YSUS test on a Vizio P50HDM
  • firepac493
    Hello fellas
    New to the board so be kind.
    I have been doing tons of research online in trying to fix my parents Vizio P50HDM. My parent were watching TV and say that the screen went black...no pop. I took the rear panel off and found one of the 4amp fuses was bad on the YSUS board. Any recomendations on a repair or a supplier here in the Phoenix area. I can install myself if need be. I also checked the voltages on the power inverter board all checks well. VA+ pins have 190vdc +-...is this normal?
  • PlainBill
    • Feb 2009
    • 7034
    Re: YSUS test on a Vizio P50HDM
    The blown fuse indicates the problem is the Y-sustain. Rebuilt replacements are available for about $110-$120 with exchange. Research would indicate if replacing Y buffers is also recommended.
    The two YPPD modules would cost $70 if you want to do the repair yourself.
    PlainBill
    • Kb7aVdTcAa3p
      • Jul 2008
      I am experiencing similar problems with my Vizio P50HDM it just shows no picture.
      The 4amp Fuse for Vs+190V is blown too, but additionally a 250V 150ยต cap on the Y-Sus board is leaking elektrolyte.
      I already checked the voltages they seem OK: Va+ 60V Vs+190V.
      How can I test which parts failed?(I would like to avoid replacing the whole YSUS-board)
      Athlon 64 X2 4000+ @2400MHz 1.15V | 1200MHz 0.9V - 4GB DDR2 - Radeon HD 3200 - Windows 7
      • mockingbird
        • Dec 2008
        • 5484
        PlainBill
        Why would you need two YPPD? Do you also have to replace one on the Z sustain? Have you ever replaced a YPPD? What is the best way to remove it? I'm thinking wicking away the solder from each individual hole... Is there a better way?
        • PlainBill
          • Feb 2009
          • 7034
          The recommendation is to replace both of them. Probably because they interact and one shorting can damage the other.
          I have never replace a YPPD, but I have replaced the hybrid used on the LG 42PC3D-UD (and countless others using the same panel). Solder wick won't begin to do the job, Grasshopper. There are very heavy ground and power planes on the board.
          One method that worked for me: Heat the leads of the hybrid with a heavy duty soldering iron (60 watt recommended) and add Chip-Quik to each lead of the hybrid. Protect the area outside of and between the rows of pins with several layers of aluminum foil. Fasten the board to a piece of plywood with a hole slightly larger than the hybrid cut in it. Similarly protect the plywood with several layers of aluminum foil. Fasten the plywood to a sturdy bench - preferably outdoors. Rig a handle to grasp the hybrid by the heat sink. Carefully heat the bottom of the board with a heat gun on it's low setting, keeping the heat gun moving. When the solder on the upper surface starts to melt CAREFULLY lift the hybrid by it's heat sink. Using a heavy duty soldering iron, heat each hole and use a dissecting pick to force the solder out.
          On one attempt I tried skipping the Chip-Quik. I keep the board on hand to remind me that I'm not infallible.
          Other methods have been reported to work.
          1. Use a screw driver to break the ears on the hybrid that hold the screws holding it to the heat sink. Cut the pins on the hybrid. Using a heavy duty soldering iron, remove the pins one at a time, using a steel needle to clear the solder from each hole.
          2. Obtain two old fashioned tinner's soldering irons (these are square rods of copper roughly 3/4" x 3/4" x 3" attached to an iron shaft, which goes into a wooden handle). Hacksaw a groove lengthwise ~3/16" deep on one corner of each iron. Heat the irons and fill the groves with solder. While the irons are hot, use them to simultaneously heat each row of pins until the solder melts and the hybrid (or YPPD) can be removed. Again, use a steel needle to clear the solder from each hole.
          PlainBill
          • mockingbird
            • Dec 2008
            • 5484
            Bill, I've been reading Coppel TV Repair just to get a better idea of what I'm getting into. The model like I've stated before is an Akai PDP4273M 42". I actually managed to download the service manual a while back (So I can figure out how to open it. It's got tons of screws).
            He's agreeing with what your saying. His latest entry, from this month, is somewhat dumbed down and understandable for people like me:
            Which is to explain and underscore that functionality of one sustain is not affected by the other.
            Still, it is affected by something completely different, which suggests
            It may still be better to service or replace both sustain boards at the same time.
            Isn't a YPPD and a Hybrid the same thing? I'll try the acid flux to aid the wick's flux. I've done this before with a copper coil, but I was pulling the coil off very hard while I was melting.
            Thanks for your help. I will no doubt end up using one of your methods. I'm gonna see if my local electronics shop has any chip quick.
            One more thing... You recommend replacing the YSUS Buffer.... Do you think the caps go south on these or is it something else that is difficult to diagnose?
            • PlainBill
              • Feb 2009
              • 7034
              You are correct, the YPPD is a hybrid. There are a number of them used on various LG and Samsung (and possibly others) Y and Z Sustain modules. The are sometimes refered to as IPMs. I've never dealt with a 50" LG plasma.
              The technique used to remove them will work on any EXCEPT the Samsung. Those boards are designed so the heat sink can be easily removed, so the 'cut the pins and extract' method works well. If I were removing them regularly I would rig up a 'branding iron' using a pair of notched copper bars, a support jig, a blowtorch, and a thermocouple. With a little experimentation it should be possible to heat the tool to the proper temperature, then pull the module in a fraction of a minute.
              PlainBill
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • chth96
                How Can I test PWM DM0365R?
                by chth96
                Hello
                I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                06-18-2025, 04:14 PM
              • SS454
                vizio e650i-a2 backlight flashes then turns off
                by SS454
                vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                panel: au optronics T650HVN05.4
                72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                https://www.shopjimmy.com/vizio-56-0...-power-supply/
                Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                08-20-2020, 03:57 PM
              • PlasMatt
                LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                by PlasMatt
                I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                09-20-2025, 06:50 PM
              • khelane
                test active pfc power with lamp test
                by khelane
                Hello
                I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                Is there a way...
                06-03-2025, 01:00 AM
