LG 49UB850V not switching on / standby LED off / LD701 blinks 5x
  • Diah
    • Feb 2013
    • 6376
    Re: LG 49UB850V not switching on / standby LED off / LD701 blinks 5x
    Originally posted by Seb932
    Tried to find L2302 to check eMMC V. During search I found L2322 is burned (resistance 440Ohms), which is output for 1.2V
    Is it ok to bride the coil for testing purposes or better replace with some other SMD coil?
    you have one ceramic cap shorted... other wise this filter coil will never burning.. good found
    dont bridge it unless you find the short
    • lotas
      • Jan 2016
      • 4611
      • Russia
      #42
      The choke doesn't just burn out, you have a short somewhere, unsolder the choke and measure the resistance on each side relative to gnd.
      • Seb932
        • Sep 2023
        • 23
        Need to give a correction, the burned choke is input for 1.2V voltage regulation, not output.
        If I short the choke the buzzing noise is gone, but still this fancy PWM signal on output side...
        No short measureable, also the 12V input is stable. Maybe its burned during some of the tests before. Because the buzzing noise i've recognized first during the test in #18
        • Diah
          • Feb 2013
          • 6376
          jumper it and let the game start... other wise buy replacement MB
          • Seb932
            • Sep 2023
            • 23
            Done already. eMMC Voltage is also correct =>3.3V. Still missing 1.0;1.2;1.5V...
            • Diah
              • Feb 2013
              • 6376
              keep it on, and monitor the temp of MB, if u have warm camera will be good.. there should be part will warming out
              • Diah
                • Feb 2013
                • 6376
                by the way do you have 5V USB?
                • Seb932
                  • Sep 2023
                  • 23
                  yes, tested and working => 5V normal/USB are supplied by IC2304
                  • Diah
                    • Feb 2013
                    • 6376
                    good, then you should be able to capture the start log via JTAG.. its maybe the MB in protection mode like OLED one... just with USB mouse and USB stick with media content on it waking it up
                    • Seb932
                      • Sep 2023
                      • 23
                      Ok, will try. Any tutorial how to do this?
                      • Diah
                        • Feb 2013
                        • 6376
                        log capture use TTL adapter 3.3V level and any terminal to capture the log
                        for waking up.. plug USB mouse and another USB stick you put on it root any MPG4 movie , start moving & clicking on mouse left and right while you plug the tv in wall socket
                          • 12208
                          • U.S.
                          #52
                          When you hear an unusual buzz, you need to use a stethoscope or rubber hose or such to try and pinpoint where it's coming from.
                            • 12208
                            • U.S.
                            #53
                            Might have a bad solder joint somewhere, those will also cause a buzz.
                            • Seb932
                              • Sep 2023
                              • 23
                              Thank you very much! I've an 8ch logic analyzer on hand, should be possible read JTAG as well. But need some time...
                              • Seb932
                                • Sep 2023
                                • 23
                                buzz is already gone by replacing/bridging the burned choke, remvove the bridge buzz is coming back
                                  • 12208
                                  • U.S.
                                  #56
                                  Thought as much, that was just for those that might see this and be wondering how to check it, sometimes it's hard to tell exactly where a noise is coming from.
                                  • GORS
                                    • May 2023
                                    • Nederland
                                    #57
                                    What is the final outcome of this thread? I have the same TV with the same problem (at least it looks that way).
                                    So I would like to know the root-cause of this and see if it could help me with mine…..
                                    • Seb932
                                      • Sep 2023
                                      • 23
                                      Short Update - TV is working again. BGA Reflow of IC100 does the trick.
                                      Long Story:
                                      • PWS,Edgelit,T-Con,Panel was working (checked before)
                                      • Previous missing voltages, all voltages are there, but my measurment method wasn't correct. I've partly measured directly on the IC output, which is before the LC part => I've measured the direct output frequency without smothing...🤦
                                      • All voltages on MB are correct, no further ideas beside BGA reflow
                                        • start with IC100
                                        • stipped down plastic parts from MB
                                        • removed the metal cover
                                        • Heatgun from below ~350°C
                                        • Heatgun on top of IC100 max 550°C
                                        • started with preheating to 200°C both sides
                                        • followed with a short period of maximum temerature on top of IC100
                                        • slowly cool down
                                      • put everything together
                                      • Power on => Everything is working 👍
                                      I know, this is not a final solution, without proper reballing the chip will fail again at some point of time. The TV will be used as backup, so no worries. Maybe I will find someone who is able to do reballing.
                                      Thanks for your help!
                                        • 12208
                                        • U.S.
                                        #59
                                        I was correct about needing a reflow, I am also correct by telling you it will last a lot longer if you can get a fan blowing on the IC.
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • brithepi2k
                                          Samsung UE75TU7020k No picture, Standby blinks 2 times
                                          by brithepi2k
                                          My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
                                          04-23-2025, 10:05 AM
                                        • cekanayake
                                          L65X1Q_DHS / BN44-00627A Samsung UN65F6400AF Standby blinks twice five times
                                          by cekanayake
                                          I am a noob with some elementary knowledge trying to fix this TV that I have no history on. Any help or guidance will be much appreciated.
                                          When I first examined it was completely dead. saw that the fuse was blown and the ICM801CS blown. I searched and found that the FSFR1800HSL might be the replacement and got one from ebay and replaced it. But when I pulled the ICM801CS I could see the last 3 letters on the blown up part was XSL. So may be I replaced it with the incorrect part. I fixed the fuse and turned it on and it now gives me a standby light blinking twice five times, then clicks...
                                          04-19-2023, 08:37 AM
                                        • htv239
                                          LG UH8500 Backlight Troubleshooting Help
                                          by htv239
                                          I am currently troubleshooting an LG 60UH8500 TV (2016 TV). Any help or suggestions would be appreciated.
                                          Overall Issue: When TV is turned on, backlights all come on for about 10 seconds, then all go out. There is sound and there is a picture on the display (obviously hard to see without backlights, but it is there).
                                          What I Have Done So Far: 1) Removed the back TV cover to expose the boards (Power Supply, Tcon, and Main), 2) blew out any dust and cleaned all connections, 3) Noticed that the LED backlights are fed from two separate connectors...
                                          10-11-2021, 01:53 PM
