LG OLED55B7V doesn't turn on Help.
  • markolino
    • Mar 2020
    • 109
    • Slovenia
    Re: LG OLED55B7V doesn't turn on Help.
    @Diah ??
    • Diah
      • Feb 2013
      • 6441
      F1 or F20000 if you have 12V on the F from both side... try replace T-CON
      • markolino
        • Mar 2020
        • 109
        • Slovenia
        ho. I changed. TCon board.
        got one used today from damaged screen. The seller claims that it must work because the TV turned on when the screen was broken... it looks like I will have to buy another main motherboard.
        what do you think?
        • Diah
          • Feb 2013
          • 6441
          what do you think?
          this is a lie from this seller
          • kca
            by kca
            Hello all ~
            08-31-2025, 06:38 AM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • seve91
            ACER XV340CK 34" black screen
            by seve91
            I got this monitor with black screen problem.
            I thought the problem was in the motherboard, so I bought 2 smashed monitor same model to disassemble boards and swap them, but same issue remains.
            After some tries I've found out that connecting LVDS cable on-fly after powering on the LCD panel let me see the whole screen for half sec, then goes black again.
            TCON got two output flats, because each flat goes to a tiny board with some COF, each tiny board manages half LCD panel.
            I discover that if I leave connected only right side (right flat of the TCON),...
            07-30-2025, 02:32 PM
          • x_orange90_x
            TCL 50S535 bad tcon or panel issue?
            by x_orange90_x
            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
            03-29-2025, 11:02 PM
          • advant
            by advant
            02-03-2020, 12:25 AM
