Panasonic TX-65FX623E identidy IC.
  • tibd
    • Oct 2014
    • 189
    • Sweden
    Hello
    I haav a Panasonic TV model TX-65FX623E which dosn't show any picture. The backlight is on.
    Upon testing the T-con i couldn't find the 12v at fuse, the fuse is ok.
    I traced it back to the main bord and the QFN25 buck IC responsible for generating the 12v is in the pic below with marking BUTAPA. No shorts where detected and the IC is not heating. Input of 16v is there, and 3v on another pin which i presume is enable signal.
    Cant find any data or schematics for further troubleshoting.
    Any ideas or if anybody came across this buck converter IC and can share would be much appreciated. The main bord model is TNPH1196.
    Best regards.
  • tibd
    • Oct 2014
    • 189
    • Sweden
    Re: Panasonic TX-65FX623E identidy IC.
    Anoter pic with measured voltages at pins
    • lotas
      • Jan 2016
      • 4457
      • Russia
      IC5260 pinout
      The font and markings are very similar to Silergy.
        • 20279
        Originally posted by lotas
        IC5260 pinout
        It looks like a silergy part to me too,but i can`t find it . Here`s a service manual for the Tx-49fxw584 https://www.manualslib.com/download/...-49fxw584.html IC5260 has panny part number C0DBAYY02857
        • lotas
          • Jan 2016
          • 4457
          • Russia
          This could be a special Panasonic order from Silergy.
            • 20279
            Yes it could be
            • Diah
              • Feb 2013
              • 6341
              the IC are fine... its pin 11 receive I/O from main chips. to switch VCC... there are error come to the main chips or there any other reason with DC/DC or epprom/ emmc
              • lotas
                • Jan 2016
                • 4457
                • Russia
                Yes, in the photo this board looks as if it was damp or had moisture, there is a lot of oxidation on the soldered components and rotten holes on the via tracks.
                • tibd
                  • Oct 2014
                  • 189
                  • Sweden
                  Thanks a lot. A community that never lets you down.
                  I agree with the liquid/ moisture damage. Overall there are tons of signs of liquid damage, corrosion and rust not only on pcbs but also the metal body. Will check pin 11 and poke around, most probably a no-fix, going back to owner or for spare parts
                  • tibd
                    • Oct 2014
                    • 189
                    • Sweden
                    By the way. If I’m getting 3v on pin 11 as I mentioned in first post and post two(pic) then it might be wrong voltage? What to expect here? Any data sheets?
                    • Diah
                      • Feb 2013
                      • 6341
                      I/O are bus signal not only current.. i would try to put DC/DC 12V regulator and DIY the chips with In from 15V and the out to pin 19.... then see what the main chip will proceed Video or audio signal as well the t-con & Panel
                      • tibd
                        • Oct 2014
                        • 189
                        • Sweden
                        Exactly was i was planing to do. Have some tiny DC-DC buck converters with common GND which will suit the purpose.
                        Any ideas what power consumption T-con in such models generally have.
                        • Diah
                          • Feb 2013
                          • 6341
                          t-con fuse A value /2
                          • tibd
                            • Oct 2014
                            • 189
                            • Sweden
                            Hello again.
                            Injecting 12v using dc-dc buck converter with common GND as of the attached pics. The tv shows steady pic. So it narrows the whole defect to the pwm ic first suspected. The question that remains is whether the IC can be bought, any known vendors that ship to Sweden? All answers would be much appreciated.
                            If anyone have a doner board can send a PM.
                            BR and thanks again to everyone for help.
                            • Diah
                              • Feb 2013
                              • 6341
                              don't bother with this IC... unless you measure the bus signal with Oscilloscope. if main chips didn't send this signal you will have same result even new IC.. if i am i will Diy it with Regulator 12V mounted on the chassis with caps 2200uf 25V and shoot 2 birds in one stone..
                              • lotas
                                • Jan 2016
                                • 4457
                                • Russia
                                So maybe this chip is alive, check all the wiring of this chip according to the diagram (resistors (they may be broken), capacitors,..) wash this place with a brush with isopropyl alcohol.
                                • tibd
                                  • Oct 2014
                                  • 189
                                  • Sweden
                                  Shall do. Still though think the problem is the PWM IC itself. Even as a hobbyist i came across this problem several times which resolved by changing the IC but yet you have a good point here. I have no oscilloscop here otherwise i would've mentioned readings here.
                                  • tibd
                                    • Oct 2014
                                    • 189
                                    • Sweden
                                    By the way, how about using a linear voltage regulator, sort of LM7812?
                                    • Diah
                                      • Feb 2013
                                      • 6341
                                      passed with cap on output
                                      • tibd
                                        • Oct 2014
                                        • 189
                                        • Sweden
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • AquaMan Ua
                                          by AquaMan Ua
                                          05-17-2025, 09:40 AM
                                        • stecos
                                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                          by stecos
                                          Hi everyone!
                                          For my passion for technology I'm now collecting several...
                                          11-28-2022, 11:39 AM
                                        • aa10aa10
                                          Panasonic Toughbook CF-33 mk1 BIOS repair
                                          by aa10aa10
                                          Good day,
                                          I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                                          I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                                          01-21-2025, 06:13 AM
                                        • Mnawar27
                                          Panasonic CF-H2AU24EF3 bios locked
                                          by Mnawar27
                                          Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
                                          I need help to remove it,
                                          thankyou all.
                                          SN; 2FKCA26876...
                                          11-16-2024, 08:00 AM
