I have a 40" Sony Bravia LCD KDL-40S4100. When I turn the TV on it works for a 2 second period and then shots of by it self,a red stanby light flashes twise,anyone here knows what could be a problem with it????? thanx
Sony LCD KDL40S4100 stanby flashes twise
Re: Sony LCD KDL40S4100 stanby flashes twise
What works exactly? Do you get picture with brightness or a blank black screen? Do you get sound? Do you get sound but no picture?
Please clearify.
This Sevice Manual can be found and downloaded for free here:
http://elektrotanya.com
It will tell you what the coding means - 2 blink error codeThe strong-minded rise to the challenge of their goals,the weak-minded BECOME HATERS
It could be the inverter transformers. See
http://www.youtube.com/watch?v=HMUazhb0bhc
If you don't have a ringer tester, there are other ways of testing the transformers.
It would also help if you post clear focused pictures of your TV using the manage attachments feature. Please do not post inline.--- begin sig file ---
--- end sig file ---Comment
Have you downloaded the service manual for this set yet? In post #2 I attatched a link where this can be found. Does your set look like the one on page 20 of this service manual?The strong-minded rise to the challenge of their goals,the weak-minded BECOME HATERS
by odie34I am a hobbyist (not a professional) so please be gentle...
I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,... -
by DangerouskHi there
Have Sony KD-49XE9005 that has been working fine for some time now. switched on this AM and after a few seconds screen blank and red LED flashing 4 times. Tried resets and all responding as expected expected and after booting up, after few seconds of displaying normal broadcast picture, screen goes blank red led flashes 4 times in sequence.
Anyone have schematics/service manual for this series. have checked the obvious items and caps test OK, voltages etc appear correct onwards.
thanks
D -
by GlavalHello, my Aunt recently gave me her broken Sony XBR-65A8G OLED after getting a replacement. It had a 4x led flash error, a replacement T-con didn't fix the error but with helpful info from this forum I found one of the smd ceramic caps on the panel pcb (C575/C378) on a 24v line was shorted to ground. I removed that cap and the tv turned on without error. It still had a black screen with the original t-con back in it, once I put the replacement t-con in it finally had a picture. After doing a panel refresh it had a very good picture but with a few vertical lines for some scenes. For owners with...3 Photos
by thstuffA) TV initially dead
B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
C) Was able to perform a Reset from Settings menu and completed out of box configuration.
D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical... -
by Carlos#2003%Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
- Loading...
