LG 55UH6030 backlight issue
  • EazyBone
    • Jun 2023
    • 1353
    • United states
    55uh6030 LG no backlights . Edgelit tv
    This TV turns on and shows picture. Everything is fine there so I'd assume it rules out the tcon/main/panel.
    The problem is, they don't turn on. LED tester lights up each side at 165Volts
    The voltage comes up to 335v on each side but they don't light up.
    Anyone experience something like this? I could assume the LEDs are bad but I feel like maybe might have some insight on this.
    Main cap hits 401v steady
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: LG 55UH6030 backlight issue
    Have you measured the bl on pin on the connector
    • EazyBone
      • Jun 2023
      • 1353
      • United states
      Assume you mean the 335v running to them? Each channel has that. Unless you mean something different
      • EazyBone
        • Jun 2023
        • 1353
        • United states
        Anyone got anything to make me think on this? I don't see an issue but PSU aren't turning on LEDs.
        Full picture, so PSU or bl related.
        • Diah
          • Feb 2013
          • 6437
          put yours Dm probe on each group LED+& - then plug it in wall record yours high and low V. same way do it but this time between TV chassis and LED+ of the groups..
          end result compare the reading
          • EazyBone
            • Jun 2023
            • 1353
            • United states
            Thx will report back with that. I thought I did that and it was the same but I'll recheck. Thx
            • EazyBone
              • Jun 2023
              • 1353
              • United states
              Chassis and LED+ turn on TV, stby goes to 181v and pretty steady
              Hit power jumps to 324 within about 2 seconds, climbs up to 335.5 in about 10 seconds and is actually fluctuating between 334.5-336.5. slowly fluctuating but always that range
              Between+ and - LED stby goes to .972v and power goes quickly to 1.7v and about 10 seconds goes to 2.3v and hovers around 2.28v and 2.33v slowly fluctuating.
              • Diah
                • Feb 2013
                • 6437
                BL issue
                • EazyBone
                  • Jun 2023
                  • 1353
                  • United states
                  Sounds good. They were 9$ so I ordered
                  • Diah
                    • Feb 2013
                    • 6437
                    well regards to yours measurements report you have open at LED... it could be too the socket joint down side the screen LOL
                    • EazyBone
                      • Jun 2023
                      • 1353
                      • United states
                      What tells you it's open? Because of the fluctuating voltages?
                      • Diah
                        • Feb 2013
                        • 6437
                        No load.. in this cases we need start from checking the PSU downside of the BL circuit if there one of the SMD R for current limit Open.
                        • EazyBone
                          • Jun 2023
                          • 1353
                          • United states
                          So diah, incorrectly diagnose here. Learning experience for me, changed the LEDs problem still exists. There is a pin on the PSU labeled MS and is getting zero volts. I believe this is a MB sent signal to turn BLs on. I found some random post of a guy jumping MS to turn on BLs with pw on. I disconnected the single pin from MB and jumped it with some, and sure enough BLs came on with picture. All was perfect. So there is some main board issue.
                          Is anyone familiar with this MB BL signal issue? I read briefly this could be an issue in another thread but no mention as to how it was fixed or where to get the information
                          Edit, not sure where my pictures went, maybe this forum reset lost them. I'll post some in a bit
                          • Diah
                            • Feb 2013
                            • 6437
                            we are sitting behind pc screen... all judgments depend on the information and photos the threat owner show us...
                            at post #2 vinceroger69​ asked you the points you talking just now on it.LOL
                            • EazyBone
                              • Jun 2023
                              • 1353
                              • United states
                              at post #2 vinceroger69 asked you the points you talking just now on it.LOL
                              There is no BL on connector, I asked what he meant and has no answer. Think you taking this the wrong way, and not sure where my pics went, here is some more.
                              PSU with MS, shows zero volts. Don't know what MS stands for
                              I am trying to trace the line, not sure if anyone can help but the path I see so far is pic 4. The MS pin starts and I run backwards to that little transitor( or whatever component) and the continuity ends there. The other side of the transitor corresponds to leg 5 (of bottom row) on 100gea chip. Then I can't trace it leaving the chip at all. No beep beep on any leg after this chip.
                              All I got so far, any input appreciated
                              • Diah
                                • Feb 2013
                                • 6437
                                MS are !MICOM Signal" IC3000 are the "MICOM" .on LG MB platform.. same to OLED TVs.. its programmed within Firmware. and it could get defect in way of cut T-CON 12V or BL signal too.. try first with IN_STOP... it may come back to life..
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  Just seen this post im still learning myself bl on is usually the singnal too turn them on hence i mentioned checking the voltage i have never seen a lg marked with ms so no idea until now what that meant the main thing is your narrowing down the fault and for the cost of the backlights it should make the tv last for a good few more years .
                                  • EazyBone
                                    • Jun 2023
                                    • 1353
                                    • United states
                                    The more I learn
                                    So I power on with service remote, tv powers on. Is unresponsive to any remote clicks. The TV shows picture and everything like normal but besides the power button nothing else works. I've tried 3 different remotes and the service menu, also the button on bottom of tv i believe swivels to change volume or channel (maybe) and it does nothing also. But it works as a power button.
                                    Suggestions?
                                    • Diah
                                      • Feb 2013
                                      • 6437
                                      The more I learn
                                      Suggestions?
                                      so did the IN_STOP bring back the micom sending the lost signal to BL?
                                      it sound to me you pressed on service remote Power Only.... this is limited function must pressing exit then turn off so you can back to normal state
                                      • EazyBone
                                        • Jun 2023
                                        • 1353
                                        • United states
                                        No like, only power works on the remote. On any of the remotes, I have unplugged them, replug, tried combinations etc. no other button works except power. Including service remote. I'll give it a try again but odd
                                        • Cornito
                                          Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
                                          by Cornito
                                          Hello Team,
                                          I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
                                          Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
                                          Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
                                          08-08-2024, 08:09 AM
                                        • cheebster
                                          iPad Pro 12.9 5th Gen Backlight Issue
                                          by cheebster
                                          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                          Anyone...
                                          05-20-2025, 09:17 AM
                                        • Cornito
                                          TCL 65C715 backlight issue
                                          by Cornito
                                          Hello team,
                                          I'm back with another topic.
                                          It's a 65C715 TCL tv with backlight issue.
                                          But the problem is a bit strange.
                                          When I took this tv from the marketplace backlight didn't work but picture was ok.
                                          Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
                                          Putting all back together the tv worked fine for weeks. => Contact issue??
                                          Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
                                          06-09-2024, 02:24 AM
                                        • shellybelly
                                          Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
                                          by shellybelly
                                          Back Story
                                          I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
                                          So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
                                          08-27-2023, 10:40 PM
                                        • fuzzyrunner
                                          Samsung LN52B750U1FXZA - Backlight Issue
                                          by fuzzyrunner
                                          Hello All!
                                          So here is the issue I am having. When everything is plugged in as normal, the TV turns on and I get a quick flash of the backlight. After that the backlight never turns back on but the rest of the TV works fine. If I pull the PWM pin from the cable between the main board and power board the backlight turns on and the tv works "normally". If it is plugged in I get nothing. I did do a factory reset but that didn't solve my issue. When everything is plugged in normally I get .6v at start up and continues rise over about 10 seconds. (~.6v then ~.8v then ~1.8v...
                                          02-28-2024, 07:36 PM
