Vizio VW42LFHDTV10...Brother Mikes TV...
  • kingofcoins
    SaveOnGreen-Cap
    • Jan 2010
    • 162
    Volunteering with this as my first TV project, but I believe it is repairable...and it would appear PlainBill also likes these challenges too:
    Brother Mike reports some squiggly lines , then it gave a whine, and went black. Now as cord is plugged in the amber light comes on, and after 5-10 seconds there is a double click, which sounds like first the main filter cap, then the bridge rectifier clicks. Unit does not respond to shut off switch, pulling plug and reinserting repeats symptoms. The cap has 161VDC, but when the click occurs it goes to 300+ VDC. Output to Inverter boards is zero until the double click occurs, then it swings to about 12VDC and falls away to 2-3 v, same thing occurs with logic feed.
    Main fuse 0+/-; all caps on p/s board , and the pair on each inverter board , all read low ESR's in circuit. All the bridge rectifier leg pairs read 16 to 19 ohms in circuit except the A/C pair is infinity.
    Pics show the p/s board has a lot of soldered in heat sinks; the bottom view is of the p/s.
    PS...I have an ESR meter, but only a analog VOM right now....THANKS for your help !
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Vizio VW42LFHDTV10...Brother Mikes TV...
    In theory, I understand what a bridge rectifier does and I have certainly helped others here identify bad ones (in fact, just one today) with successful repairs as a result.
    So if you measured (with power off and tv unplugged) pins 1-2, 1-3, 1-4, 2-3, 2-4, and 3-4 and found 16 ohms on even one pair, I would say this bridge rectifier is shorted.
    However, I'm not so sure about it being shorted with your findings of 161V DC and a fuse that measures 0 ohms.
    On TVs, I know there are multiple power sources. A standby 5V, the main power, and a potential PFC (which I'm still learing about).
    --- begin sig file ---
    --- end sig file ---
    • kingofcoins
      SaveOnGreen-Cap
      • Jan 2010
      • 162
      Re: Vizio VW42LFHDTV10...Brother Mikes TV needs help
      Being new inside a TV I realize they would have more circuitry features than an LCD monitor, but am at a loss about multiple power sources. Do you mean my finding a variable voltage output at the main cap could be part of the scheme and not a failure ?
      • kingofcoins
        SaveOnGreen-Cap
        • Jan 2010
        • 162
        Anybody have a link to schematics or repair manual for this Vizio?
        • PlainBill
          • Feb 2009
          • 7034
          Nothing from my usual free sources. You could try some of the paid sites.
          PlainBill
          • kingofcoins
            SaveOnGreen-Cap
            • Jan 2010
            • 162
            Re: Vizio VW42LFHDTV10...Brother Mikes TV...repair manual
            PlainBill and ALL you VERY helpful folks....
            > HAVE A SUCESSFUL AND VERY RE-PAIRABLE HAPPY NEW YEAR !!
            BILL..> I did find a service manual at Elektro Tanya here :
            Would you help me on this diagonsis and repair please ?
            • kingofcoins
              SaveOnGreen-Cap
              • Jan 2010
              • 162
              Re: Vizio VW42LFHDTV10...Brother Mikes TV...update
              Update on my progress...I found after several plug in trials that the unit does regularly produce the 5VSB supply to the logic board, and the double click I hear is apparently the power supply failing to make or maintain the 12v and 24v connection. After several more tries it happens that instead of kicking right out it will hold then a few seconds later a second click will result in the logo going to white and then I read the 12v and 24 volt out of the p/s board. This however is as far it goes, no lights, and unit will not turn off.
              • PlainBill
                • Feb 2009
                • 7034
                Well, I can explain some of the readings you describe. The basic design of this power supply is pretty standard for TVs of this size. AC in goes through an input noise filter and surge protection, then into a bridge rectifier and produces about 165VDC across the main filter cap. This is used to power a standby power supply, which is always on when the TV is plugged in. The output of the standby supply goes to the main board, and provides power for the standby processor and associated components, mainly the IR receiver, and keypad.
                When the TV is turned on via either the remote or the keypad a signal is sent back to the power supply which turns of the PFC (power factor correction) front end and the main supply. The PFC 'chops' the rectified AC and boosts it to about 300-350 VDC. The main supply produces the 5V and 12V supplies for the main board and the inverter. Either 5V or 12V is used to provide other voltages (3.3V, 2.5V, 1.8V) used on the main board
                Now, I'm having problems explaining the symptoms you are seeing. Usually when the standby processor turns on the main supply it verifies the voltages are correct, then initializes the main processor(s). If an error is found it will shut down the main supply and possibly flash an error LED.
                The fact that the main supply will sometimes shut down again and other times will stay up is characteristic of bad caps, especially if after several repeated attempts it will stay up. Theorizing that the DC out of the power supply is noisy, thus causing stability problems for the main board would seem logical. The fact that you checked the ESR of all caps and found them good shoots a rather large hole in that theory.
