My Vizio P42HD When powered on, it has good picture and sound...but then over next five/ten minutes, the picture starts flickering, gets wierd colors then blank. Unplug power cable for few hours then plug power back. Turned TV on and same problem happend again. Is the Y sus board caused this problem. Sorry, I don't know much about TV.
Vizio P42HD screen flickers and frequently goes blank
Re: Vizio P42HD screen flickers and frequently goes blank
Can you confirm this model number? I have a P42HDTV10A which shows similar symptoms. Picture's whole and complete, but the image's washed out, and the backlight does show some flickering. I was originally going to post, asking if anyone has seen bad caps on this TV. There have been references to a bad Y-Sustain and a bad Z-Sustain board. Other people have gone as far as replacing the buffer boards, too.
Next week, I may be able to provide pictures of the image and the innards as well.
Thanks for reading!
Assuming...7 Photos -
by pdsternsGood Morning TV'ers
Vizio usually starts and works fine for a few minutes then goes blank. Checking voltages when shutdown it reads 5v on the standby pins on the PS and 12v on the 12v pina, backlights are out now. What can I conclude or where to next.
Thanks in advance
burns -
by mecha1166Hello, we have 4-6 of these sets now. All have blank screens, or slow-moving colors (looks like tie-die shirt). Some have narrow white lines and color around it.
We have tried a new main and several tcons (2 exact and 2 similar). Same thing. Probably a panel - has anyone had this issue? These are fairly new sets, all but one came from rental.I own one, it was junked out. I tried searching for this model in forums but the search showed no threads for this model number. Thanks for any input! -
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
by mrtekHi.
picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED... - Loading...
