Vestel 17IPS72 R4 BLOWS Q7
  • alltvrepairs
    • Jan 2014
    • 256
    • Malta
    HI
    Need some help here. Led controller mosfet MDD14N25C Q7 bliwing immediately.
    Tried a replacement board and all is fine but would like to repair this.
    Suspecting either transformer shorted or gate drive from Ic. But looking for your opinion if ot is a known fault
  • petehall347
    • Jan 2015
    • 4448
    • United Kingdom
    Re: Vestel 17IPS72 R4 BLOWS Q7
    check associated resistors and be sure you used a genuine replacement mosfet
    • alltvrepairs
      • Jan 2014
      • 256
      • Malta
      Tks. So far cross checked relative components against diagram but haven't identified the culprit yet
      • slybunda
        • Feb 2012
        • 139
        C120 - has that got burn marks on its side?
        • Diah
          • Feb 2013
          • 6563
          just bad quality,.,, replace both Chanel at once and be sure u don't have short cable of BL cable behind the screen
          • alltvrepairs
            • Jan 2014
            • 256
            • Malta
            I guess you are referring to C130 47p 2kv. The brown shade is due to the heat of the underlying Mosfet
            • alltvrepairs
              • Jan 2014
              • 256
              • Malta
              Sorry what both channels? There is only 1 FET switching on BLs. LEDs work fine with a replacement card.
              • Jane
                How do you test MOSFET in laptops ?
                by Jane
                I tried to use this method:
                Testing an N-channel MOSFET:
                Step 1: Discharge the Gate (turn off the MOSFET)
                Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                Step 2: Charge the Gate (turn on the MOSFET)
                Now, place the red probe on the Gate (G) and the black probe on the
                09-27-2024, 03:31 AM
              • Nooy
                VGA MOSfet permanently shorted and loss of MOSfet pad
                by Nooy
                Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                02-14-2024, 02:26 AM
              • redbaron1007
                Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
                by redbaron1007
                I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
                Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
                09-09-2025, 11:10 AM
              • AppleLover123
                Asus X712EA 3 volts after the first mosfet
                by AppleLover123
                Hey guys,
                i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                Now i thought something...
                12-15-2024, 07:49 AM
              • MicroSMD Lab
                ASUS ROG Zephyrus GPU Mosfet repeat failure
                by MicroSMD Lab
                The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                01-10-2024, 06:36 AM
