TV Philips 40PFT4101/12 - power on loop
  • betmen
    • May 2019
    • 90
    • Croatia
    TV is Philips 40PFT4101/12, power supply 715G6934-P01-000-002M, motherboard 715G6947-M002-000-004Y (703TQGPL068).
    The problem is that when it is plugged in, the TV turns on by itself, the Philips sign appears, the backlight turns on and off a couple of times, and the TV turns off, and so it repeats itself in a circle. It does not respond to the remote and nothing is written on the screen, the red light does not blink.
    A few weeks ago, it used to turn on by itself about once a week, but after that it worked, now it doesn't work.
    I checked the power supply, voltages are fine, no swollen capacitors.
    I disconnected the T-CON cable and the same thing happens.
    The only thing I noticed is that the double diode D9121 heats up a lot together with the cooler.
    Does anyone have an idea what this is about and what to do?
  • EazyBone
    • Jun 2023
    • 1361
    • United states
    Re: TV Philips 40PFT4101/12 - power on loop
    Backlights flashing on and off could indicate a bad LED. Do you have LED tester?
    How long do backlights turn on? Is it a quick flash and off or stay in a few seconds
    • betmen
      • May 2019
      • 90
      • Croatia
      I don`t think that LED is bad, it is just a quick flash and then it lights up for 15-20 secunds and then TV restarts.
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • reessi
        HP - CE Series - DAG7ALMB8C0 REV.C - MODEL - G7AL-2G - Missing MAINON & SUSON - Turns on power LED & Charges
        by reessi
        I have re-soldered the loose pins on the RAM slot which is a common fault on these models..
        It charges and turns on the power LED but is missing several voltages like RAM and CPU do not come up which I believe is due to MAINON & SUSON being missing to turn these supplies on..
        What I am un-sure of is what is the ITC chip waiting for to send out these signals, what are the requirements?
        I have checked these lines in diode mode and they seam normal -> 600.
        I have checked to see if they come on for even a fraction of a second...
        07-15-2025, 09:14 AM
      • Victor Moreira Silva
        Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
        by Victor Moreira Silva
        I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
        Well, my decice specs are the following:
        Model: Acer Nitro 5 AN517-54-55T5
        CPU: Intel Core i5-11400H
        GPU: NVIDIA GeForce GTX 1650
        Motherboard: GH51G LA-L181P Rev:1c
        The symptom:
        When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
        05-26-2025, 10:49 AM
      • hoarderteks_kyriakos
        Dell Latitude E5570 - No display, turns off after a minute of pressing the power button.
        by hoarderteks_kyriakos
        Hello.
        Yesterday my mother encountered a problem with her laptop, which led to it not turning on and expressing the behaviour mentioned in the title (you press the power button and then it turns off after a minute)
        Here is what happened:
        At one point i was fixing a setting on the laptop to make the laptop properly recognize the NVMe drive i put in months ago. All worked until all of a sudden the computer blue screened. The screen said it would reboot, but it never did. So she held down the power button, powering it off. Pressing it again, the screen briefly turned...
        10-08-2025, 07:33 AM
