The Notorious Sony "Light Engine"
  • stevekasian
    Old N00b
    • 182
    • USA - West Side!
    Does anybody have any technical information on the notorious "Light Engine" problems that plagued the Sony Grand WEGA 50"+ HDTVs?
    I am looking at acquiring one that is in need of a Light Engine replacement. If it is possible to rebuild/repair the thing myself (as, even used, Light Engines are selling for $400+... WAY too much to spend on this TV), I'd like to know.
    The model number is KDS-R50XBR1.
    Any info would be appreciated!
    Thanks,
    Steve
  • PlainBill
    • Feb 2009
    • 7034
    Re: The Notorious Sony "Light Engine"
    Wizard has posted some information on these. Perhaps a search would have found this thread.
    PlainBill
    • Wizard
      • Mar 2008
      • 2296
      Problem is in LCD panels themselves and not replaceable. The Sony no longer carries optical engines anymore. The last one I had was 2 years ago plus, and Sony told us no more left to replace. When I say, I mean WHOLE thing minus the lamp pulled out and some boards. It was over 1,000 dollars wholesale.
      Cheers, Wizard
      • stevekasian
        Old N00b
        • 182
        • USA - West Side!
        Thanks for the tip PlainBill. I did, however, do a search for "sony light engine" and came up with only one search result that didn't match my query. Believe me when i tell you that I don't take posting in forums lightly - search is essential for keeping a tidy place. The good news is that now when someone searches the same, this thread will come back, which will, in turn, guide them to the thread you suggested.
        Thanks Wizard, for all your information!
        SK
        • merkin
          • May 2010
          • 57
          http://repairs.sunnyoasis.com/sonylcdtv/
          'bout your only choice, unless you can refurb the LCD panels.
          TSM http://www.tristatemodule.com/ used to have refurbs, even gave you back the core charge when they receive your broken light engine.
          Lots of info here also http://www.agoraquest.com/
          • brithepi2k
            Sony KD-65XE8596 no standby light
            by brithepi2k
            I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
            cheers...
            09-06-2025, 02:22 PM
          • Ihandyrepair
            sony 55X850D black screen no front white or red led light.
            by Ihandyrepair
            Hi guys
            strange one
            I have a dead Sony 55X850D
            when plug in, black screen, no front white or red LED, no back light no screen
            Voltages I get
            3.3v LD/power and main board
            reg 12V
            reg 19V
            3.3v on power on pin
            no Tcon on
            no tcon 12v
            no BL_on
            I do get BL_ERR 2.0v
            I tried to bypass it by ground it but still get same symptom
            I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
            or is possible the chip next to...
            08-07-2024, 04:58 AM
          • YasaCh
            Sony kdl 40p5500 red light keeps blinking 3 times
            by YasaCh
            Hello...
            my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
            i opened the back cover no sign of damage on the powery suply or motherboard
            when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
            another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
            07-07-2025, 11:53 AM
            Lithonia Lighting versus Light of America Compact Fluorescent product quality
            by sam_sam_sam
            I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
            I also have back when Light of America had these light bulbs available for yard lights
            The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
            While the Lithonia lighting fixture has all most certain bulb failure
            So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
            I have only had this light fixture for not more than a year if it...
            07-02-2023, 03:45 PM
          • Carlos#2003%
            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
            by Carlos#2003%
            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
            02-15-2024, 07:52 PM