                I have two tests to propose. First, start with a 'cold' set - one that has been unplugged for at least half an hour. Monitor the 'Power On' signal at the connector from the main board. Plug in the TV and see if the signal behaves consistently through several attempts to power up, until it does go into the white Vizio logo. Unplug the set and try again. Does it go to the white logo on the first attempt? If so, that would imply that something is warming up and working when it is warm. Again, this is characteristic of a marginal cap. If on the other hand, it seems to be more random (it would go to the white logo about 20% of the time), it would suggest something else is the problem.
                If it DOES appear to be a thermal problem, the second test would be to use a hair dryer to warm various points - the caps in the power supply, various parts of the main board, etc, and see if there is a particular area that appear to be thermally sensitive.
                If it doesn't appear to be thermal, try flexing various parts of the main board slightly to see if that has any effect.
                PlainBill
                • kingofcoins
                  SaveOnGreen-Cap
                  • Jan 2010
                  • 162
                  Bill... Thanks for coming in and you have a GREAT New Year !!
                  Some of the confusing symptoms and readings are no doubt from bringing the caps out of 9 months idle storage and 'warming' it up. When I first tried set plugging in and out, the switch had no affect, and the clicking pattern was different. Now that its 'awake', the switch seems to jump up the main supply, but only after a few seconds delay, which then reads 400VDC btw, the logo goes white, and it's only then that I read the 24v and 1.8v at the inverters, and 12v, 5v and 3.3v to the main board. Otherwise its only 5VDC output to mainboard during standby. And switch fails to turn set off.
                  Now the cold boot test ..set off about 45 mins, meter on pin 14 of J7, plug in, the logo stays amber even though the double click is heard. plugging and unplugging deflects meter slightly but does not get white logo until switch is pressed even then only after a few seconds delay. When logo white, meter shows slight drop in signal ohms. Pull plug and reinserting on several attempts failed to get the white logo back...only way is pressing switch and waiting.
                  All the lytics on the power and inverter boards where checked in circuit with 'Russian Mikes' ESR meter, each would read like 0.02 or so but the capacitance would show as some multiple. Advise if we need also a volt or ohm check on them. The hair dryer on the main board caps didn't produce a thermal response. And I did not ESR check any on the main/logic board, yet...there are about 70 of them ...advise.
                  Other notes:
                  I read there is supposed to be a blue led on inverter boards when lamps light up. I of course see none.
                  I've read Vizio says inverter boards are integral part of display, and not repairable....this is not true as there are two separate removable boards.
                  Do I need to plug in the TV cable during any tests...LMK.
                  I haven't seen any back lights or image either way so far.
                  There is 6. VDC at the speaker wires from mainboard.
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Other notes:
                    I'm going to be shutting down for an afternoon of watching football (the type played with an oblate spheroid), so this will be brief. Here's a little information on the typical start up sequence.
                    Initially the power cord is plugged in, and the standby supply is providing 5Vdc. The power button is pressed, and the standby processor carries out a series of health checks, then turns on the the main supply. The PFC boosts the rectified line voltage to 400 VDC, and the main SMPS comes up. Once these voltages are stable the main processor is started, and begins it's own self tests.
                    Many power supply designs have a number of caps in parallel. Measuring the ESR is tricky. My best suggestion when measured capacitance is a multiple of a single capacitor is to test the ESR of each out of circuit. As a quick alternative, multiply the measured ESR by the number of caps in parallel. As an example, 1000uF 16V FM series has an ESR of .02, three in parallel should read .007.
                    PlainBill
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      A video explanation of this is at
                      http://www.youtube.com/watch?v=4iTR-iCn0hY
                      • kingofcoins
                        SaveOnGreen-Cap
                        • Jan 2010
                        • 162
                        Re: Vizio VW42LFHDTV10...ESR the caps
                        Always best, yes, testing out of circuit. Good when you question 6 , 7 maybe 10 caps. But, looking at my mainboard here there are 70 caps...good chance I may hurt something,or add to the problems by undoing and re-doing that many, huh ? In such cases is there any way we can narrow our suspects down?
                        Now, are you saying that e.g., measuring some parallel caps in circuit will show a higher capacitance and total ESR than their individual readings when out? So if I see a cap, in parallel with say two others, and I read some multiple of its capacitance in circuit, and say the ESR read is 0.18, then its likely that none of the caps individually is over 0.18 ohms ESR, and that if they of similar make, use, and condition, the average one will be about 0.06 ohms ESR out of circuit ?
                        Or do I have it all backward ?
                        Working Update....I probed those 70 caps on my mainboard this PM and found 4 that were high in ESR, and a pair of parallel 220uf x 16V caps both reading 0.76 ESR. Would bad caps on this main/logic board be causing any of the faults.. and what would you suggest I do next...pull a leg and retest ?
                        ...Or?
                        • PlainBill
                          • Feb 2009
                          • 7034
                          ...Or?
                          Remember the rules for parallel resistors. Two identical resistors in parallel would measure half their nominal resistance value (and have twice the power rating). Two 1K 1/2 Watt resistors in parallel would measure 500 ohms, and have a combined rating of 1 watt.
                          In the case of the capacitors you mentioned, a 220uF 16V cap should have an ESR below .115 ohms. Two in parallel should have an ESR below .057. (ESR is a 'better than' rating). At .76, they are more than 15 times the design specs for a low ESR cap.
