LG OLED55B7V doesn't turn on Help.
  • markolino
    • Mar 2020
    • 108
    • Slovenia
    Re: LG OLED55B7V doesn't turn on Help.
    @Diah ??
    • Diah
      • Feb 2013
      • 6367
      F1 or F20000 if you have 12V on the F from both side... try replace T-CON
      • markolino
        • Mar 2020
        • 108
        • Slovenia
        ho. I changed. TCon board.
        got one used today from damaged screen. The seller claims that it must work because the TV turned on when the screen was broken... it looks like I will have to buy another main motherboard.
        what do you think?
        • Diah
          • Feb 2013
          • 6367
          what do you think?
          this is a lie from this seller
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • seve91
            ACER XV340CK 34" black screen
            by seve91
            I got this monitor with black screen problem.
            I thought the problem was in the motherboard, so I bought 2 smashed monitor same model to disassemble boards and swap them, but same issue remains.
            After some tries I've found out that connecting LVDS cable on-fly after powering on the LCD panel let me see the whole screen for half sec, then goes black again.
            TCON got two output flats, because each flat goes to a tiny board with some COF, each tiny board manages half LCD panel.
            I discover that if I leave connected only right side (right flat of the TCON),...
            07-30-2025, 02:32 PM
          • x_orange90_x
            TCL 50S535 bad tcon or panel issue?
            by x_orange90_x
            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
            03-29-2025, 11:02 PM
          • advant
            by advant
            02-03-2020, 12:25 AM
            Lithonia Lighting versus Light of America Compact Fluorescent product quality
            by sam_sam_sam
            I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
            I also have back when Light of America had these light bulbs available for yard lights
            The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
            While the Lithonia lighting fixture has all most certain bulb failure
            So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
            I have only had this light fixture for not more than a year if it...
            07-02-2023, 03:45 PM
