I need 6870C-0511A Tcon Dump
  • arizanotlari
    • Nov 2014
    • 158
    • Turkiye
    Tv: Lg 65UB980V
    Panel : LC650EQF-FGF1
    Tcon : 6870C-0511A
    Hi.
    i need tcon dump (u450) of 6870c-0511a. The eprom I have is empty. Maybe it should be empty but I wanted to ask you to be sure.
    https://www.badcaps.net
  • arizanotlari
    • Nov 2014
    • 158
    • Turkiye
    Re: I need 6870C-0511A Tcon Dump
    It should have been empty anyway. So the problem is solved.
    • kca
      by kca
      Hello all ~
      08-31-2025, 06:38 AM
    • ziddey
      TCL 55P607 / 55P605 tcon dump
      by ziddey
      Picked up this tv in non-working condition. On plug, the backlight would come on, and the led would flash about 16 times before cycling. So my initial guess was a fault with the mainboard. However, after holding down the reset button and plugging in power, it actually booted and stayed on. Still no display, but backlights good, and could hear roku sounds when pressing physical/remote buttons. No more cycling.
      Next, detached one panel ribbon at a time, and got the respective white half, and banding on the other. Tcon seemed like common / likely culprit and are available cheap. Confirmed...
      07-14-2022, 12:11 AM
    • x_orange90_x
      TCL 50S535 bad tcon or panel issue?
      by x_orange90_x
      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
      03-29-2025, 11:02 PM
    • Ahari
      by Ahari
      I...
      08-13-2025, 06:12 AM
    • advant
      by advant
      02-03-2020, 12:25 AM