                          As far as being responsible for the symptoms, it depends. In general terms, there are two types of power supplies; linear and switching. If these were providing filtering for a linear supply, they probably are good. If they are filtering a switching supply, they are bad. What is the brand and series of the caps?
                          PlainBill
                          • kingofcoins
                            SaveOnGreen-Cap
                            • Jan 2010
                            • 162
                            OK based on your explanation then a lot of my cap readings in circuit will turn out to be marginal or high, depending on their usage, thus the need to search the cause of failure further before attacking so many caps. I'll start with the high ESR pair CE21 and CE22, as they are in the switch control circuit by the J2 connector.
                            My cap brands are...
                            On the Mainboard they are all 70 TAICON's, of several series like C0647
                            On the Inverters there are 4 Rubycon ZLH
                            On the power supply board they are mostly Nichicon (not sure series), and some Chemicon KZE's
                            BTW, can you provide a link for us to a table of acceptable low ESR's for caps?
                            • PlainBill
                              • Feb 2009
                              • 7034
                              You are going to have to do that yourself. Start by looking for a datasheet based on the manufacturer and series, then looking up the ESR for the capacity and voltage. Remember this is a 'better than' value. A capacitor with an ESR rating of .05 ohms might read .02.
                              PlainBill
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                C0647 denotes year 2006 and week 47. This is when the caps were made.
                                • kingofcoins
                                  SaveOnGreen-Cap
                                  • Jan 2010
                                  • 162
                                  Bill....what I meant was an acceptably low ESR reading for a used cap regardless of series or manufacturer...as a guide I use in LCD circuits....
                                  1) Bob Parker's K7214 table...I want my caps at less than half of his values:
                                  2) Kakopa's design...I like the high quality or better columns:
                                  http://kakopa.com/ESR_meter/
                                  PlainBill
                                  • kingofcoins
                                    SaveOnGreen-Cap
                                    • Jan 2010
                                    • 162
                                    Re: Vizio VW42LFHDTV10...Brother Mikes TV...taicons
                                    So any opinions on all these Taicons on my board ? Do they have good and bad series ?
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      https://www.badcaps.net/forum/showthread.php?t=388
                                      From some comments I have seen, you are only half right. Seriously, you should trust the readings of your ESR meter over what some guy in Phoenix says. A cap that gives a bad reading is bad. A cap that reads a good ESR is almost certainly good, and is not the cause of a problem you are seeing. If it is a garbage brand, it may fail soon, but it hasn't yet.
                                      PlainBill
                                      • kingofcoins
                                        SaveOnGreen-Cap
                                        • Jan 2010
                                        • 162
                                        I took out the 6 Taicon caps from the mainboard, and all 6 had actual ESR's
                                        about 4 to 5 times what I would call OK to leave, and up to 16 times higher than the Panasonic FM's I installed.
                                        Interesting the out of circuit ESR's were in all cases about 10-20% lower than the in circuit nos I read..eg, those parallel 0.76 in circuit caps both read about 0.65 when pulled.
                                        Now that they're off I see they where mostly Taicon series VT with the two 'poor' ones series VZ.
                                        Results of fix...see next post...>
                                        PlainBill
                                        • Steph.hen
                                          Bridge rectifier identification part number KPB305G
                                          by Steph.hen
                                          Hi all, a newby question about a bridge rectifier I'm trying to identify.
                                          I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?...
                                          08-29-2024, 09:52 AM
                                        • mpn78
                                          Fujitsu Q556, What capacitor for bridge rectifier?
                                          by mpn78
                                          Hello
                                          My Fujitsu Esprimo Q556 motherboards blew up. At least fuse, bridge rectifier and capacitor got damaged. I have changed fuse and bridge rectifier (DF1508S), but I don't know what capacitor it is (picture). I know that capacitors size is 47nF, but I don't know other specs for it. Can you help me to choose right capacitor for my motherboard?
                                          There is 240V AC on input side of bridge rectifier and 340V DC as output on capasitors side.
                                          Thanks....
                                          04-05-2022, 12:31 PM
                                        • EasyGoing1
                                          Reading input and output of bridge rectifier on the same scope?
                                          by EasyGoing1
                                          I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
                                          When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
                                          06-26-2022, 12:52 AM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • Ross Kohler
                                          Diagnosing South Bridge (FH82H370) on Asus H370-Pro Gaming Motherboard
                                          by Ross Kohler
                                          I'm learning about motherboard repair and I believe I've traced the issue down for the South Bridge on the particular motherboard I'm working on. My path of concluding that:
                                          - There's no sign of any attempt to power on when pushing the power button.
                                          - No PSON signal is reaching the 24-pin ATX connector.
                                          - The Super IO chip is receiving the PS_SWITCH signal from the power button and is relaying this signal back to the South Bridge.
                                          - The Super IO is not receiving the S_SLPS#_R signal back from the South Bridge
                                          - If I pull the Super IO S_SLPS#_R pin...
                                          04-16-2024, 09:36 AM
