my new post is how can i find out if the problem is the main board or the av board as i now believe the psu is ok.
my question is if the psu was ok what would make these symtoms...
tv wont work from the sets own controls the on/off dont function need to switch off from the ac plug the wall outlet.
i posted the results on another post of the psu volts on the p connectors 201 etc.
when first pluged in i hear the relay click 3 times the set shows a picture with av2 in the right hand top corner then it changes to a blue screen with the no signal logo moving around the screen is there any thing i can do to see if it is the av board as another member said as iv tried my laptop on it no joy all the scarts on using the boys xbox same result.
when i tested my 18 volt relay i belive it tested ok as it done the same clicking sound as the 24 volt one i had lying about so i think its fine and as i said the power board is ok.
im new to the forums using them etc so if iv not done the right things sorry in advance.
