Advice needed-Technika 32-207 works but sticks on channel,won’t change channels ok
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Advice needed- Tv works but then sticks on a channel and won't change channels ok
    you just need to look on ebay and find the exact board that matches what used in your set.
    • rustinjust
      • Jun 2022
      • 49
      • England
      My board is 17pw20, would it be ok to use a board that looks identical but is 17pw20.1 ? I'm guessing that's an updated model in some respect?
      • lotas
        • Jan 2016
        • 4589
        • Russia
        You need exactly the same one that you have and that it comes from the same panel (matrix) as yours.
        • rustinjust
          • Jun 2022
          • 49
          • England
          It looks exactly the same apart from the .1 at the end of the board number. The rest of the board number is the same
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4318
            • Italy - Milan
            Re: Advice needed-Technika 32-207 works but sticks on channel,won't change channels o
            17pw20 is a power board! Update yourself...
            • spleenharvester
              Reverse engineering of 18650 4-channel tester
              by spleenharvester
              Hi friends
              I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
              05-04-2025, 02:43 AM
            • Camarada78
              Carvin PA620 shutting down
              by Camarada78
              I have a Carvin PA620 powered mixer with a weird problem: channel one shuts down the entire speaker output when plugged in. Its not a short because it still outputs sound through the line outs.
              1. voltages are somewhat correct (-42/+42, -26, -17/+17, when it should be +-43, -24, +-18).
              2. Channel 2 if plugged works normally, no issues, any volume.
              3. Channel 1 if plugged very low volume, works normally. if goes a little louder, it shuts down everything (both speaker channels)
              4. line out works normally in any situation, even after shutting down the speakers.
              10-15-2024, 12:07 PM
            • dicky96
              American Audio VLP1500 Distorting on one channel
              by dicky96
              Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
              Protection and Clip LED are off
              There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
              I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
              The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
              07-13-2022, 05:25 AM
            • dicky96
              I need to block a UHF channel but not sure how to do it
              by dicky96
              Hi guys
              I couldn't really find a section on the forum for this question so I guess I will put it here
              I do a lot of work in one of the local apartment hotels (an apart-hotel they call them here)
              Mostly I am maintaining the equipment in the 'TV' room or at the pool bar
              Anyway, I have a problem with the system in the TV room - most of this was a system I 'inherited' off the previous technician who no longer lives on the island
              Basically they have (see pic it probably explains it better) the following system. The UHF cabling is daisy chained...
              01-31-2022, 05:24 AM
            • sima112
              Marantz pm 6005 right channel not worknig
              by sima112
              Hi guys,
              I need a help with my Marantz pm6005. It started to have weaker the right channel a few months ago, than it got back to normal and now it has lost sound completely on the right channel. At the final stage it was loosing the channel for a while and than it returned. After it has disappeared completely I could forced it back by unplugging the source form CD (which I normally use) to phone and back. It would then work for a few minutes and died again. Now it is possible power up and all function works normally (apart the right channel ) on all inputs, except the phone both channel...
              01-30-2023, 12:11 PM
