Vizio vx37lhdtv10a Won't work !
  • mrtony5
    • Nov 2010
    Hello I just bought this TV a couple of years ago and about 2 months ago it just quit. When plugged in the vizio light will glow orange and when the power button is pushed it will change to white for a sec then back to orange and do nothing. I took it to a repair shop and they said the main board is bad and needs replaced. I checked all the caps and didn't see any that looked bad. I've done a lot of reading and can't find a fix. I just don't see how a whole board can go bad. Does any one have any input of what to look at or test. Thank you all very much
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Vizio vx37lhdtv10a Won't work !
    There are a number of things that can go bad on this unit. The usual suspects are the caps, of course, sometimes the inverter board(s).
    The first thing to do in this forum is to post a picture of the set opened up and then get one of each board inside. Use "Manage Attatchments" on the post page for your pics.
    I have attatched the service manual for this TV set.
    • mrtony5
      • Nov 2010
      Okay thank you very much I will post some pictures and model numbers for the boards when i get back from thanksgiving vacation.
      • mblack4d
        • Mar 2013
        I just received this Vizio and was told I could keep it if I fixed it, I found u10 "V out" pin sheared off and not connected to main board, 5V in and V in is connected and soldered but with no out it makes that chip pointless, the manual has helped however just seeking some further advice. Thanks could that cause a problem. I sure it can just wondering if any one else has noticed this problem.
          Did you test all the LDO regulator, please report all the reading in format as shown by retiredcaps.
          Did you also check the resistance reading on the output pin to see if the load is shorted.
          See how to test LDO link under my signature.
          • Dgtech
            E. Technician
            • Apr 2009
            • 1462
            • Steeler
            Just as Budm is suggesting, you got to go through the motions of checking everything. It sounds like a repair gone wrong. These chips go bad but I personally never seen one blow off a lead. Sounds like they were trying to test it and broke it off.
            • cliff_hootarski
              • Jul 2006
              • 411
              Are you sure the output pin is sheared off?
              See:
              https://www.badcaps.net/forum/showth...999#post300999
              Post #7
              Notes: we are looking at the regulator with the Big tab up (the big tab is tied internally to the center pin.
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • bobbyskillz
                Vizio E241i-a1 - works, but OSD stuck and no buttons work
                by bobbyskillz
                Hello, experts! I have a weird issue I've never seen before. I know some of you have definitely seen this. I think some have seen in. I'd greatly appreciate any advice you can give me.
                I bought a E241i-a1 to use as a monitor. It powers on, displays the image, and has sound. I just can't get the OSD to go away. The TV doesn't respond to any input from the remote contol or buttons except for the power button. Is this a firmware issue? I can't access settings to reset it. A quick search for the firmware has no results. I'm lost. Please throw some ideas at me.
                Thanks for...
                07-02-2025, 03:43 PM
              • SS454
                vizio e650i-a2 backlight flashes then turns off
                by SS454
                vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                panel: au optronics T650HVN05.4
                72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                https://www.shopjimmy.com/vizio-56-0...-power-supply/
                Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                08-20-2020, 03:57 PM
              • mrtek
                Vizio M65-C1
                by mrtek
                Hi.
                picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                07-14-2025, 07:28 PM
              • hollox123
                ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                by hollox123
                Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                1. Laptop keyboard doesn't work
                2. The backlight on the laptop keyboard doesn't work
                3. The x2 side LEDs (red) on the laptop don't work
                The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                But I am strongly aiming that it is somehow a BIOS-related problem,...
                05-11-2025, 08:05 AM
