Teac LCD221d TV flickering problem
  • andy smethurst
    • 49
    Hello: I have one of these Teac 22" tv's that seems to work fine except I don't have the original external power supply, which should be (15v-6A). The only one I have at the time is a (16v-3.7A). Would the difference in available current be the cause of the flickering,? or what. This tv is about 5 years old and user manuals and schematics dont seam to exist, unless i'm looking in the wrong areas? Any help on this model would be appreciated,Thanks
    Regards:Andy
  • PlainBill
    • Feb 2009
    • 7034
    Re: Teac LCD221d TV flickering problem
    Regards:Andy
    1. I would suspect the power adapter.
    2. Source of service manual.
    PlainBill
    • truep
      • Aug 2010
      • 373
      I also suspect the power adaptor. You are drawing way too much current causing the voltage to lower. You may also overheat the power adaptor and cause a fire hazard
      • andy smethurst
        • 49
        Hi, I found a (16v-4.5A) power supply and this cured the flickering problem, but still gets hot of course, and i wouldn't intend using it on a permanent basis,i'me just trying to sort the thing out. I got it at a salvage auction with no power supply and no remote. That is the other problem,I've used a couple of those cheap programable remotes, but the codes seem to only operate the minimal operations, like on-off,and volume and change stations if you're lucky, so if anyone has advice on this area I would appreciate your advice.
        Regards:Andy
        • bamboofuto
          Redmibook 15 (67591_1_15) screen flickering problem
          by bamboofuto
          does anyone know how to solve Redmibook 15 (67591_1_15) screen flickering problem.
          i tried changing lcd 2 times but still got the same problem.
          when connected to external display everything normal....
          09-27-2024, 09:44 PM
        • theone111
          by theone111
          3. Problem: TV shuts down
          07-22-2024, 10:36 AM
        • Zeonalbasta
          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
          by Zeonalbasta
          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
          09-13-2024, 01:17 PM
        • reessi
          ACER BM320 Monitor - Horizonal Flickering Lines After a While
          by reessi
          The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
          They are black on the right and gradually fade to nothing on the far left.
          They start either after 5 mins or up to 2 hours after so annoying for testing.
          They flicker continuously very fast! With a slight pause milli-second every second.
          Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
          I tested each half by removing the first the left flex from...
          06-03-2025, 09:58 AM
        • domu
          Viewsonic VS16217 strange problem - white flickering screen on power up
          by domu
          As per subject, on power up display shows no image, but white
          flickering screen. Strangely, it only happen after power was lost
          when it was on. After power returns - white screen only, but if
          disconnect power for 12-24 hrs, and connect then again monitor
          works normally.
          Any clues how to go about it would be greatly appreciated.
          07-18-2023, 04:57 AM
