Samsung UE50NU7020W TV Stuck on Smart TV Logo with No Display
  • ovrax
    • Nov 2023
    • 17
    • Belgium
    Hello everyone!
    I have a Samsung UE50NU7020W TV with an issue.
    When I plug it in and turn it on, it displays the "Samsung Smart TV" logo, the logo disappears, and it doesn't respond, no reaction at all.
    The backlight remains on, but I can't do anything.
    I've tried unplugging the ribbon cables from the T-con board one by one, but the problem remains the same.
    Any ideas? I haven't found a similar issue on the forum.
    Thank you!
    Ovrax
  • Diah
    • Feb 2013
    • 6558
    Re: Samsung UE50NU7020W TV Stuck on Smart TV Logo with No Display
    upload photo of the Tv back side to see all boards how connect together..... NU with T-CON !!! i would love to see its T-CON
    • ovrax
      • Nov 2023
      • 17
      • Belgium
      Indeed, there is no T-CON; I was simply referring to the two ribbons connected to the motherboard
      Here are the photos.
      That's the only board of the tv.
      In the photo, the speakers and wifi board are removed.
      • Diah
        • Feb 2013
        • 6558
        use Go advance and upload urs photo on this forum.
        • ovrax
          • Nov 2023
          • 17
          • Belgium
          Done. Sorry for that
          • Diah
            • Feb 2013
            • 6558
            show please yours screen as you said it show ssmsung smart at start up
            • ovrax
              • Nov 2023
              • 17
              • Belgium
              Here are the screen photos.
              When I plug it in, and one second after.
              In the second photo, the backlight is on. But nothing is displayed. No sound either.
              • Diah
                • Feb 2013
                • 6558
                okay... you need to take out the black heat sink, you will find 8pins chips ( SPI ) this need to freez it then plug the tv in wall... see the result
                will be good if you show us the SPI chip and its lable
                • ovrax
                  • Nov 2023
                  • 17
                  • Belgium
                  Here are the photos without the heat sink.
                  Feel free to ask if you need more photos.
                  Is it really effective with the fridge? How long should I put the board in the fridge, and how long should I wait before trying again?
                  • Diah
                    • Feb 2013
                    • 6558
                    IC 503 , you need cool air spray.. not in fridge LOL
                    Lighter Gas can freez it too,,, but be caution don't burn your house
                    • ovrax
                      • Nov 2023
                      • 17
                      • Belgium
                      Hum, I need to find a cool air spray...
                      You think the problem is this SPI ?
                      • Diah
                        • Feb 2013
                        • 6558
                        we need to freez it first to see any change... if no change then we have issue at the NAND or main CPU BGA issue. however if you cn find boards will be fine too... yours panel are fine.
                        • ovrax
                          • Nov 2023
                          • 17
                          • Belgium
                          Ok thank I will check.
                          Alright, just for your information, a few weeks ago, I tried it, and the TV worked (just one time!), but it was extremely slow. Do you think if I replace the motherboard, the TV will work normally again?
                          Thank you.
                          • Diah
                            • Feb 2013
                            • 6558
                            Thank you.
                            sure will work your panel fine and B too.... nothings ells only left MB
                            BTW did you tried to disconnect the wifi / BT from the boards and turn on ??
                            from yours writing it was slow.. so the BGA issue very high possible under RAM / NAND / CPU.
                            • ovrax
                              • Nov 2023
                              • 17
                              • Belgium
                              Yes, I disconnect the wifi / BT from the board and it is the same thing.
                              I will check about a new motherboard and replace it.
                              Thank for your help !
                              • letmealone
                                Smart Tech LE-4048SA stuck at SMARTTV logo: problem solved.
                                by letmealone
                                I had this tv set, stuck at the 'SMARTTV' screen with coloured logo. Impossible to find the original Smart Tech firmware, so i searched in kazmielec.tech some firmware compatible with the tv-set hardware (CV338H-T42 card and Y400HJ6.PE1 screen). The firmware i tried was wrong and it bricked the TV, just showing a black screen and not entering stand by anymore. I supposed it needed special hardware to reflash the NAND, but i was wrong, it just needed a working compatible firmware. Still in the kazmielek page i tried ' CV338H-T42_1920x1080_Telefunken TF-LED43S81T2' and it finally worked. I wrote...
                                09-16-2024, 10:03 AM
                              • conghuyms
                                MacBook Air A2179 stuck logo , pls help me !
                                by conghuyms
                                Hey everyone,
                                I’ve got a MacBook Air A2179 that got some water damage through the keyboard. Now it powers on, shows the Apple logo, but just stays stuck there — no startup chime, no keyboard backlight, and no progress bar under the Apple logo.
                                When I try to boot into Internet Recovery (Option + Command + R), the mouse cursor is extremely slow and laggy — like when I lift my finger off the trackpad, the cursor keeps drifting slowly for a second or two.
                                I opened it up and found some corrosion around the LED driver IC area on the logic board. I cleaned...
                                11-05-2025, 08:30 AM
                              • Schule04
                                Samsung UE48H6270SSXZG black screen after Smart TV logo
                                by Schule04
                                Power supply is BN44-00709A
                                Mainboard is BN94-07385J
                                Got this TV from Ewaste.
                                Symptoms
                                The power LED comes on when plugged in. After pressing the power button the backlight lights up and stays lit. The Samsung Smart TV logo fades in and out. After that the display stays black and doesn't react to buttons on the TV or remote. TCON board has 3 blue LEDs which are lit. A small part of the backlight seems to flicker when the TV is powered up. TV shuts off after some minutes.
                                Attempted troubleshooting...
                                07-01-2022, 05:56 PM
                              • sbt123
                                ferguson/cello f5820rts4k stuck on smart tv logo
                                by sbt123
                                Hi there ,i have the above tv and it will not get beyond the smart tv logo ,the led in the corner of tv is also flashing red and green constantly,all buttons on remote and side of tv are unresposive.
                                Thank you.
                                04-20-2023, 04:24 AM
                              • x_orange90_x
                                Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                                by x_orange90_x
                                I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                                12-28-2023, 06:26 AM
