  • Tr0ll
    • Oct 2023
    • 6
    • Norge
    Original T-con:
    First replacement T-con:
    I thought it might be t-con and ordered new t-con from china(supposedly tested) and mounted this. This worked totally fine first day. 2nd day i got some horisontal lines(just a few which went on left side but also a small part over to right side of screen but not to the end of screen)
    Was a bit dissapointed picture was not perfect but settled with the thought that those few lines was not an issue. After one more week i was back to square 1 except that this t-con with ribbon cable test gave following result:
    Unplugging One side showed picture fine
    Unplugging other side, distorted picture with typically t-con distortion issue.
    were thinking it might actually be a bad replacement t-con and ordered another one from another seller.
    Second replacement T-con:
    Gives exactly the same issue as the first one, two ribbon cables= no picture
    One ribbon cable= picture on half of the screen.
    A small difference from original t-con though, there was also some minor distortion in picture on the half that was working.
    Am i really unlucky with the t-con replacement cards from china or, is this some strange panel issue anyways? (my logic outruled that as the first card gave perfect pictures on 50% of screen with one ribbon cable unplugged)
    Sorry for this bible of text, but what do you guys think?
    it is so frustrating as it worked "fine" for almost two weeks after first replacement of the T-con.
    Thanks in advance =)
    BR
    (edit i tried to google my brainz out and found some similar issues reported but never found any solution/conclusions)
    • 12307
    • U.S.
    Re: T-con suspect issue. Both ribbon cables no picture. One ribbon cable ok. (58pus85
    Maybe try cleaning the 2 tcon ribbon cable pins with ipa, some use pencil eraser, not too vigorously they can be fragile, inspect and make sure none of the pins are damaged and make sure the lvds cable is clean and secure at the tcon.
      • 12307
      • U.S.
      Have a strange idea, with that first replacement tcon in tv, try the "tape cutoff" method, can look it up in search or on youtube.
        • 12307
        • U.S.
        Example there, he managed to get it down to one line but sometimes you need to cover more, might not be your problem, don't know, it is strange that the replacement worked for a whole day then no good next day: https://www.youtube.com/watch?v=pfrRhw7-ZII
          • 12307
          • U.S.
          Suppose it could be a short from panel taking out the tcons but the original tcon seems to be ok.
          • Tr0ll
            • Oct 2023
            • 6
            • Norge
            So appreciated with your feedback, thanks!
            I tried to run a rubber over all the pins without luck. Did only use my eyes to check and i see poorly so maybe i will try zoom/photo with my phone and post here for you to see?
            But my logic are saying it is no errors with the ribbon cables as they work independently? Maybe LDVS when both signals is passing through? What do you think about my reasoning here? This is the first time i am trying to repair a TV after some Youtube schooling.... so bear with me if I am not following all logic here. I have a multimeter somewhere... but knowledge how to use it... not yet at least...
            Not sure if the tape-off method will work here, as i understand that would probably be an idea if i got picture with both cables but ended up with picture with horisontal lines?
            • Diah
              • Feb 2013
              • 6498
              put back yours original t-con, search for firmware in name upgrade_loader.pkg on usb stick formatted in fat32 mbr mode and do upgrade or downgrade.... the screen will work again hopefully
              • Tr0ll
                • Oct 2023
                • 6
                • Norge
                Thanks for you answer.
                can you explain a bit more or point me to another thread with this info?
                When Tv was operated i checked firmware from settings and there was no available updates.
                • Diah
                  • Feb 2013
                  • 6498
                  yours TV chassis TPM191E Android , if its from 2020 then need only choice firmware from this year.. so downgrade to this ( PM191E _ 101.001.037.004 – Date: 2020/06/15 (Upgrade_Loader )
                  look here to download only upgrade_loader firmware..
                  search google or here i did wrote how to format usb Stick as FAT32 in MBR mode....
                  notice the usb must be in MBR then TV will response to it at startup
                  • Tr0ll
                    • Oct 2023
                    • 6
                    • Norge
                    Thanks a bunch! But can you tell me any more about the back-ground for this? Tv are fully updated, is that the issue? And need to back to software from 2020? How come...?
