Vizio VW42LFHDTV10.4 ?
  • chocolate123
    • Dec 2010
    []Good afternoon all,
    I need help.
    I have a Vizio VW42LFHDTV IOA OR so I believe is the model number.
    I paid Vizio to do diagnostics on it.It has no picture ,the diagnosis is INVERTER BOARDS HAVE BAD CAPS.i HAVE REMOVED THE BACK FROM THE SET AND COVER FROM THE RIGHT SIDE ir BOARS MAIN OR SLAVE(?)
    The cap on the right side board looks to be marked SC43 there are two caps there marked VOA PET,I assume the boards are identical if only transposed left to right.
    Can someone tell me where to buy these caps,the top of one is bulged and leaking.I need to know what and where to find these and then I have a dude who will solder them in for me .
    Where can I buy them and what is the part number?
    Happy holidays and tthanks for helping me try to save some money to get my two year old tv fixed.
    chocolate123
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Vizio VW42LFHDTV10.4 ?
    PET is the material used in the sleeve.
    Other than that the numbers don't tell me anything.
    Have pics?
    Mann-Made Global Warming.
    - Dr Seuss
    • hoadle
      • Jul 2010
      • 174
      Correct Vizio VW42LFHDTV1OA & I had Vizio VW42LHDTV1OA need replace new mainboard or T-CON board (i think not sure)
      when I turn on the logo Vizio form Orange to White color & back light on but no logo or blue screen
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • SS454
        vizio e650i-a2 backlight flashes then turns off
        by SS454
        vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
        panel: au optronics T650HVN05.4
        72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
        link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
        Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
        https://www.shopjimmy.com/vizio-56-0...-power-supply/
        Vizio 55.75J01.001G (91.75J10.004G) Main Board...
        08-20-2020, 03:57 PM
      • mrtek
        Vizio M65-C1
        by mrtek
        Hi.
        picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
        When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
        This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
        07-14-2025, 07:28 PM
      • howardc64
        Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
        by howardc64
        Failure Symptom
        No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
        Where is the short?
        Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
        Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
        05-27-2025, 02:56 PM
      • howardc64
        Vizio SmartCast TV software bug that looks like hardware
        by howardc64
        Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
        It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
        11-16-2024, 05:17 PM
