LCD Not Working
+ More Options
Posts
  • Menessis
    • Nov 2010
    • 51
    LCD Not Working
    OK guys. I picked up a SOYO MT-SYTPT3227AB LCD DOA. I'm not a tech. But I do build cirucuit boards from plans and so forth. I have a multimeter!
    So maybe I can get this thing working with some help of course. All it wil do when plugged in is show the red led.
    I pulled it all apart to look and see what I could find. The "main" fuse "F1" is working. I think that would be a good sign.
    Here are a couple of pics of the power supply.
    So what do you thinK ??? There is one spot that looks like it got hot. Dont see any bulging Caps!
    [/IMG]
    Any help will be great. Thanks
    Menessis
  • retiredcaps
    • Apr 2010
    • 9271
    Re: LCD Not Working
    First, please edit your original post so that images are NOT inline. Use the manage attach feature.
    Second, umm, you have 7 obviously bad caps in the lower right hand section of the power board. Since you have 7 bad caps, many here will recommend that you replace the ALL. All means all.
    Use quality low ESR caps from this list ...
    https://www.badcaps.net/forum/showthread.php?t=2280
    --- begin sig file ---
    --- end sig file ---
    • Menessis
      • Nov 2010
      • 51
      Re: LCD Not Working
      OK I think I fixed the "inline image" problem. Sorry about that.
      This is great. I was looking for a bulge along the length of the caps. But looking at the picture online is when I seen them bulged at the end! You learn something everyday!
      So to replace the caps, should I do all the little ceramic ones too?
      BTW thanks man.
      Menessis
      • retiredcaps
        • Apr 2010
        • 9271
        Re: LCD Not Working
        Nope, still inline.
        Once you see a bad one, it will be obvious in the future.
        Just replace all the electrolytic caps. I count 13 (not including the big one on its side). The big one rarely, but not never, fails.
        Caps can also fail without the obvious physical defects. They can be out of uF tolerance (a 1000uF cap may only measure 25uF) or have high ESR (ohms).
        Caps can be purchased here at badcaps.net to help support this site or they can be purchased at the big distributors like digikey or mouser. Badcaps sells Rubycon and Samxon. Digikey and mouser carry Panasonic and United Chemicon.
        Make sure to get the correct physical dimensions correct.
        • Menessis
          • Nov 2010
          • 51
          Re: LCD Not Working
          I can get the replacement caps here today and see what happens.
          Menessis
          • retiredcaps
            • Apr 2010
            • 9271
            Re: LCD Not Working
            If "here" means Radioshack or some local electronics store, I would suggest you do not proceed. Radioshack does not stock low ESR capacitors. The same goes for most general electronic stores. SMPS power supplies require low ESR capacitors to function properly.
            However, should you live in a big city or am lucky to have a local store that carries caps in the list I posted earlier, then go for it.
            Rubycon MCZ, Panasonic FM and FC series are favourites among members here.
            • Menessis
              • Nov 2010
              • 51
              Re: caps
              Well they do have the panosonic caps. No RadioShack! lol I will go see what I can find and take it from there. Have to hurry cuz I have another stop on the way.
              Thanks again.
              • crepiduse
                • Nov 2010
                • 69
                Re: LCD Not Working
                I concur, replace all caps with Rubycon or Panasonic. ALL CAPS!. Then you should be ok, if not, definitely better than you were.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Re: caps
                  No RadioShack!
                  I have nothing against RadioShack (aka The Source in Canada). I have fond memories of them from childhood, but RadioShack just does not sell the correct capacitors required for a SMPS application.
                  • weirdlookinguy
                    • Sep 2007
                    • 1638
                    Re: LCD Not Working
                    What's wrong with inline pictures? With the new auto resizer that Topcat put in, they resize themselves and fit my screen just fine. I don't have to do any horizontal scrolling. It is easier for them just to appear fit to size automatically thanks to the auto resizer that Topcat put in than to have to open a bunch of attachments that don't resize themselves.
                    Are you using IE? I think that last time I used IE, the auto-resizer didn't work and inline pictures loaded full size. Now THAT was a pain in the ass. In Firefox and Opera, the auto resizer works.
                    • Wrog
                      • Oct 2009
                      • 472
                      Re: LCD Not Working
                      The problem is that you still have to wait for the entire image to load before it resizes itself. That, and in 6 months time, who knows if the images will still be at that same (offsite) location to help future users?
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        Re: LCD Not Working
                        Let me count the ways.
                        1) Just last week, someone posted 12 MB worth of inline pictures in post #1. With 20 posts per page, it means everytime I come back to read, I have to load 12MB each and every time. 20 posts * 12 means I waste 240MB just loading the page.
                        Some ISPs have monthly usage caps and charge extra for usage.
                        2) Offsite picture hosting may not exist in the future. User accounts come and go. Or what used to be a free hosting site and then converted to a premium site and the pics no longer load.
                        3) Right now, I'm using a 9 inch diagonal netbooks and the scrolling back and forth make it impossible to read.
                        4) The 9 inch netbook has a very slow "write" solid state disk (SSD). When I download 12MB of pictures, the browser writes 12MB to the cache located on the SSD and it is very slow. It also means 12MB of cached data is possibly deleted in order to make room for a picture that I may not need to see again.
