Sony KD-43X8307C bootloop
  • unimatrix93
    • Oct 2021
    • 347
    • Magyarország
    Dear community,
    I came with this Sony set with a bootloop problem. Maybe you can help me out.
    The Sony logo appers, the android OS starts to load, then freezes, then reboots.
    So this TV set is stuck in a bootloop, the first thing comes to my mind is a faulty EMMC, but I couldn't find anyone with a programmed replacement IC or a working motherboard that doesn't cost a fortune.
    I Only have a CH341A sadly, so I can't flash it.
    I made some video of the original symptom, when you plug in the TV.
    And I also made one where I tried a method you mentioned before in the forum. Forcing the TV into green LED mode, hard reset. I also tried force it to read the USB and do a firmware upgrade but I don't think it's even reading it.
    (USB is 16GB 3.0, plugged into a USB 2.0 port)
    Do you think is there anything else I can try besides EMMC swap?
    Maybe reflowing or freezeing it could help?
    Thank you for your time and thanks in advance!
  • William1967
    • Nov 2017
    • 215
    • Netherlands
    Re: Sony KD-43X8307C bootloop
    A CH341A won't work, it has no BGA socket
    There is no other way to programme the EMMC.
    Buying a preprogrammed EMMC is the best option unless you want to buy a better programmer, this could be helpfull for future repairs.
    • unimatrix93
      • Oct 2021
      • 347
      • Magyarország
      Sure, but sadly I cannot find a place where they sell preprogrammed EMMCs for this model.
      Which programmer do you recommend me to buy?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4462
        • Italy - Milan
        if you have whish to.experiment and maybe fail, then i suggest you a special usb dongle found on AliExpress at the ultra cheap price of 15 euro or less, it is designed only to program emmc on board with flying wires, some effort it is needed for things to.work, i have purchased it on june but i had no time to use it, it needs a free software, the names and particulars now i cannot provide you, i'm on vacation...september.. but.remember you.need.also a dump, this is hard to obtain..
        • unimatrix93
          • Oct 2021
          • 347
          • Magyarország
          I will look up this dongle, looks interesting for this money. MAybe worth a try If we can find the dump for the TV.
          Thank you for the advice and enjoy your vacation!
          • William1967
            • Nov 2017
            • 215
            • Netherlands
            Search with Google for KD-43X8307C emmc, first hit is a seller and maybe there are more to find.
            • saghi88
              i need eMMC Dump for Sony KDL-55W805C
              by saghi88
              The TV won't turn on (no power, no LED,). All voltages are present on the motherboard. The CPU is working and is getting warm.
              This is a common issue with this model. If the eMMC is faulty, the TV will either go into a reboot loop or not turn on at all.
              does anyone have the EMMC dump file?
              Model: Sony KDL-55W805C
              Mainboard: 1-980-805-31
              EMMC: SK HYNIX H26M52103FMR
              Display-Panel: T550HVF06.0
              07-04-2025, 02:11 PM
            • mhd bero
              Sony KD-65XD8505 EMMC NEED
              by mhd bero
              Hi.
              I'm searching for an eMMC dump for Sony KD-65XD8505
              Motherboard: 1-980-832-11
              THE TV NO BOOTING HE HAVE 8 TIME RED LED BLINKING I THINK EMMC DUMP FILE IS DAMAGE.
              Thank you.
              09-09-2025, 09:31 AM
            • 5m44p1x
              Looking for Sony KD-55X750F EMMC dump
              by 5m44p1x
              The TV falls into boot loop several minutes or hours after power on, I'm thinking it's the EMMC issue, and want to have a try from there. Is there anyone who got this one and willing to share it with me? Million thanks!
              Model: Sony KD-55X750F
              Mainboard: 1-982-454-11
              EMMC: SK HYNIX H26M52208FPR
              08-01-2025, 12:26 AM
            • Morosan Dimitrie
              Sony KDL 55W-955B Sony EMMC dump search :)
              by Morosan Dimitrie
              Hello guys, can someone help me with an eMMC dump for a Sony KDL55W-955B TV, I tried to read the original memory with the RT809H but it shows me that it only has 1888MB even though it should have around 3.8GB. On a new memory it shows me 3776MB. From what I found on the Sony page, the following models could also be compatible:
              KDL-65W955B, KDL-55W955B, KDL-60W855B, KDL-50W805B, KDL-42W705B, KDL-32W705B, KDL-48W605B, KDL-40W605B, KDL-60W605B, KDL-55W805B, KDL-42W805B, KDL-48W585B, KDL-32W706B, KDL-42W706B, KDL-42W815B, KDL-42W817B, KDL-50W815B, KDL-55W815B, KDL-42W828B, KDL-42W829B,...
              06-08-2024, 04:13 PM
            • Lanparty
              Emmc RT809H and Sony kd55x8505c SK Hynix H26M52103FMR
              by Lanparty
              Hello guys
              One million dollars question.
              The problem is I have this tv with almost dead Emmc if I hold Vol - and Power button for about 40 sec. it goes in Recovery mod but does not want to boot from USB . I read the Emmc H26M52103FMR 16Gb and shows that User date is damaged corrupted. I have bought the same Emmc I copied all Boo1 Boot 2 and CSD_EXT file 512 kb from oem old emmc and the user date 14.6Gb from another dump but same model TV. Reballing reading and writing went without any problems but when I soldered back on PCB the TV does not go even in Recovery mod totally dead.I...
              04-22-2021, 08:56 AM
