Samsung UE40F6320AY dead pixels?
  • Bad_IC
    • Aug 2021
    • 23
    • Sardinia
    would someone kindly tell me if the TV panel has dead pixels problem?
    I attached the photo, if you zoom it you can see the several dots...
    Thanks in advance
    Bad_IC
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4540
    • Italy - Milan
    I sent you a private message on plcforum, didn't you noticed it?
    • piposarcade
      Samsung UN50KU6300 dead no standby led
      by piposarcade
      01-04-2024, 01:33 PM
      Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it...
      05-22-2024, 02:07 PM
    • kevin_allein
      Samsung QE 75 Q 7 FGMTZG Power Supply dead
      by kevin_allein
      Hi, have this Samsung QE 75 Q 7 FGMTZG TV with no function. First analysis shows the power supply board is dead and fuse blown. Power Supply has the number BN94-11439A. I did short circuit test transistor and diodes and those do not appear to have shorts. I must admit I did not look at every single data sheet.
      In the TV was some black dust residue, so probably one of the electrolytic caps blew, but they do not show short either.
      Does anyone have schematics for that board ?
      Any good tip, what could be the issue ?
      02-27-2025, 12:15 PM
    • tvguy12012012120
      by tvguy12012012120
      02-07-2025, 05:13 PM
    • Asraf Atb
      by Asraf Atb
      01-27-2025, 05:02 PM
    • jesterace
      Samsung UE49MU6400 acts dead until disconnecting backlights, then works.
      by jesterace
      Hi everyone I have this TV which was dead one day when I tried to turn it on. I've had the cover off and there was just a pulsating/electrical clicking/ticking noise from the PSU. I disconnected the mainboard as sometimes this works to just fire it up with backlights on? That didn't help. Same noise. Then I disconnected the backlight cable from the PSU and the TV came alive. It appeared to respond to the remote and i'm pretty sure it's fully operational when there is no backlight connected.
      However, I am in a dilemma.
      I tested the backlight outputs with the lights disconnected...
      10-20-2024, 10:15 AM