                    (edit: if this method works, should i stay away from updating again?
                    edit2: Sorry if i am a bit dumbstruck here, just wanting to make sure, really appreciates all suggestions here and i will surely test it)
                    • Diah
                      • Feb 2013
                      • 6498
                      after reading yours first post again... don't do it with your original T-CON... put the replacement one in order the firmware will match version on with replacement one... as you said you have already the last version.... but yours T-CON maybe older... this conflict could be solved with downgrade...
                      however its known issue at Philips Android TVs, Part of main firmware buffer (MFC ) glitch out. tv work fine BL -- ampilight and sound too.. but screen black..
                      • lotas
                        • Jan 2016
                        • 4803
                        • Russia
                        The chassis of this TV is "TPM20.1E LA".
                        • Diah
                          • Feb 2013
                          • 6498
                          (58pus85
                          please look on the trusted page of Philips, and search after the NO he posted 8545
                          between we discussed this before... you link for HW and my for FW
                          • Tr0ll
                            • Oct 2023
                            • 6
                            • Norge
                            Did a new test on the different T-cons now with following result:
                            Replacement card 1 (this was the card that "worked" for almost two weeks)
                            Only Left channel= totally fine picture 50%
                            Only Right channel= Fireworks/colors 50%
                            Both: Fireworks/colors 100%, probably a busted card right?
                            Replacement card 2
                            Only Right channel= Picture on 50%, but also disturbances(few horisontal/vertikal lines and some shading) over all screen(even if left is disconnected) starting to think this is panel issue..
                            Both= no picture
                            Original t-con
                            Only Right channel= Picture on 50%, but disturbances was totally same as with replacement card 2 so i now really thought panel issue, 10 seconds later picture were again crisp and fine, with no issues....
                            Both= No picture.
                            Really back at square 1.
                            Will probably try the FW-method with replacement card 2, thoughts?
                            Again, thanks a bunch for trying to help me, really appreciated.
                            • lotas
                              • Jan 2016
                              • 4803
                              • Russia
                              Replacement card 2
                              Both= no picture
                              Original t-con
                              Both= No picture.
                              If on different T-cons the left side shows well, but the right side is distorted, then the problem is in the panel or in the right panel bar. Take a photo of the right bar.
                              • Diah
                                • Feb 2013
                                • 6498
                                we do make judgment from what written by you.... first One day fine..
                                and then... 2 weeks working fine
                                so all the answers from me and any other will be just guess, from that you did many time trying replacing T-CON.. did you took the ribbon cable ad inspect them under good loop if any of the contact pins got short / broken , move to side !!!!
                                if they are fine... then the side of bad screen.. need to inspect the panel edge buffer boards
                                  • 12307
                                  • U.S.
                                  Shorted/defective panels will but do not ALWAYS present with horizontal lines.
                                    • 12307
                                    • U.S.
                                      • 12307
                                      • U.S.
                                      Replacement card 2
                                      Both= no picture
                                      Original t-con
                                      Both= No picture.
                                      Can you show pictures of these distortions.
                                      • Oliver Neno
                                        • Sep 2024
                                        • 9
                                        • Sweden
                                        Hello.
                                        Im having the same issue with no picture if both is in and if either one is disconnected the other half show picture. Tried the tape fix on a pin that looks darker then the rest on the left lvds cable( looking from front of the tv. Then i get picture but some white lines flickering on the screen. Can this be the pin that is damaged and i only need a new cable? The tv is out of warranty ofc...
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
                                        • CyberPhoenix
                                          Issue with picture quality of Sony bravia TV
                                          by CyberPhoenix
                                          Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                          01-22-2024, 02:08 AM
                                        • iglitare
                                          by iglitare
                                          09-04-2025, 07:13 AM
                                        • scubacamper
                                          Sharp Aquos LC-70C6400U Half Screen Dark
                                          by scubacamper
                                          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                          05-03-2025, 12:19 PM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
