Philips 43pft4112/12 blinking standby
  • Raulnn
    • Nov 2022
    • 103
    • España
    good evening. I have this basic tv, with an all-in-one board. This tv has a common fault in the primary power area. the tv did not turn on. I bought a repair kit. I have installed all the parts of the kit, but now the tv turns on the standby light intermittently but does not start. the flashing is very fast. What can be? Does anyone know the model? Thank you
  • Raulnn
    • Nov 2022
    • 103
    • España
    Re: Philips 43pft4112/12 blinking standby
    I attach the schematic of the source, in case someone can guide me. a greeting
    • R_J
      • Jun 2012
      • 9579
      What parts did you change and which parts were bad? How can we guess what kit you bought?
      • Raulnn
        • Nov 2022
        • 103
        • España
        Sorry, I put everything I changed.
        R9101 out
        U9101 I Don't Know
        C9103 out
        D9102 out
        D9104 out
        Q9101 out
        7 smd resistors R9103, R9104, R9106, R9107, R9108, R9109, R9110 something ok
        4 smd C9108, C9109, C9110, C9111 ??? I Don't know
        F9901 ok
        • Raulnn
          • Nov 2022
          • 103
          • España
          good evening! to see if someone can help me. after replacing all these components, the tv already has a standby light, but that light is intermittent and does not respond to the power button. the voltage on the main filter is unstable, between 1xx-3xx. the voltages in the secondary are also unstable. the 22v is 17.8v and a bit unstable and the 12v is very unstable and goes from 0 to 8v. There is a loss of 4v. Could anyone help me? Do you need any measurement?
          • kukeo
            • Jun 2022
            • Poland
            Hi! Did you resolve the issue? I have the same problem: unstable voltages, blinking standby LED.
            • kukeo
              • Jun 2022
              • Poland
              I need to post this, maybe someone will find this helpful. The TV is working now. In my case the R9101 was the problem because of me. I made a mistake ordering 22Ω resistor instead of 0.22Ω.
              • alro7779
                Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                by alro7779
                Hello, guys!
                The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                09-14-2025, 12:25 AM
              • Bad_IC
                Philips TV 37pfl5604h/12 no standby voltage
                by Bad_IC
                I have a problem with this TV, the standby voltage is not present. I have checked the components around the IC fsq510's area and they seem to work, also replaced this IC but the problem persists.
                These are the voltages in some pins of IC fsq510:
                Vcc=18v
                D=320v
                Vstr=154v
                Unfortunately, I couldn't find the schematic
                What else could I check?
                Is it possible to provide standby voltage from an external source to allow the TV to turn on?
                Thank you​...
                11-08-2024, 01:07 PM
              • jasonbay13
                Philips 37HFL5682L/F7 no standby light, incomplete service manual?
                by jasonbay13
                picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
                am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
                12-01-2023, 09:55 PM
              • rju
                Samsung 60" Plasma TV, Blinking Standby LED
                by rju
                A sports bar/restaurant with ~40 Samsung Plasma TVs. This is the 2nd TV that has a blinking standby LED. I'd like to learn how to repair these TVs because I'd guess that over time more and more of them will develop this symptom. My hope is to repair the bad PCB, however if that's not realistic then I'd replace the bad PCB.
                Model PN60F5300AF, Type PN60F5300, Model Code PN60F5300AFXZA
                Upon applying power, the red standby is steady. When I tap the power button, the standby LED immediately blinks twice, then it blinks once ~ every 4 secs. Also, Upon applying power, the...
                07-21-2020, 05:23 AM
              • mecha1166
                QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
                by mecha1166
                I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
                03-28-2024, 08:31 AM
