Vizio VW42LFHDTV10...Brother Mikes TV...
  • rmoody
    Learning Member
    • Jul 2011
    • 262
    #121
    Re: Vizio VW42LFHDTV10...Brother Mikes TV...
    why did you replace the fuse in the first place? was it bad?
    • stefnopolis
      • Aug 2011
      • 14
      #122
      I have no equipment to check wheather the fuse was the culprit or not so I decided to give it a shot.
      • Dgtech
        E. Technician
        • Apr 2009
        • 1462
        • Steeler
        #123
        What has been done so far with your set has all been done without using a meter to check a fuse? You've replaced the main board with no success. The wasted money and wasted time could have been avoided if you would have posted pictures of what you had in the first place. We could have told you where to find the proper fuse and then we would go on from there. Now you are backtracking saying that the fuse wasn't really secure?
        Post pictures of the whole set and then post pics of the individual boards, including the master and slave inverter boards (if any, would be on the right and left side under a cover).
        • rmoody
          Learning Member
          • Jul 2011
          • 262
          #124
          Then go to wal-mart to the automotive section and buy you a digital multimeter for like 15 bucks. You will need this many many times and it's a decent DMM for the price.
          • stefnopolis
            • Aug 2011
            • 14
            #125
            I have not changed the mainboard yet DGtech. Still waiting for its arrival. The only difference in the fuse I replaced was the pigtail part (mounting). Yes I will have to get a meter. I want to check the caps and regulators. Hopefully my situation is the same as King's and I can follow his steps. This way I can return the main board I orderd.
            • stefnopolis
              • Aug 2011
              • 14
              #126
              The mainboard I ordered finally arrived. The components and numbers all matched on both boards pefectly. The only exception being the middle numbers 0472 and 0502. Other than that... same exact board. So I switched the boards out and still same problem. I believe, that eliminates the mainboard as the culprit. I placed my tv in a pitch black room as suggested and turned it on. No light what so ever besides the Vizio logo. With the lights being off I am asuming that it is not the TCON and leaning 100% toward the inverters as the culprit. Will check them out tomorrow and post findings. If so, is there a way to repair the inverters? Or , would I have to have them replaced?
              • Dgtech
                E. Technician
                • Apr 2009
                • 1462
                • Steeler
                #127
                It would be nice to be able to SEE these inverters to know what type and what you should check next. Flying blind sucks.
                • stefnopolis
                  • Aug 2011
                  • 14
                  #128
                  Found the culprit!! After careful inspection found one of the pins fried on the Master inverter. I believe it is MU1. It has 16 pins on both sides. Now, where to get the part... anyone?
                  • rmoody
                    Learning Member
                    • Jul 2011
                    • 262
                    #129
                    yep, If there is no backlight, you needed to check the 24v line coming from the power supply and if you have 24v there, you can pretty much bet its in the inverter.
                    • stefnopolis
                      • Aug 2011
                      • 14
                      #130
                      100% sure its the master inverter.. anyone know where to get the MU1 integrated circuit?
                      • stefnopolis
                        • Aug 2011
                        • 14
                        #131
                        Never mind. Just picked up the part.
                        • PlainBill
                          • Feb 2009
                          • 7034
                          Are you also getting the transistors?
                          PlainBill
                          • stefnopolis
                            • Aug 2011
                            • 14
                            #133
                            Fortunately yes. Instead of looking for all of them individually I just purchased the already assembled kit from ebay. 15 bucks ... sure why not.
                            • Dgtech
                              E. Technician
                              • Apr 2009
                              • 1462
                              • Steeler
                              #134
                              I'm surprised you didnt just replace the board. I've replace this chip several times on different sets. It's a task that I wouldn't suggest taking on unless you're a pro at soldering.
                              What is the numbers on the inverter board you are fixing??
