Panasonic TX-65FX623E identidy IC.
  • tibd
    • Oct 2014
    • 189
    • Sweden
    Re: Panasonic TX-65FX623E identidy IC.
    Problem solved with NOS MC7812C with Caps. Working fine.
    • Diah
      • Feb 2013
      • 6615
      the best you done.. i love DIY in cases there are complex,,, thought via DIY i made TVs and projector from scraps., even old B/W CRT wood box TV work on android HDMI input. LOL
      • tibd
        • Oct 2014
        • 189
        • Sweden
        BTW Diah
        Have you ever came across short in panel of Samsung Q7F QLED. I have one lying since a couple of week, resolved a short on panel board. Yet still there is a short on the qled panel itself at left lower corner where all horizontal lines emerge. It getting very hot at just this point. I was wondering to dig with a dremel here and see what happens. Any ideas?
        • Diah
          • Feb 2013
          • 6615
          BTW Diah
          yes .. at COVID time i got one of this shit sammy TV from friend, there was short at panel gate cells. with infrared camera i can located the area but not exactly point. for fun with my friend i used my Laser machine for engraving i have one at home (Nd:YAG laser) with output wavelength 532nm , i removed the XY galve and used the beam direct after the expander to 100mm laser Lens ( the focused spot of the laser beam will be in nano ... i pulsed the beam at several points to destroy the gate transistors ...result was the short went out... but there are noticeable burn and 4 thin line vertically LOL .. my friends liked the idea and push me to pulse more in hope the lines disappear.. end result fire spot in size 1 euro coin ... but the lines become more ..
          • jm1234
            Reolink RLC-410-5MP - buck convertor
            by jm1234
            it's a PoE camera and it stopped working. Using thermal image I identified failing component U22 marked as 16AF which seems to be buck convertor TI https://www.alldatasheet.net/datashe...62569DBVR.html. I took it out and It is inteed shorted on the output. However, after I took it out, the resistance between the output pads (on the board) still shows 190ohm, is that bit low?
            Another issue is, seems to me I must be missing one of the tiny resistors R810 that should make up the voltage devider for the buck convertor. Honestly I did this months ago, I cannot...
            07-14-2025, 04:30 AM
          • BigPete
            Panasonic Heatpump Dryer Repair
            by BigPete
            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
            Unfortunately the whole machine has to come apart to fix it.
            I have...
            11-01-2025, 06:40 PM
          • Andre Gilbert
            by Andre Gilbert
            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
            11-20-2024, 08:52 PM
          • AquaMan Ua
            by AquaMan Ua
            05-17-2025, 09:40 AM
          • stecos
            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
            by stecos
            Hi everyone!
            For my passion for technology I'm now collecting several...
            11-28-2022, 11:39 AM
