technika lcd 32-209 screen blanking
  • wessy67
    • 9
    hi there i am new to this site i have a problem with my lcd tv the picture is perfect after switching on then after 1 min 55 seconds the screen freezes and then the screen fades to blank still got sound so switch it off and on again and it does exactally the same and the same time could this be down to a faulty capacitor any advice would be greatly recieved
  • seanc
    • Nov 2008
    • 1319
    Re: technika lcd 32-209 screen blanking
    Can you take the back off and take some pictures?
    They can be a maximum of 2000x2000px and please attach them to the forum using the manage attachments function.
    • wessy67
      • 9
      here are some pics with the bach off seanc
      • Dgtech
        E. Technician
        • Apr 2009
        • 1462
        • Steeler
        After closely reading the description of the problem, it sounds more like an overheating processor than capacitor problem. However, It only costs about $5.00 to change the caps out just to rule them out.
        • wessy67
          • 9
          thanks dgtech would finding this possible prossesor be a big job
          • Dgtech
            E. Technician
            • Apr 2009
            • 1462
            • Steeler
            Change out the caps first with low ESR caps. Ruling this out is critical to taking the next steps. Replacing the processor means replacing the board so... do the easiest, cheepest step first - capicitors. Of course, you can always check the connectors for a good connection.
            • japlytic
              • Oct 2005
              • 2086
              I see what appears to be Samxon GF Series in the power supply board, which are a known bad unit. What are the other brands and series (e.g. CapXon KF) of electrolytic capacitors on the main logic board?
              Also, replace the two black and one brown electrolytic capacitors in the bottom right corner of the main logic board.
              Finally, check the SMD electrolytics if they are not bulging.
              I think the heatsinking of the main system controller in the centre of the main logic board is inadequate.
              • wessy67
                • 9
                sorry for the delay japlytic here is a little drawing of capacitors
                • wessy67
                  • 9
                  can anyone say which other caps on the above drawing are know bad caps please
                    master hoarder
                    • May 2008
                    • 12170
                    • Bulgaria
                    All are, except for the EPCOS. EPCOS makes good capacitors. However, I see that one of them is rated for 85C only. Therefore, it would be a good idea to replace it, as well as all of the other 85C rated caps.
                    Samxon also makes good caps, but their GF series are known to be problematic.
                    The only cap you don't need to replace is the 150uF 450V Samxon.
                    • wessy67
                      • 9
                      thanks momaka will do
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
                      • smic717394
                        by smic717394
                        07-25-2024, 10:16 AM
                      • Chrissygizmo
                        by Chrissygizmo
                        02-10-2025, 12:33 AM
                      • spice_disc
                        Vizio TV M50-C1 reboot cycle and static on screen
                        by spice_disc
                        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                        09-08-2024, 02:37 PM
                      • ipatch
                        ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                        by ipatch
                        i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                        08-24-2024, 02:36 PM
