Samsung UE43KU6400U Flashing Red Standby Light
  • Bloopeta
    • Jun 2018
    • 526
    • United Kingdom
    Have a Samsung UE43KU6400U that will not turn on, just continuous flashing red standby light.
    Power button does nothing
    Have unplugged the mainboard, and backlights illuminate.
    Have tried removing panel ribbon cables one at a time, and that makes no change.
    With mainboard unplugged, all voltages from powerboard seem ok, but with mainboard connected, they never quite reach full voltage, and drop and raise in a constant loop (in time with click noise from mainboard.
    Using backlight tester, I get 63.6v on both sides, so seems like no bulbs out
    Is it most likely a powerboard fault? Or mainboard?
    • 12206
    • U.S.
    Re: Samsung UE43KU6400U Flashing Red Standby Light
    Probably mainboard, maybe check voltage regulators on mainboard, youtube is your friend for how to videos if needed.
    • EazyBone
      • Jun 2023
      • 1345
      • United states
      Has similar problems like this, for me was main board also.
      • Bloopeta
        • Jun 2018
        • 526
        • United Kingdom
        I will have a look thankyou
        • Bloopeta
          • Jun 2018
          • 526
          • United Kingdom
          Thankyou
          • Bloopeta
            • Jun 2018
            • 526
            • United Kingdom
            Just an update, it was the mainboard, all working now
            Thankyou to everyone who replied to my post.
              • 12206
              • U.S.
              Glad to hear it.
              • Michael Long
                No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                by Michael Long
                I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                Dead / No Power / No Standby Light results after power company had three
                consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
                After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
                09-13-2022, 06:55 AM
              • ChristianBr01
                LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                by ChristianBr01
                I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                04-23-2025, 01:48 AM
              • Kaar3l
                Samsung QLED QE65Q7FNAT only standby light
                by Kaar3l
                TV: Samsung QLED QE65Q7FNAT
                PSU: BN4400940A
                MB: BN94-12832K
                I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                09-24-2024, 01:35 PM
              • 7ony
                Samsung plasma - flashing standby light
                by 7ony
                The TV is a 2013 Samsung plasma, model # PN60F5300AFXZA.
                Snagged it up in non-working condition a couple years ago. Previous owner said that sometimes he could get it to come on after repeated tries but other than that he couldn't get it to turn on.
                Personally I haven't been able to get it to turn on at all. The standby light comes on solid when plugged in, but pressing the power button results in the standby light flashing once every 4 or so seconds. No "click" noises, no light from the panel at all. Just the flashing standby light.
                No visible...
                08-31-2020, 05:18 PM
              • marcinq
                Samsung UE60KS7000 No Standby Light
                by marcinq
                I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
                I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
                05-26-2025, 11:36 AM
