Redmibook 15 (67591_1_15) screen flickering problem
  • bamboofuto
    • Nov 2022
    • 53
    • indonesia
    does anyone know how to solve Redmibook 15 (67591_1_15) screen flickering problem.
    i tried changing lcd 2 times but still got the same problem.
    when connected to external display everything normal.
  • bamboofuto
    • Nov 2022
    • 53
    • indonesia
    anyone?
    • mmccomputer
      problem with replacing lcd screen
      by mmccomputer
      I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
      otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
      If anyone has any information on the subject...
      12-15-2024, 03:44 PM
    • jimjoe123
      LCD TV Green/Pink screen problem
      by jimjoe123
      I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
      Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
      Then each time...
      02-23-2020, 01:29 AM
    • domu
      Viewsonic VS16217 strange problem - white flickering screen on power up
      by domu
      As per subject, on power up display shows no image, but white
      flickering screen. Strangely, it only happen after power was lost
      when it was on. After power returns - white screen only, but if
      disconnect power for 12-24 hrs, and connect then again monitor
      works normally.
      Any clues how to go about it would be greatly appreciated.
      07-18-2023, 04:57 AM
    • benek123
      RedmiBook 15 pro 2023 Ryzen - after replace LCD screen work only in windows
      by benek123
      I replaced the screen and LCD ribbon in Redmi Book 15 Pro Ryzen 2023. After replacing, the image on the screen is only visible in Windows 11 - when the AMD drivers are loaded.
      The screen is backlit but there is no image in: bios, post, when loading windows, in linux (ubuntu boot from usb), windows 10 PE.
      When I disconnect the EDP connector from the board and connect the HDMI cable, the image is visible everywhere good, in the BIOS you can see 2/3 of the image, i.e. 1920 pixels out of 3000 pixels.
      I checked the EDID with the old screen - it is identical.
      What...
      09-24-2024, 03:28 PM
    • Chrissygizmo
      Sony KD-55XG9505 lines on screen problem
      by Chrissygizmo
      Hello again everyone,
      This is my latest mission, to try getting this Sony tv back to normal working order…
      I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
      02-19-2025, 11:31 AM
