No inputs on my Philips flat HDTV 50PF9631D 50" plasma
  • DarknQuiet
    • Nov 2010
    Last year our plasma had died and Sears came out to repair it. We needed a new power supply. I took the power supply to work and repaired the 2 caps on the board. The tv now powers up great, the only problem is that none of the inputs work at all. They did before the caps were replaced. Could I have plugged in a cord on the wrong place? There was one small connector on the left side of the board that could have plugged into 2 differnt places. Or could a different board gone bad in the process? Thank you for your time and any insight that you could share.
    DQ
  • PlainBill
    • Feb 2009
    • 7034
    Re: No inputs on my Philips flat HDTV 50PF9631D 50" plasma
    DQ
    Here is the link for the service manual. Since you couldn't be bothered to include a picture of the back of the set, you can look the proper cabling up yourself.
    PlainBill
    • bohaboha
      PHILIPS 32pfl3403d Flat-panel TV Upgrade Assistant problem
      by bohaboha
      Hi trying to update my Philips cause in retail mode not possible to get out from it i get this message in update site : Error message: no data exception. Your reference: Request ID (server_1930105)
      how to fix it thanks
      02-05-2025, 09:23 PM
    • valvashon
      32" Philips PAL TV from India- should I get it or leave it for somebody else?
      by valvashon
      I know this isn't troubleshooting related but thought it was the best place to ask. There is a supposedly working 32" Philips flat screen originally from India for free near me on FB Marketplace. It's a PAL receiver but will do NTSC (?) from the HDMI inputs. Will add the model number later. I like quirky stuff but have plenty of TV's/monitors around so I don't really know what to do with it. Should I get it and see if there is a compatible NTSC/ATSC tuner board that could be swapped in?
      Val
      09-12-2025, 11:09 AM
    • Sharpa
      Repair attempt Philips 55OLED804/12
      by Sharpa
      I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
      The symptoms when bought: Philips logo appears then tv turns off
      Things tried so far:
      1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
      2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
      Yesterday, 08:30 AM
    • alro7779
      Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
      by alro7779
      Hello, guys!
      The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
      09-14-2025, 12:25 AM
    • G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo
      by G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
      It does power up when pressing the power button.
      I already try the power button while plugin the plug with no result.
      Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
      Could this be an PSU or eMMC issue ?
      07-19-2025, 03:43 AM
