Samsung UN46C8000XFXZA vertical bars/horizontal lines
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4546
    • Italy - Milan
    Re: Samsung UN46C8000XFXZA vertical bars/horizontal lines
    that code is not enough, you must search for LJ94-03871C
    • nomoresonys
      • 12323
      • U.S.
      It's not very hard, just type here your panel number and the first 6 numbers on the white sticker of your tcon.
      • x_orange90_x
        • May 2015
        • 765
        I messed with it last night and got some interesting results. When I unplug the ribbon for either side, rather than being solid black, the side disconnected is gray with the thin lines still present. The opposite side still displays all original symptoms and picture quality doesn't change. Not positive, but I believe this means it IS the panel that is bad because it's "creating" it's own image when not connected to the tcon.
        Attached are the photos I was asked for.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4546
          • Italy - Milan
          why you posted these photos? i have asked around ICE1 chip..
          i don't know how can you state in your test it displays all same faults, if no image present i don't know how can it displays bad colors and rows... keep present that each pixel incorporates a sort of a capacitor, so if you rapidly disconnect matrix and turn on backlight there can possibly be a persistance in previously displayed picture.. you must test it after hours.. or you disconnect power and panel after a black image displayed..
          • Stanley1843
            Screen Display Vertical Multicolor Lines
            by Stanley1843
            Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
            06-29-2024, 11:54 AM
          • noisykid
            Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
            by noisykid
            5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
            12-30-2024, 07:15 PM
          • x_orange90_x
            Samsung UN46C8000XFXZA Horizontal lines
            by x_orange90_x
            I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
            I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
            07-15-2023, 05:06 AM
          • oxi1158
            Toshiba TV 55L6200U horizontal lines + vertical bands. Any hope?
            by oxi1158
            My TV had been showing for the last year some faint horizontal lines on all of its right side, about one out of each 4 of 5 rows of pixels. Not much of a bother, they were unnoticeable when watching a movie. Then, all of a sudden the horizontal lines became much stronger and crossed the whole screen, effectively making it a pain to watch.
            I watched some youtube video where some guy "fixes" it with some tape on the ribbon cable of the t-con, so I tried that, but to no avail. Actually, after putting the TV back together again things worsened: apart...
            10-09-2020, 08:37 PM
          • Falki
            Colorful LCD Vertical Lines on Samsung ue55es8090
            by Falki
            Hello there, ive recently found an older 55inch Samsung SmartTV.
            Sadly it has vertical lines at the left and one line in the middle-right.
            I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
            I have factory resetted the TV as well but also with no luck.
            I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
            A similar issue has been posted as well but also with no actual response ...
            08-12-2025, 04:19 AM
