LG 50PC3D Plasma -bad caps or is there more to this?
  • nanosec
    • May 2011
    • 7
    I'm counting 7 bulging capacitors on the power supply board, and none on the other boards.
    Just wondering if this is the z-sus board or the other boards?
    What would your best guess be based on these pictures?
    If I replace the bad caps do you think this problem will go away?
    I am by no means an expert, but I am a quick study on things, here's hoping I can fix this.
    Thank you in advance for your time, believe me, I appreciate it!
  • PlainBill
    • Feb 2009
    • 7034
    Re: LG 50PC3D Plasma -bad caps or is there more to this?
    Don't post pictures inline, it slows loading pages and inconveniences the experts like retiredcaps, as well as annoying others - like me. Use 'Manage Attachments' (under the text entry area).
    That doesn't look like a Z-sustain problem, but I could be wrong. The first step would be to replace the bulging caps. If you live in the USA 7 caps from Digikey will probably cost you about $10, including shipping.
    PlainBill
    • Village Electronics
      OldPro
      • 118
      Obviously you replace caps that appear to be bad. I would suspect the buffer(s) to be the problem with this symptom.
      • nanosec
        • May 2011
        • 7
        Sorry guys, I don't see a way to edit my post, otherwise I would change it immediately. (is there a timer on the edit button?)
        Thanks, I will replace the caps and see how it goes, and please advise if you want me to upload the images as attachments as per your requests either later in this thread or however you want.
        • nanosec
          • May 2011
          • 7
          Just finished replacing capacitors. Powers up fine, but problem still exists.
            OldPro
            • 118
            buffer(s)
            • nanosec
              • May 2011
              • 7
              Thanks guys, appreciate your help and please forgive my image faux pas
              Any recommended source for rebuild or replacement boards?
              • retiredcaps
                • Apr 2010
                • 9271
                I have no personal dealings with CoppellTV (or financial gain), but I have been following their blog and they seem like a reputable company. One member reported good dealings with them.
                Their latest post makes you think about repair or replace.
                http://blog.coppelltvrepair.com/
                They also have ebay auctions to repair/replace parts.
                --- begin sig file ---
                --- end sig file ---
                  OldPro
                  • 118
                  I may have that board. Could you post a picture of the buffer? It may be one long board or 2 shorter boards. In an LG they will be on the far left when facing the open rear of the TV.
                  Get the numbers on the white label. That will be the part number.
                  The fault in buffers is usually the flat pack IC's. Very difficult to change individually with highly specialized equipment. The parts numbers are easy to search out.
                  • nanosec
                    • May 2011
                    • 7
                    Sorry for the delay, here's pics of the part numbers for the buffer boards
                    • djjuanito2
                      • 3
                      Did you guy's found the fix for this problem with the picture?
                      Thanks!!
                      • rmoody
                        Learning Member
                        • Jul 2011
                        • 262
                        I sent a Ysus to them today to be rebuilt. I hope they do well.
                        • djjuanito2
                          • 3
                          I replaced the y-sus ,z-sus and still showing the same picture ,I think maybe is the power supply.
                          I hope somebody can find the fix , If I fixed first I will posted.
                          Thanks!!
                          • rayrod81
                            • Oct 2010
                            • 205
                            It is a buffer problem not y-sus or z-sus. Replace buffers and it should work fine.
                            • djjuanito2
                              • 3
                              Thanks my friend ,
                              I found the problem it was the 6871QDH089A ON THE 50PC3D -LG /SHORTED FET
                              This damage on the power supply the FET SD20N60 Q852 I believe is the location and the Y-sus and z-sus board was bad too.
                              • rayrod81
                                • Oct 2010
                                • 205
                                Yeah the FETs shorting on the buffer are a common problem with this panel.
                                • cadillacman
                                  • Feb 2011
                                  • 524
                                  i had the same issue with a 42 inch lg... one of four shorted, went ahead and replaced them all...
                                    by momaka
                                    03-12-2025, 03:42 PM
                                  • eryjus
                                    by eryjus
                                    05-10-2023, 11:21 AM
                                  • Paxman_Swede
                                    by Paxman_Swede
                                    Hello!
                                    01-14-2025, 09:51 AM
                                  • captain150
                                    by captain150
                                    03-16-2025, 07:34 PM
                                  • Foetuss
                                    Gigabyte GA-6OXT :: caps question
                                    by Foetuss
                                    Good evening
                                    I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                    Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                    But I was also suprised about the bigger boys, which are 330µF 25V.
                                    Could it be they used 25V caps because they were cheaper / available at that time?...
                                    02-11-2025, 12:22 PM
