LG 37LC7D - turns on for several seconds then goes grey
  • frannyjunk
    • Oct 2010
    • 82
    Hi, I have an LG LCD TV that I am trying to diagnose. Here are the symtoms. I can turn in on no problems. After a random amount of time (sometimes a few seconds, sometimes hours), the screen goes dark grey (backlight still on, I can see it). I can unplug the ribbon cable from the power supply to the mainboard, then re-plug it in and the TV is ok upon turning on. After a few seconds (to sometimes minutes), there's a pop and the TV makes a faxing machine type sound (high pitch recurring whine). Can I assume that this is a mainboard issue? There is no sound outside of the high pitch whine. My logic:
    TV turns on and off just fine = power supply is ok
    TV comes on and works fine after everytime I unplug the power supply ribbon cable (not the 5V but the 12/24V) = TCON is ok
    Is my logic correct? I don't know how to check the power supply to the mainboard. Perhaps someone can instruct me?
    Thanks for any help the forum can provide. Thanks!!
    P.s. I don't see any bulging caps.
  • Hobby 1
    • Mar 2010
    • 86
    Re: LG 37LC7D - turns on for several seconds then goes grey
    A bad T-con will give you a grey screen.
    The power supply voltages will be labelled on the board. Measure the voltages when the set is on and working ok as well as when the problem shows up. See if there is any difference.
    • zklgfs
      Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
      by zklgfs
      I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
      08-11-2025, 02:14 PM
    • twonk9098
      Lenovo Legion 5 high fan spin turns off after 34 seconds
      by twonk9098
      I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
      I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
      I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
      I have tried a few new bios but exactly...
      07-14-2024, 11:19 AM
    • Rick_1234
      by Rick_1234
      Good evening, gentlemen.
      Things I tried
      06-22-2024, 04:44 PM
    • riko 656
      Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
      by riko 656
      I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
      Laptop Model:
      • Model: Lenovo Legion Slim 5 16APH8
      • GPU: NVIDIA GeForce RTX 4070
      • Main BIOS chip size: 32MB
      • VBIOS chip size: 16MB
      Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
      What I Have Tried So Far:
      1. I
      11-04-2025, 05:14 AM
    • Kambi13
      Dell Inspiron 3542 Turns on works for 30 seconds to 1 minute then turns off
      by Kambi13
      Hi all need some help, I've got a Dell insprion 15 3542 that turns on works for about 30 seconds or sometimes a minute or two and then turns off and wont turn on again until I remove and replug the power connector
      Not heat related, everything is ok regarding to that.
      All voltages are present.
      Wondering if this as anything to do with one wire circuit, the charger is not original, but it was working fine
      Motherboard is Cedar 13269-1 F3XMC Rev A00...
      07-12-2024, 06:10 AM
