Sharp LCD
+ More Options
Posts
  • fastvideo
    • Dec 2008
    • 55
    Re: Sharp LCD
    Originally posted by Menessis
    Check for "gammy"? Do you mean "Gummy" ? Dried up grease? on the heat sink?
    Menessis
    Yes, sorry for the wrong spelling.
    I have saw the heat transfer pad dried up on Sharp tv before.
    Also get a can of freeze, this can help diagnose and locate where is your heat problem.
    • retiredcaps
      • Apr 2010
      • 9271
      Re: Sharp LCD
      Good suggestion. If heatsink is removed, please post pics so we can see what it looks like.
      --- begin sig file ---
      --- end sig file ---
      • Menessis
        • Nov 2010
        • 51
        Re: Sharp LCD
        I tried using the hair dryer when the tv is cold and warming up different areas to see if there is a difference. LOL. How do you use the "freeze"?
        Menessis
        • Menessis
          • Nov 2010
          • 51
          Re: Sharp LCD
          OK here is a shot of the heat sheild removed. The grease wasn't dried up. Didn't find any nasty looking solder joints either.
          New caps I think is the next step??
          Menessis
          • Menessis
            • Nov 2010
            • 51
            Re: Sharp LCD
            Update. I just put it back together enought to turn it on. I used the hair dryer on the caps in the psu for maybe 20 to 30 seconds and tried it. I did this about 5 or 6 times and walla! It works. So it would seem to me that the problem is indeed the caps.
            Menessis
            • PlainBill
              • Feb 2009
              • 7034
              Re: Sharp LCD
              Menessis
              1. That's a good sign. If you want a better verification, rig a shield over the caps so you are heating the surrounding components, but not the caps. If it now DOESN'T respond to the hair dryer, you have proven it's the caps.
              2. That's spelled voila! http://www.answers.com/topic/walla Although in this case, eureka (used to express triumph on a discovery) might be more appropriate.
              PlainBill
              • Menessis
                • Nov 2010
                • 51
                #27
                Re: Sharp LCD
                Good idea....I'll try that tomorrow.
                Menessis
                • Menessis
                  • Nov 2010
                  • 51
                  #28
                  Re: Sharp LCD
                  ok so now I can't find the two 330uf 220vlt caps anywhere!
                  Menessis
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #29
                    Re: Sharp LCD
                    Mouser carries a Nichicon 330uF 220V cap. I don't know if it is the correct dimensions though. Digikey has nothing with qty = 2 (minimum is 200). If the Nichicon is the wrong dimension, then list the dimensions of the existing UCC cap and we can go up in voltage while keeping the 330uF.
                    All the other KY caps can EASILY be replaced with Panasonic FM caps. The FM caps exceed the esr and ripple of the KY caps.
                    KY datasheet at
                    FM datasheet at
                    I compared 2 for fun.
                    1000uF 25V - KY 0.031 ohms 1910 ripple
                    220uF 35V - KY 0.080 ohms 865 ripple
                    1000uF 25V - FM 0.018 ohms 2600 ripple
                    220uF 35V - FM 0.038 ohms 1290 ripple
                    Good job with the hair dryer to narrow down the problem.
                    • fastvideo
                      • Dec 2008
                      • 55
                      #30
                      Re: Sharp LCD
                      KY datasheet at
                      FM datasheet at
                      KY has a better life time 7000hrs.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #31
                        Re: Sharp LCD
                        Digikey says KY has 10,000 hours.
                        The new Panasonic FR series (equivalent to the FM) has 10,000 hours and it looks like it is finally in stock at digikey, but "on order" at mouser.
                        So instead of ordering FM, go for the FR.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #32
                          Re: Sharp LCD
                          Were these the "all in one row" caps in the left hand corner? Or somewhere else?
                          • Menessis
                            • Nov 2010
                            • 51
                            #33
                            Re: Sharp LCD
                            No the 330uf, 220 v are the two big ones on there side in the middle of the psu.
                            I looked on DigiKey the other night and didn't see them there. Must have been tired!
