Samsung 5053X now flashing pixels
  • Tobytech
    • Nov 2010
    • 13
    I followed the forums advise on my picture problem. Low and behold it was the video main board. This has resolved 98% of my problems.
    The only thing that remains is that I faintly have multicolored pixels flashing (about 2hz) in the background. I have tried to make voltage adjustments. The pulsing gets better or worse based on the adjustments. Also I can hear a transformer on what I believe the PS board buzz with every pulse. It just seems like I have a voltage out of tolerance that I can't get dialed in "or" yet another problem persists. If Anyone has any advise I would greatly appreciate it. Thank again, Todd.
  • Tobytech
    • Nov 2010
    • 13
    Re: Samsung 5053X now flashing pixels
    Also, the pixel oscillations from the TV seem to be effecting my living room light. Yes the light faintly pulses along with the TV oscillations.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      try sticking a ups or expensive filtering surge protector in between the tv and the wall...see if that makes it go away
      • Tobytech
        • Nov 2010
        • 13
        I guess that is a possibility. I'm going to try plugging into a different circuit as well. I doubt this is the problem being the oscilations on my light fixture only happen when the TV is turned on. I guess its worth a shot. After that I have a feeling I'll be into the power supply board. Thanks! Todd
        • Tvbob
          tvbob
          • 204
          Forget the plug, You have a shield missing or not grounded
          Open grounded cable etc
          • Tobytech
            • Nov 2010
            • 13
            I have checked for defective shields and could not come up with anything. Any adjustment that I make on either the SMPS, Y-Main or power supply main board changes the intensity of the pulse as well as color. "Playing" with the adjustments can just about get rid of the pulse but will not resolve it totally. The transformer on the Power Supply Main board still buzzes "faintly" with every pulse. If there are any more ideas out there please let me know. Personally I'm leaning toward the PS Main board but any additional help is greatly appreciated!!!!! Thank you, Todd
            • learnmore
              Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
              by learnmore
              Hello Community!
              CASE DETAILS
              Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
              13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
              Tried inserting firmware on USB and left it in for a few hours, but no change
              03-03-2024, 09:49 AM
            • STKR123
              Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
              by STKR123
              As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
              I wonder if re-flashing the BIOS might be of any use here.
              As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
              There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
              11-03-2024, 06:58 AM
            • Bad_IC
              Samsung UE40F6320AY dead pixels?
              by Bad_IC
              would someone kindly tell me if the TV panel has dead pixels problem?
              I attached the photo, if you zoom it you can see the several dots...
              Thanks in advance
              Bad_IC...
              01-11-2025, 05:05 AM
              09-07-2024, 05:50 AM
            • Bloopeta
              Samsung UE43KU6400U Flashing Red Standby Light
              by Bloopeta
              Have a Samsung UE43KU6400U that will not turn on, just continuous flashing red standby light.
              Power button does nothing
              Have unplugged the mainboard, and backlights illuminate.
              Have tried removing panel ribbon cables one at a time, and that makes no change.
              With mainboard unplugged, all voltages from powerboard seem ok, but with mainboard connected, they never quite reach full voltage, and drop and raise in a constant loop (in time with click noise from mainboard.
              Using backlight tester, I get 63.6v on both sides, so seems like no bulbs...
              09-11-2023, 02:34 AM
