Samsung HPS-5053X Screen problem
  • Tobytech
    • Nov 2010
    • 13
    Hey all,
    New to the forum and would greatly appreciate some help/advise with my plasma TV problem problem. The TV began to develop multicolored line problems (about 1" thick). About 6 months after the 6th line appeared my laptop computer would no longer interface with tv via audio/video port. The TV was still viewable until the entire screen went to all multicolored pixels. The picture can still be seen in the background (barely). Has anyone ran into or expirenced this problem before? What parts/boards made a repair? Again, any help is greatly appreciated. Thank you all, Todd
  • Tobytech
    • Nov 2010
    • 13
    Re: Samsung HPS-5053X Screen problem
    When the problem first happened the colored lines would, at times, disappear. This makes me believe that it is not the panel, but a component. My wife ran one of those "pixel exciter" programs from her laptop and now the entire screen is a barrage of multicolored pixels. If anyone is able to point me in the right direction please do so. Thank you, Todd
    • truep
      • Aug 2010
      • 373
      bad main board, common problem.
      • Tobytech
        • Nov 2010
        • 13
        Thank you very much for the confident answer. I don't have much expirence in the plasma world, but have a decent background in electronics, in which I work in daily. I would hate to have to throw this TV away over an easily resolveable problem. Thanks again!
        • Tobytech
          • Nov 2010
          • 13
          Here is a youtube link to the problem I am expirencing. It is the same exact model with the same exact problem. Thought this may help in any further assistance. I would hate to purchase an expensive replacement board and end up with the same result. Also the wife yelling at me "just buy a new TV!"
          • Tobytech
            • Nov 2010
            • 13
            http://www.youtube.com/watch?v=lGmf4bjoQc4
            • Wizard
              • Mar 2008
              • 2296
              Correctly diagnosed. Panel itself with buffers, power supply and YSUS and ZSUS are fine.
              This can be either logic board or mainboard.
              Cheers, Wizard
              • Tobytech
                • Nov 2010
                • 13
                Thank you all for your subject matter expertise. It is greatly appreciated. I will post the final solution is once the repair is made. Once again, thank you!!
                • Chrissygizmo
                  by Chrissygizmo
                  02-10-2025, 12:33 AM
                • mmccomputer
                  problem with replacing lcd screen
                  by mmccomputer
                  I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
                  otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
                  If anyone has any information on the subject...
                  12-15-2024, 03:44 PM
                • Chrissygizmo
                  samsung galaxy ao2s very temperamental after screen replaced
                  by Chrissygizmo
                  Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                  Ive eventually managed to get it on and working but it's very temperamental...
                  The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                  05-26-2024, 12:05 AM
                • jimjoe123
                  LCD TV Green/Pink screen problem
                  by jimjoe123
                  I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                  Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                  Then each time...
                  02-23-2020, 01:29 AM
                • kotel studios
                  Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
                  by kotel studios
                  Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
                  In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
                  08-06-2025, 02:07 AM
