TV Philips 40PFT4101/12 - power on loop
  • betmen
    • May 2019
    • 90
    • Croatia
    TV is Philips 40PFT4101/12, power supply 715G6934-P01-000-002M, motherboard 715G6947-M002-000-004Y (703TQGPL068).
    The problem is that when it is plugged in, the TV turns on by itself, the Philips sign appears, the backlight turns on and off a couple of times, and the TV turns off, and so it repeats itself in a circle. It does not respond to the remote and nothing is written on the screen, the red light does not blink.
    A few weeks ago, it used to turn on by itself about once a week, but after that it worked, now it doesn't work.
    I checked the power supply, voltages are fine, no swollen capacitors.
    I disconnected the T-CON cable and the same thing happens.
    The only thing I noticed is that the double diode D9121 heats up a lot together with the cooler.
    Does anyone have an idea what this is about and what to do?
  • EazyBone
    • Jun 2023
    • 1351
    • United states
    Re: TV Philips 40PFT4101/12 - power on loop
    Backlights flashing on and off could indicate a bad LED. Do you have LED tester?
    How long do backlights turn on? Is it a quick flash and off or stay in a few seconds
    • betmen
      • May 2019
      • 90
      • Croatia
      I don`t think that LED is bad, it is just a quick flash and then it lights up for 15-20 secunds and then TV restarts.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • reessi
        HP - CE Series - DAG7ALMB8C0 REV.C - MODEL - G7AL-2G - Missing MAINON & SUSON - Turns on power LED & Charges
        by reessi
        I have re-soldered the loose pins on the RAM slot which is a common fault on these models..
        It charges and turns on the power LED but is missing several voltages like RAM and CPU do not come up which I believe is due to MAINON & SUSON being missing to turn these supplies on..
        What I am un-sure of is what is the ITC chip waiting for to send out these signals, what are the requirements?
        I have checked these lines in diode mode and they seam normal -> 600.
        I have checked to see if they come on for even a fraction of a second...
        07-15-2025, 09:14 AM
      • Victor Moreira Silva
        Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
        by Victor Moreira Silva
        I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
        Well, my decice specs are the following:
        Model: Acer Nitro 5 AN517-54-55T5
        CPU: Intel Core i5-11400H
        GPU: NVIDIA GeForce GTX 1650
        Motherboard: GH51G LA-L181P Rev:1c
        The symptom:
        When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
        05-26-2025, 10:49 AM
        03-31-2024, 02:12 PM
