manuals can be found for free at
    http://elektrotanya.com/
    --- begin sig file ---
    --- end sig file ---
    • michalk3777@gmail.com
      Sharp Hisense - LC-65N7004U Error codes
      by michalk3777@gmail.com
      Hello, looking for a list of error codes for this TV. made in 2020, its manufactured by Hisense under Sharp brand. No clicks, black screen, no sound, power light is on solid. When I press power, it blinks 5 normal blinks and 1 short. and nothing happens.
      Anybody has a list of error codes that might apply to this TV? I have not opened it yet.
      Regards,...
      12-15-2024, 09:20 PM
    • jean luc ferre
      upgrading windows7 to windows10 on an old laptop toshiba satellite m40 331 allways in error
      by jean luc ferre
      on this old laptop toshiba satellite m40 331 i am trying (but failing) to upgrade frow w7 to w10 and allways i have the error : 0xc1900101 - 0c20017. The upgrading process stops with the pc blocked with the logo screen w10 on the display; then there is no activity on the disk hdd or ssd.
      it's also impossible to boot from a dvd iso bootable, the device equally blocks on the w10 logo screen...
      i verified the informations in the device manager and it seems there are no problems...
      i wonder if it's not an issue about the bios (which is very old) or an interface problem...
      05-27-2025, 07:13 AM
    • Sus256
      HISENSE 65E7KQ PRO - no boot
      by Sus256
      Hi all!
      HISENSE 65E7KQ PRO
      RSAG7.820.13512 - chassis
      MT9618BAATAB - cpu
      RSAG7.820.12059 - power
      HD650Y3U77 - panel
      KLM8G1GETF - emmc
      Replaced emmc.
      Terminal log
      UART
      AC_ON
      E-B
      FDE enabled
      06-01-2025, 02:11 AM
    • sushilachuthan
      APC UPS error P13
      by sushilachuthan
      one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
      the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
      The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
      We replaced the SCR with new device,, but the device is not power on as expected.
      Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
      09-26-2025, 09:00 AM
    • mecha1166
      QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
      by mecha1166
      I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
      03-28-2024, 08:31 AM