                        • Menessis
                          • Nov 2010
                          • 51
                          Re: LCD Not Working
                          Kind of funny....I'm more confussed about posting the pics them I am about replaceing the caps!
                          Are you saying not to use PhotoBucket? Some instructions please. Im in the same boat, pay for bandwidth!
                          Menessis
                          • Wrog
                            • Oct 2009
                            • 472
                            Re: LCD Not Working
                            Menessis
                            Correct, don't use Photobucket. Just use the "Manage Attachments" button when you are posting!
                            • Menessis
                              • Nov 2010
                              • 51
                              Re: LCD Not Working
                              OK NO PhotoBucktet!
                              I struck out getting the caps locally! There web page says they have the Panosonic but when I get there.....poof, no Panosonic!
                              So I will be looking at the caps link here.
                              Menessis
                              • Menessis
                                • Nov 2010
                                • 51
                                Re: LCD Not Working
                                OK in order to get these caps from you can I give you a list? I tried the link but it gave me an error page.
                                1) C41 – 22uf 50v 5mm x 12mm
                                2) C41 – 47uf 35v 5mm x 12mm
                                3) C33 – 1000uf 10v 10mm x 16mm
                                4) C34 – 1000uf 10v 10mm x 16mm
                                5) C30 – 1000uf 16v 10mm x 20mm
                                6) C31 – 1000uf 16v 10mm x 20mm
                                7) C40 –1000uf 10v 10mm x 16mm
                                8) C32 – 1000uf 16v 10mm x 20mm
                                9) C37 – 1500uf 16v 10mm x 20mm
                                10) C23 – 470uf 35v 10mm x 16mm
                                11) C21 – 470uf 35v 10mm x 16mm
                                12) C20 – 470uf 35v 10mm x 16mm
                                13) C19 – 470uf 35v 10mm x 16mm
                                There is lots of room for extra length. Let me know what you can do.
                                Thanks again.
                                Menessis
                                • Wrog
                                  • Oct 2009
                                  • 472
                                  Re: LCD Not Working
                                  If "you" means Topcat (the owner of this site), you may want to send him a private message with what you are asking since he likely doesn't read every thread. He would probably be interested in why the electronic checkout isn't working as well (which links you are clicking on). Good luck with the repair!
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    Re: LCD Not Working
                                    Hmm, I looked through badcaps.net stock and they have no stock in either Rubycon or Samxon for caps 1 and 2.
                                    All the others are available, but I would hate to pay shipping/postage twice to get some caps from here and others from another supplier.
                                    Digikey has all the caps in Panasonic FM except 47uF 35V which is available in FC.
                                    • Menessis
                                      • Nov 2010
                                      • 51
                                      Re: LCD Not Working
                                      OK I'm looking at caps. Thousands upon thousands!
                                      Does this look like what I'm after???
                                      EEU-FR1E102
                                      Menessis
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        Re: LCD Not Working
                                        I see you updated your country profile.
                                        Yes, that is the correct mouser url for Panasonic FM caps. IIRC, smason, another fellow Canadian here, orders from digikey.ca and gets his caps in usually less than 48 hours.
                                        You can choose mouser.ca or digikey.ca. I believe digikey is cheaper in terms of shipping ($8 USD) to Canada than mouser.ca ($20).
                                        If ordering from digikey.ca, I usually put this in the search field to quickly narrow down the right parts ...
                                        "1000uf 16v fm"
                                        "1500uf 16v fm"
                                        "47uf 35v fc"
                                        Since it costs $8 for s/h, you might as well get a spare cap or two and other electronic components to offset the $8.
                                        • MMH3
                                          Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
                                          by MMH3
                                          i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
                                          Never ever i experienced problems with that.
                                          Now i have one 5050sff machine, where this jumper isnt working at all.
                                          I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
                                          The history of the machine is that i used it in my office...
                                          03-23-2025, 09:28 PM
                                        • DynaxSC
                                          GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                                          by DynaxSC
                                          I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                                          There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                                          The board is generally working now, all PCIe ports are working, Windows installs normally.
                                          However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                                          The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                                          03-10-2025, 12:27 PM
                                        • obelix24
                                          Macbook Air 2020 (a2179) - touch id not working
                                          by obelix24
                                          Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
                                          I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
                                          02-09-2025, 12:57 PM
                                        • hopkok
                                          Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
                                          by hopkok
                                          Hi masters, I need your help.
                                          I am working on Lenovo Legion 16ITHg6
                                          Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
                                          INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
                                          My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
                                          AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
                                          Power LED is not working as well, power button working well.
                                          UI26 ??? is there any firmware too? Powered by +3VALW_AG.
                                          Motherboard...
                                          05-04-2025, 09:35 AM
                                        • bociub
                                          laptop freezes, usb 2.0 not working, usb 3.0 working
                                          by bociub
                                          Hi there,
                                          It is sunday and I got a faulty hp pavilion 15-cs1006na. No available schematics on the entire world. It flashed 5 long 4 short and no post then I discovered the usb 2.0 2. pin in one of the usb-a socket bent backwards and been shorted to 2. and 3. pin of the 3.0. after removing this short in the port the laptop came alive.
                                          Now the laptop freezing randomly. The webcam, the built in mic and according to the device manager one more thing not working which are connected to usb. If I connect anything what have usb 2.0 plug that wont work if i plug anything what...
                                          08-25-2024, 03:44 PM
