TCL 55S451 Blank screen
  • x_orange90_x
    replied
    Originally posted by amxlink
    Any pictures available of the working fix? I have the same TV in the same situation, but am unclear on what part of the ribbon cable for the right side I need to tape to attempt a fix.
    I don't have a picture of what I did. What I suggest is you find the clock signals yourself and then block them with tape. The way I found them was by looking at the main board and finding the labels near the ribbons. When I found CLK1 thru CLK8 (I believe it was) I followed the trace to the ribbon connector. Using a multimeter in continuity, place one probe on the the pin of the connector and run the other probe along the pins of the opposite side of the ribbon (the end that plugs into the strips on the panel) until you hear a beep. When it beeps you've found where that signal comes out on the other end. All you need to find is 1 and 8 then everything in between those are the remaining signals. Start by putting tape over all 8 and see what happens.
    This is assuming your multimeter BEEPS when continuity is found.
  • amxlink
    replied
    Originally posted by x_orange90_x
    Update:
    I revisited the tape method and successfully found the clock signals, blocked them, and the end result looks great! I can't see any anything wrong with the picture!
  • x_orange90_x
    replied
    Originally posted by EazyBone
    You gonna sell a tape TV?
    This one was more or less a proof of concept and personal achievement šŸ˜„
    The ones I DO sell I've either replaced power supply components, boards, or most commonly, backlights. On rare occasion I get one that has nothing wrong with it at all.. And those are the ones I can't guarantee anything AT ALL.
    But as far as used TVs go, they're just the same as used cars. You can put a new transmission in a car and sell it but 6 months later a head gasket goes. I may put a new power supply in a TV but I can't guarantee that the backlights won't fail next week. That's why I will honor my work and my customers for a respectable length of time.. but obviously not forever.
  • EazyBone
    replied
  • x_orange90_x
    replied
    Well at least you got a 4th garage TV šŸ˜‚ šŸ˜‚
    šŸ˜† I have way more than 4 in there! I fix and resell most of them. Just picked up another 55" Samsung 4k last night.. Added to the "needs backlights" pile along with a 55" Element, 50" Toshiba, and 75" Vizio. Funny thing is, I don't even USE a 4k in the house, only 1080p lol can't really tell the difference
    It was just nice to save this one finally because I was probably one more garbage day away from evicting it.
  • EazyBone
    replied
  • x_orange90_x
    replied
    Update:
  • x_orange90_x
    replied
    Throw it in the trash
    After watching the following video I think I might dust this TCL off and give this a try!
    https://youtu.be/bdw8Mub9ReU?si=a2J11CRKriWQSTZP
    If I do this, would I apply 12v to the VCC leg of that IC in order to get a "smoking gun"? About how many amps would be appropriate?
    Lastly, do you think this may work on my case? 😁
  • EazyBone
    replied
  • x_orange90_x
    replied
    Did I lose you guys?
  • x_orange90_x
    replied
    maybe check all the resistors on the right side.
    I previously did a resistance check on all of them and they read correctly. Should I check them another way? I don't understand how blocking the clock signals gives me grey on the right and image on the left, but uncovering just one makes the whole screen black again.
    replied
  • x_orange90_x
    replied
    I checked the left side voltages with the right side ribbon disconnected and get the following:
    DVDD1 = 1.83V HVAA= 6.73V
    VAA= 15.32V
    VCM1= 4.19V
    VSS1= -5.03V
    VSS2= -8.91V
    AVCM= 4.19V
    Notice the left has VSS instead of VGL. So clearly I'm missing voltages on the right. If I check the left side with the right ribbon connected I get almost the exact same readings as the right side, so the right side brings down the left when it's connected.
  • x_orange90_x
    replied
    Originally posted by lotas
    Yes, check it out.
    I noticed my labels are quite different from what would be expected. The only one that sticks out to me is DVDDI. Should be 3.5V and I'm under 2V. What do you think?
  • x_orange90_x
    replied
    Yes, check it out.
    All ribbons attached, no tape, and power on:
    DVDDI = 1.83V
    HVAA = -3.8mV
    VAA = -0.376V
    VCM1 = -0.363V
    SPI_DI = 120.6mV
    SCK = 120.3mV
    SPI_CS = 3.25V
    SPI_DO = 3.27V
    VGL1 = -3.0V and increases toward 0
    VGL2 = -8.93V
    AVCM = -.362V
  • lotas
    replied
    Yes, check it out.
  • x_orange90_x
    replied
    Check also VGH, VGL, 3.3v..., there are many more control points there
    Ok. Do I just check voltage between the test point and ground with it plugged in and turned on?
  • lotas
    replied
  • x_orange90_x
    replied
    If none of the capacitors have low resistance (in Om), then they are fine, show where you masked the contacts.
    Attached is a photo of the lines I blocked off. The 4th line is STV, then CKV 8, 7, 6, 5, 4, 3, 2, 1 in that order from left to right. I checked continuity on them to find that's what they are via the test points over each of their resistors. With the tape in place I rechecked and the first untaped one (STV) still has continuity, so I know I blocked off ONLY the clock lines.
    I also checked all of the caps for short to ground and all are ok.
  • x_orange90_x
    replied
    lotas
    I'm going to reattempt the tape trick tonight and I'll take a photo of it for you. I'm hoping I can find a bad component on the scaler to fix the issue rather than the tape. If I can FIX it the image will be perfect, but the tape trick will likely cause some lines or something.
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • ygorsan
    by ygorsan
    🧩 Problem Summary:
    • I
    07-28-2025, 08:34 AM
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
  • JDC
    (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
    by JDC
    ONN 100012588
    Issue: No Power, Then Rebooting After Main Board Change
    Short answer: replace main board and power board
    Technical answer: replace main board and Q306 & Q307 on power board.
    Long answer:
    TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
    07-15-2022, 07:39 AM
  • mrautom8
    Samsung TV UN75H6350AFXZC main board schematics?
    by mrautom8
    Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
    Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
    While relay is on, all voltage rails are present and steady (scoped) on main board.
    I love a good logic puzzle but getting lost without any schematics.
    No shorts on ANY capacitor main board.
    Thermal camera shows 3.3V inductor getting warm instantly but...
    10-19-2025, 06:32 PM