                              • stefnopolis
                                • Aug 2011
                                • 14
                                #135
                                Yes I know those pins are extremely small but if i succeed I will be feeling very good about the work ive done and $ I have saved. I bought this tv fried and sofar I have spent on a fuse, a restock fee, and the circuit/transistor kit. If I fail I wont be feeling bad about buying the master or having someone solder those pesky pins. Besides I have done plentyof smd's no problem... hopefully this will be a similar task.
                                • taydu
                                  • Jul 2011
                                  • 15
                                  #136
                                  Few days ago the tv gave up on me, i found this thread, read it couple times and check all
                                  U2, U4, U7, U8, U9, U33 and the voltage are fine. Now im kind of frustrate, could someone shed some light for me.
                                  Any suggestion would greatly appriciate
                                  • Dgtech
                                    E. Technician
                                    • Apr 2009
                                    • 1462
                                    • Steeler
                                    #137
                                    A description of the failure or pictures of the failure is always a great start.
                                    • taydu
                                      • Jul 2011
                                      • 15
                                      #138
                                      I was able to:
                                      - Turn on the TV
                                      - Vizio Logo turn from orange to White
                                      - Screen is Black (not even backlite or a flash, completely black from off to on)
                                      - Not able to turn OFF TV unless unplug
                                      From what I've read from this thread and other thread it, the problem is from the main board mostly U33. I used my multimeter to check and got the following number
                                      Chip Location / Vin / Vout / Adj,Gnd
                                      U2 / 5.19 / 3.30 / 2.0
                                      U4 / 5.19 / 3.30 / 2.0
                                      U7 / 3.30 / 1.28 / 0.0
                                      U8 / 5.19 / 3.30 / 2.0
                                      U9 / 3.30 / 1.52 / 0.0
                                      U33 / 5.19 / 3.30 / 2.0
                                      • Dgtech
                                        E. Technician
                                        • Apr 2009
                                        • 1462
                                        • Steeler
                                        #139
                                        Check the inverter boards as well. (Master and Slave)
                                        • taydu
                                          • Jul 2011
                                          • 15
                                          #140
                                          two caps on both inverter are bulge, will get it replace but it shouldn't effect the main board ( cannot turn off after it turned on?)
                                          • Steph.hen
                                            Bridge rectifier identification part number KPB305G
                                            by Steph.hen
                                            Hi all, a newby question about a bridge rectifier I'm trying to identify.
                                            I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?...
                                            08-29-2024, 09:52 AM
                                          • mpn78
                                            Fujitsu Q556, What capacitor for bridge rectifier?
                                            by mpn78
                                            Hello
                                            My Fujitsu Esprimo Q556 motherboards blew up. At least fuse, bridge rectifier and capacitor got damaged. I have changed fuse and bridge rectifier (DF1508S), but I don't know what capacitor it is (picture). I know that capacitors size is 47nF, but I don't know other specs for it. Can you help me to choose right capacitor for my motherboard?
                                            There is 240V AC on input side of bridge rectifier and 340V DC as output on capasitors side.
                                            Thanks....
                                            04-05-2022, 12:31 PM
                                          • EasyGoing1
                                            Reading input and output of bridge rectifier on the same scope?
                                            by EasyGoing1
                                            I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
                                            When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
                                            06-26-2022, 12:52 AM
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • Ross Kohler
                                            Diagnosing South Bridge (FH82H370) on Asus H370-Pro Gaming Motherboard
                                            by Ross Kohler
                                            I'm learning about motherboard repair and I believe I've traced the issue down for the South Bridge on the particular motherboard I'm working on. My path of concluding that:
                                            - There's no sign of any attempt to power on when pushing the power button.
                                            - No PSON signal is reaching the 24-pin ATX connector.
                                            - The Super IO chip is receiving the PS_SWITCH signal from the power button and is relaying this signal back to the South Bridge.
                                            - The Super IO is not receiving the S_SLPS#_R signal back from the South Bridge
                                            - If I pull the Super IO S_SLPS#_R pin...
                                            04-16-2024, 09:36 AM
