LG LV880 VCR issues
  • Tom41
    • Oct 2005
    • 339
    • England
    LG LV880 VCR issues
    Today, I was transferring a bunch of old VHS tapes to DVD using this VCR and a DVD recorder. Unfortunately, one of the tapes had clearly snapped in the past and been stuck back together with sticky tape. Usually this doesn't cause too much of a problem, but I think the adhesive on the sticky tape had degenerated over the years. Looking at the splice later on, I noticed a little bit of powder that may either be loose oxide on the tape, or the remains of the adhesive.
    When the splice passed the heads, the picture and sound completely disappeared. Not having a usable head cleaning tape, I decided to run some fairly new, 'clean' tapes (no splices or dirty bits) back and forth for a while until eventually the picture came back.
    However, the VCR is not picking up the Hi-Fi Stereo signal on any of my tapes now, and the mono sound I get is slightly wobbly. In addition, the picture quality is not quite as good as it was before. I've ran tapes to the end and back to see if I can dislodge any dirt on the heads, but it's pretty much the same no matter what I do now.
    I've tried both tapes originally recorded with this VCR, and store-bought movie tapes. Both produce a slightly poorer picture, and no stereo Hi-Fi sound.
    Do you think that the VCR just needs a good clean (perhaps opening it up and cleaning the heads manually), or has the Hi-Fi stereo head been damaged beyond repair? There is no Hi-Fi sound at all, not even intermittently, and that may be a bad sign. Should I see if I can get hold of a new head cleaning cassette? If so, should I go for the wet or dry type?
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • crepiduse
    • Nov 2010
    • 69
    Re: LG LV880 VCR issues
    I would run a liquid cloth head cleaner tape through it and see what it does, or manually clean them. I doubt you damaged them beyond repair, but if it scratched it it "may" be possible.
    • romansroad
      • 123
      Definitely a liquid cleaner, and I bet all will be well. You could pop the cover and use 95% isopropyl alcohol with a soft (chamois) swab as well.
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • triplefour
        LG 75UN8570AUD panel issue fixed with tape.
        by triplefour
        I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
        add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
        07-17-2023, 10:22 PM
      • gretti
        MSI Z370-A Pro, works but does not power off or reboot and USB issues
        by gretti
        I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
        The MSI BIOS included the ME firmware for the board. The size...
        10-16-2025, 02:14 AM
      • RetroComputingGrotto
        IBM LTO 7 Tape Drive - Dust Sensors??
        by RetroComputingGrotto
        I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
        I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
        09-19-2024, 01:54 AM
      • alltvrepairs
        Hisense 55AS6G screen double sided tape required
        by alltvrepairs
        I need to replace the LEDs of this TV. The screen is glued with double sided tape. This video shows the proceudre required.
        I need a source for this type of double sided tape adhesive please.
        https://www.youtube.com/watch?v=bN6g...nel=QUADRA-NET
        Tks!
        07-17-2025, 09:32 AM
