Samsung LED TV Model UA49N5000AR (Flipped image)
  • angelos
    replied
    Re: Samsung LED TV Model UA49N5000AR (Flipped image)
    me too, but i learnt nothing.
  • Storyteller12
    replied
    Anyways, glad you got it fixed
  • Storyteller12
    replied
    That’s what the service remote does. He didn’t do anything special. He just had an old remote he supposedly modified to send the correct ir commands.
  • angelos
    replied
    I don't get it, he didn't want to tell you how he fixed it, that is odd.
    Yes, he said that he does not use the Samsung service remote. He has a gray
    Samsung remote. I think this remote is a very old remote. Perhaps a VCR or TV remote. He says that he pushes two buttons simultaneously on it and this takes the tv directly into service menu. He says that he had to do some kind of modification in this remote.
    I don't know but it sounds fishy to me. He says he pressed it once and the tv said "Not available" and the second time it went in without any problems.
    I am not aware of any remote modification on as Samsung remote that does this kind of operation. Perhaps someone in this forum can tell????
    replied
    Originally posted by angelos
    I have ordered one from Aliexpress but it has not come yet. I took the TV to a colleague of mine and he got it sorted. His explanation on how he got the tv sorted was rather sketchy so i left it at that.
  • angelos
    replied
    Originally posted by lotas
    This option worked in older models, but it will not work in new “smart” models; with a clean eeprom it may not even turn on.
    FYI, this is not a Smart model
  • angelos
    replied
    Originally posted by Storyteller12
    I'm assuming the service remote didn't work?
  • lotas
    replied
    Originally posted by Davi.p
    I don't think so.. are you sure? my guess is another, original settings are stored in main memory, both current and default.. if the boot software finds empty eprom it rewrites it.
  • Davi.p
    replied
  • lotas
    replied
    Putting all FF to the settings eprom is not harmful because main sw rewrites it with default stored in main flash ic..
    Yes, but you will lose everything: serial numbers, regions, MAC address....
  • Storyteller12
    replied
    I’m assuming the service remote didn’t work?
  • Davi.p
    replied
  • angelos
    replied
    doesn't the asian versions use like america version something like 1,4,2,power? Or info,1,4,2...
    Try pressing Exit for 15 seconds, this resets the tv, or you can erase the settins eeprom.. maybe hotel mode has get in.. try search service manual
    Hi Davi.p
    I was on leave until now and got to look at my messages. Tell me how do you erase the settings in the eprom and what are the consequences of doing so?
    Regards
    A Anagnostou
  • Davi.p
    replied
  • diif
    replied
    What the hell are you talking about???
    Get lost loser.
    See the warning triangle under everyone's username ?
    Click it and report it as spam.
  • angelos
    replied
    With the tv on you press “info, then factory” it should pull up the service menu
    I will try that later today when I am in front of it. Thanks so far.
  • Storyteller12
    replied
  • angelos
    replied
    I added a picture of the service remote i used that did not work.
  • angelos
    replied
    Try the service remote or if you have an old android phone with ir blaster you can download an app.
    I believe you push (menu, 3speed) to enter service menu. This is a master service menu and differs from the one you were trying to use
    Using the service remote, when i press "Factory" the tv set says "Not Available"
  • Storyteller12
    replied
    Hi Storyteller12,
    Are you saying i push the menu button 3 times in succession quickly? Would this be in standby mode?
    No, it's a button labeled 3speed. I made a mistake as you push
    info then 3speed button
  • Robby-Gr
    TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
    by Robby-Gr
    I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
    However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
    The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
    Additional issues:...
    09-27-2025, 12:02 AM
  • shlomim412
    samsung ua55es6800 - no image
    by shlomim412
    hi
    having problem with samsung ua55es6800
    tv had backlight on, sound working - responds to the remote control but no image.
    check tcon board - had 12v in but no other voltages present.
    when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
    when leaving only left side connected - again no voltages and no image.
    put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
    kept trying to block less pins on the left ribbon cable...
    05-15-2024, 05:00 AM
    LCD LED TV Service Menu Codes
    ALL LCD LED TV SERVICE MENU CODES
    Service Menu Code with Board Name
    China Universal Board / Jumper Board Service Menu Code
    Changhong Ruba Service Menu Code
    Ecostar LED TV Service Menu Code
    Orient LED TV Service Menu Code
    Haier LED TV Service Menu Code
    TCL LED TV Service Menu Code
    Samsung LED TV Service Menu Code
    LG LED TV Service Menu Code
    Videocon LED TV Service Menu Code
    Supra LED TV Service Menu Code
    Toshiba LED TV Service Menu Code
    Symphony LED TV Service Menu Code
    Veste/ LED TV Service Menu Code...
    10-31-2024, 03:58 AM
    HP ZBook 14 G2 Base Model Notebook 14 Specification for Upgrade or Repair
    This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
    09-06-2024, 05:27 AM
    HP ProBook 640 G1 Base Model Notebook 600 Specification for Upgrade or Repair
    This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