                            OK I just looked again. Selected FR series with the filter. Then it shows up to 50v and that's it.
                            OK what about these KXG's
                            Menessis
                            • PlainBill
                              • Feb 2009
                              • 7034
                              Re: Sharp LCD
                              Menessis
                              220V sounds like it is on the line side of the PSU. No need for low ESR caps there. Of course, without a picture....
                              PlainBill
                              • Menessis
                                • Nov 2010
                                • 51
                                #35
                                Re: Sharp LCD
                                Post #8 the middle picture shows the two caps on there side. Your probably right Bill. So the KXG's I found are OK then you think?
                                Menessis
                                • fastvideo
                                  • Dec 2008
                                  • 55
                                  #36
                                  Re: Sharp LCD
                                  Menessis
                                  KX is good for the two and that is the same type on the board.
                                  It is very very rare the line filter cap to cause this type of problem, but I have saw the one with the yellow circle instead.
                                  • Menessis
                                    • Nov 2010
                                    • 51
                                    #37
                                    Re: Sharp LCD
                                    Those ones you circled are all KY's except the one to the right. All I can see on that is CS (M), it's 33uf and 350v.
                                    Menessis
                                    • Menessis
                                      • Nov 2010
                                      • 51
                                      #38
                                      Re: Sharp LCD
                                      Ok I can't find anything that fits the two big ones. 330uf 220v The only ones I can find so far are general purpose 1000 hr.
                                      Since these are the "hi" side, could I leave them in?
                                      Menessis
                                      • Menessis
                                        • Nov 2010
                                        • 51
                                        #39
                                        Re: Sharp LCD
                                        Well this is my list so far:
                                        1 3 565-1613-ND CAP 680UF 50V ELECT KY RAD 0 1.03000 $3.09
                                        2 4 565-1555-ND CAP 1000UF 25V ELECT KY RAD 0 0.74000 $2.96
                                        3 1 565-1601-ND CAP 100UF 50V ELECT KY RAD 0 0.44000 $0.44
                                        4 1 565-1575-ND CAP 330UF 35V ELECT KY RAD 0 0.50000 $0.50
                                        5 1 565-1464-ND CAP 33UF 400V ELECT KXG RAD 0 1.72000 $1.72
                                        6 6 565-1573-ND CAP 220UF 35V ELECT KY RAD 0 0.50000 $3.00
                                        7 2 P12927-ND CAP ELECT 22UF 50V FM RADIAL 0 0.34000 $0.68
                                        Still have not found the two 330uf 220v better than 1000 hours.
                                        Menessis
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #40
                                          Re: Sharp LCD
                                          I'm a bit confused here.
                                          1) Which caps are "bad" when heated up? The answer seemed to be the two main filter capacitors. Is that correct?
                                          2) I honestly don't care which brand and series of capacitors is chosen, but if you are going to replace all the KY caps, why replace them with new KY? If they are bad or suspect, why not another manufacturer like Panasonic FR series which has equivalent or better ratings?
                                          3) I also understand the requirement to match the original cap specs as close as possible.
                                          • advant
                                            by advant
                                            02-03-2020, 12:25 AM
                                          • sefoster
                                            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                            by sefoster
                                            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                            11-20-2022, 09:29 AM
                                          • SONY_E-WASTER
                                            Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
                                            by SONY_E-WASTER
                                            Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
                                            The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
                                            then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
                                            does...
                                            12-26-2021, 05:46 PM
                                          • gavenb
                                            Sharp LC-80LE661U 80 inch
                                            by gavenb
                                            Hi folks!
                                            I have a LC-80LE661U that had some interesting issues.
                                            Initially, it would come on and show the sharp logo and would show normal static before shutting off.
                                            I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
                                            11-12-2023, 02:05 PM
                                          • Superbee_dad
                                            Sharp 80” long short flash backlight error - Help
                                            by Superbee_dad
                                            Hello Sharp TV experts
                                            Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                            > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                            > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                            01-24-2025, 11:51 PM
