Sharp LCD TV Blows Fuses LC-19SB24U
  • Solder Boy
    • Nov 2006
    • 178
    I've had this unit on the shelf for a year so I dusted it off to see what was wrong with it. It didn't turn on at all. I checked the alum caps they were good but I'm not sure about the two rectangular black caps.
    One is .1uf 275v the other is .22uf 275v. The one black cap doesn't even register anything on my ESR meter and the other one reads 25 and is in the yellow zone.
    The small black fuse is a replacement.. it blew when power was applied.
    Would I be in the right area if I suspect those two black caps are bad?
    The grey fuse tested ok.
    www.bcrelectronics.ca
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Sharp LCD TV Blows Fuses LC-19SB24U
    I haven't worked on any LCD TVs, but people report that these types of caps rarely fail.
    If the fuse blew, I would check the bridge rectifier (D7527) for shorts. Number the pins 1-4. Set your multimeter on 200 ohm (if manual). With power off and lcd unplugged, measure 1-2, 1-3, 1-4, 2-3, 2-4, and 3-4. Any reading below 30 ohms suggest a shorted bridge rectifier.
    If there are no shorts, check capacitor C7528 to see if you get mains voltage x 1.4 DC V. That is 120 AC * 1.4 = 160 to 165V DC.
    If that is present, there seems to be two diodes mounted on heatsinks. Using a ground screw for the black probe, put the red probe on the middle pin and measure the DC V.
    --- begin sig file ---
    --- end sig file ---
    • Hobby 1
      • Mar 2010
      • 86
      Its not a cap, its the power FET. Look for one with a dead short across the legs. Replace it with a higher rated one. These are all failing with the same problem. Takes longer to open the case than to fix it.
      • Dgtech
        E. Technician
        • Apr 2009
        • 1462
        • Steeler
        It sounds to me like you have a direct short to ground on the primary (HOT) side. This should be easy to find. You can do everything with the power off. First, measure across the fuse with ohm meter. What resistance do you get there. If zero, then I'd desolder the rectifier, and then re-measure.
        • easterbran
          • Nov 2018
          • 4
          Sorry to resurrect such an old thread. I am currently having the same issue with my LC-19SB24U. I have tested both F7501 (good) and F7502 (bad). So I replaced F7502 with a 2.5A 250V slow-blow fuse. Every time I connect the Power Supply Board to the wall, the F7502 fuse immediately blows. This happens with the Power Supply Board isolated from all other components (not connected to the main board or backlights).
          I then checked the two large diodes (D7520 and D7526) for continuity from anode to cathode and they looked good. No continuity in the reverse direction, as expected. These were both tested off of the board.
          All caps appear to be in good shape, no bulging or discoloration. Following the advice in this thread, I looked into the FETs attached to the heatsinks. Following this guide (http://electronicsbeliever.com/how-t...-is-defective/), I found that the resistance was nearly zero across all pins of Q7523, which is part number (FQPF8N60C), and that this likely means that this transistor is bad. The other FET showed high resistance (order of kOhms) between all pins, so I ruled this one out.
          I'm currently waiting for the new FET to arrive, but was wondering if anyone had any advice or things to check in the meantime?
          I'm referencing the Troubleshooting diagram (attached) from the service manual (downloadable here: ).
          • easterbran
            • Nov 2018
            • 4
            Forgot to mention, I have checked the D7527 Bridge Rectifier to make sure the resistance is appropriate from anode to cathode of each diode, and all 4 pins looked good. This was done with the rectifier off the board.
            • R_J
              • 9556
              If the fet is shorted all around, then it is very likely components in the gate drive are also bad and need to be checked.
              Check D7522 (15volt zener) Q7524 (2sc2712)
              • TechGeek
                Computer Geek
                • Jan 2015
                • 2254
                Is it a Hot to Neutral or Hot to Ground short? You can verify this by checking resistance on the 3 pin IEC connector. Ground is the lonely pin.
                Hot is on the left if the connector looks like this:
                Hot on right:
                EDIT: the lonely pin is on the middle
                Permanently Retired Systems:
                Kooky and Kool Systems
                sigpic
                • easterbran
                  • Nov 2018
                  • 4
                  SOLVED!
                  It was indeed the Q7523 FET, which is part number (FQPF8N60C). I replaced it with a $10 replacement off eBay, and all is well. No more blowing the F7502 fuse and the monitor works as usual.
                  Thanks all!
                    Surface Mount Fuses Fundamentals Datasheet
                    TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                    TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                    10-07-2024, 06:07 AM
                    TF-FUSE Thin Film Surface Mount Fuses (Very Fast Acting), 0603 Size Datasheet
                    FF Series (Very Fast Acting), 0603 Size
                    Features
                    ● Very fast acting at 200% overload current levels
                    ● Low DCR
                    ● High inrush current withstanding capability
                    ● Fiberglass enforced epoxy fuse body
                    ● Copper termination with nickel and tin plating
                    ● Halogen free, RoHS compliance and lead-free
                    Applications
                    ● Notebook computers and tablets
                    ● Digital cameras
                    ● Memory cards
                    ● Toys
                    ● Bluetooth earphones
                    ● Portable electronic devices​...
                    10-07-2024, 05:50 AM
                  • BlackScreen_22
                    Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
                    by BlackScreen_22
                    Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
                    Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
                    I had no problems connecting mosfets and capacitors,...
                    08-27-2024, 12:46 PM
                  • Michale32086
                    LG 60LN5400 Blows TCON Fuse
                    by Michale32086
                    I could have sworn I posted about this before, but I can't seem to find the post..
                    To whit..
                    I have a 60LN5400 that came in.. Backlights work fine.. No display..
                    Traced the problem to the TCON board.. Blown fuse..
                    Replaced the fuse.. Blows again.. Replaced the fuse again... This time it fries the marked part on the Main Video board...
                    Got a new Main Video Board.. Replaced the fuse on the TCON..
                    The fuse is fine and the backlights come on fine if I don't have the cellophane connectors from the TCON to the...
                    10-30-2019, 09:21 AM
                  • dimis7
                    LG 37LS5600 blows main fuse
                    by dimis7
                    Need some advice to troubleshoot this TV.
                    PSU blow the main fuse F100, 3.15A.
                    I replace the fuse with another 3A (but not ceramic) and blows it again after few seconds when i plugged in to the wall, with nothing connected to PSU, just the power cord.
                    I checked with DMM for dead sorts but didn't found any.
                    Checked bridge rectifier and seems ok.
                    Also check main filter cap with transistor / cap / esr tester (the usual cheap transistor testers from ebay) and found ok.
                    PSU p/n is EAX64405901 (1.6)...
                    10-28-2022, 05:15 AM
