LG 50pk750-ua bad main
  • x_orange90_x
    • May 2015
    • 702
    I just got this tv yesterday and it exhibit the exact same symptoms as the OP in the following thread:
    https://www.badcaps.net/forum/showthread.php?t=48150
    Power it on and the screen lights up, goes dark after about 2 seconds, and pressing any button lights up the blue led on the tv. The person in the above thread replaced their main board and it fixed the problem. I find that it's way too expensive to buy a replacement on eBay. There are "services" on eBay that claim to repair these boards, but the cost is still quite high.
    My question is, what goes bad on these boards that these "services" are repairing? Bad IC? Poor soldering? If it's something that can be done at home I'd like to give it a shot.
    I don't have any photos yet because I haven't opened it up yet.
  • Diah
    • Feb 2013
    • 6343
    Re: LG 50pk750-ua bad main
    BGA could happened on OLD and new TV too... the threat you linked do the same as in POST #21 and #26
    • x_orange90_x
      • May 2015
      • 702
      Thanks for the reply! Ya I seen those posts about the BGA. I think I'm going to take the board to my brother to try and fix it. He has a soldering station and all that good stuff. He said he can heat it up and reflow it.
        • 12081
        • U.S.
        The lead-free alloy used for BGA solder balls has a melting point of 217ºC and requires a minimum reflow temperature of 235ºC to ensure good wetting. Maximum reflow temperature is in the 245ºC to 260ºC range, depending on complexity and density of the board.
        • x_orange90_x
          • May 2015
          • 702
          I don't know what equipment he has but I know he repairs CRT TVs and monitors, and old video game consoles. He said he can do it.
          If I were to install a small fan on the heatsink (if ample room), would I have it pulling air off or blowing onto the heatsink? I could probably wire it to one of the USB ports right?
            • 12081
            • U.S.
            It's nice if the fan fits inside, some cut a hole the shape of the fan thru the back cover right where the heatsink is and put it there, prolly a 5 volt case fan would work if you want to use a usb port of tv, I think blowing air directly on it is best.
            • Diah
              • Feb 2013
              • 6343
              to the age of this TV and its known fault and the heat it generate 100% its reflowed before at least 1 time.. in this case if didnt work then need Pasta and stencil to reball , only Pasta will work not ball
              • x_orange90_x
                • May 2015
                • 702
                I highly doubt it was ever serviced. I got it from an older couple and they said the HDMI went out first, so they used rabbit ears and then eventually that quit working too. Now it does pretty much nothing besides power on.
                Random side question though, does anyone know if the stand has to be removed to get the back cover off? I hate how some TVs you have to lay flat and remove the stand to get the cover off. My 60" Samsung has an access panel that can be removed to get to all the boards while it stands upright.
                • Diah
                  • Feb 2013
                  • 6343
                  yes you need.. and a punch of screw LOL
                  • x_orange90_x
                    • May 2015
                    • 702
                    I just had my brother do a reflow on the BGA and replace the thermal pad. I'll report back after I've tested.
                    • x_orange90_x
                      • May 2015
                      • 702
                      Put it back together last night and it worked! I have noticed though that the image seems faded, lacking bright whites and dark blacks. Colors look good and the picture quality is great, but the tone/temp is just off. I messed with the settings and nothing completely fixes it. If there is only a single thing being displayed, for example the loading symbol in Mario Kart 8 Deluxe, it's very bright and vibrant. As soon as the rest of the screen is populated, everything gets dimmer and pale.
                      Could this be weak capacitors, or is it just an old tired panel?
                      • x_orange90_x
                        • May 2015
                        • 702
                        I have been reading about LGs having overly aggressive Automatic Brightness Leveling and/or Temporal Peak Luminance. I think that's what's happening with the dimming, but as for the lack of bright whites I still have no idea what that's about.
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          Poor quality reflow perhaps.
                          • Diah
                            • Feb 2013
                            • 6343
                            +1 reflow not 100% succeed..
                            tell yours Brother to add load at the middle on the CPU,
                            • x_orange90_x
                              • May 2015
                              • 702
                              I'm reluctant to agree that it's from the reflow. Have you guys personally seen this happen? It looks something like blue light filter or Warm temp settings, but only over white. Everything else is vivid. And speaking of vivid, I find changing the picture mode from vivid to sport helped a lot.
                              All of these results are on a single HDMI and single source. I haven't had time to test OTA or another device/input. I will try later today to see if it's across all inputs.
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                I've not seen it as I have BGA rework machine with a bottom heater.
                                It reads like a poor job though.
                                  • 12081
                                  • U.S.
                                  Skip the vivid mode, that's what kills backlights early.
                                  • x_orange90_x
                                    • May 2015
                                    • 702
                                    Yeah, on LEDs I always set them to vivid and manually turn backlight down to about 70%. This is a plasma though, so no backlights to worry about.
                                      • 12081
                                      • U.S.
                                      Oh, my bad failed to register the P.
                                      • x_orange90_x
                                        • May 2015
                                        • 702
                                        I played around with it more yesterday. I connected an antenna for OTA tv and adjusted the settings more. It actually looks great now. The only real issue I have with it is the auto dimming. I can't seem to find any info online about a service menu for this tv, so I can't disable the feature. I have turned off the eco setting however. I know on the OLED models they have Temporal Peak Luminance and/or Automatic Brightness Leveling in service menu. Maybe LG locked the options in the plasma models 🤷
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
                                        • JSin21
                                          Compatibility of main boards between different variations of samsung MU6100
                                          by JSin21
                                          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                          I have Samsung Smart TV UA65MU6100WXXY version DA01
                                          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                          11-27-2023, 04:54 AM
