LGOLED55B7V Clicking and dead screen.
  • Donny2derby
    • Apr 2023
    • 228
    • Uk
    Re: LGOLED55B7V Clicking and dead screen.
    Ok thanks Davi I will try that.
    I did say that I don’t have any power at all on the P202 board which has all the 12VT and 24VD terminals on it.
    And limited voltages on P201. But I will do as you ask and report back.
    The board is disconnected and removed from the TV just now so I’m working on it as a bench job. I didn’t appear to have standby voltage on it when it was in situ.
    Also the fact I’m not getting any voltage from certain inductors or capacitors on the primary side makes me think the issue is way before getting to the connectors for the tcon and video boards.
    • Donny2derby
      • Apr 2023
      • 228
      • Uk
      With a bench power supply set to 3v and negative connected to ground positive to DRV on, I get nothing. I only get a voltage drop when I connect my 3v to ground also. So there’s clearly a short on the circuit before my P201 connector which is for the main board I believe.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4516
        • Italy - Milan
        i wonder why you tell different results in these tests, previously you had 8v at 12vm pins...
        • Donny2derby
          • Apr 2023
          • 228
          • Uk
          Ahh ok Davi I understand now.
          I thought you wanted me to check what voltages I had on DRV ON etc not all pins.
          Will test again later on and post findings.
          • Donny2derby
            • Apr 2023
            • 228
            • Uk
            Ok so to be clear Davi.
            You want me to put 3vDc on 12VT on, DRV on and PWR on and test what voltages I have on all the other P202 pins to ground?
            I’m at work in a couple of hours so will make the test as I believe you ask me to.
            Do you want me to carry the test out with 240v mains plugged in or not?
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4516
              • Italy - Milan
              #26
              Answer to the second post, test both connectors, you wanna test entirely the ps board so obviously the mains in, right... remember, to minimize risks as you are not so expert, some control pins like pwr-on needs a small current so it's safer to get a small battery, or place a 2,2k or more ohm resistor in series to the bench supply.. it's an oled tv..
              • Donny2derby
                • Apr 2023
                • 228
                • Uk
                #27
                Ok Davi.
                Connector P202. With 3.3vDC on DRV ON. There is 7.87vDC stable voltage on all 12VT pins. But completely dead on all 24VD pins.
                With the 3.3vDC on 12VT on there is no voltage present at all.
                With 3.3V on PWR ON. Also no voltage present at all.
                Connector P201.
                3.3V on DRV ON. 7.9V stable on all 12VM pins. Nothing elsewhere.
                3.3V on PWR ON. There was an audible switching coming from the board immediately. On 20VS there is unstable voltage between 18v and 21v
                On 12VM pins. Unstable voltage between 11&13v.
                With 3.3v on 12VT ON.
                Stable 7.7v on 12VS pins. Nothing on 20VM pins.
                The audible switching when 3.3v was applied to PWR ON was totally new!
                And there are voltages present now where I wasn’t getting them before applying the 3.3v as you asked so thanks very much for your input!
                Is there hope yet haha?
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4516
                  • Italy - Milan
                  #28
                  Bad test... i told you to make the three jumpers at same time...
                  12VS what it is? The unstable voltage is probably a bad contact on your jumpers..
                  don't hope much, a fault in ps board is much more suitable than one on screen, wait for the celebrations
                  • Donny2derby
                    • Apr 2023
                    • 228
                    • Uk
                    #29
                    Ok so I need 3.3vDC on PWR ON, DRV ON & 12VT on at the same time!!?
                    Yet you don’t sound so confident I’m going to get a success at all!
                    12VS is 7.7v stable.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4516
                      • Italy - Milan
                      #30
                      Yes at the question. 12VS doesn't exists if i'm right..
                      • Donny2derby
                        • Apr 2023
                        • 228
                        • Uk
                        #31
                        Yes Davi you are correct there is no 12VS
                        • Donny2derby
                          • Apr 2023
                          • 228
                          • Uk
                          #32
                          Davi something amazing has happened!
                          With those 3 pins linked and 3.3v applied all voltages on both connectors are present and stable!
                          This is exciting! What next?��
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4516
                            • Italy - Milan
                            #33
                            Next i will try to make you do a screen test, remove the ribbons from main board to tcon bd, then with the 3 jumpers in place turn on current and watch if a video test starts, if you can film it... or photograph..
                            • Donny2derby
                              • Apr 2023
                              • 228
                              • Uk
                              #34
                              Ok Davi that’s great thanks.
                              I’m at work tonight so will try that tomorrow morning when I get up.
                              If this works and the TV is fixed we will get married and have babies together haha!
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4516
                                • Italy - Milan
                                #35
                                Bleahhh!!!!
                                • Donny2derby
                                  • Apr 2023
                                  • 228
                                  • Uk
                                  #36
                                  Does the fact that the voltages are all correct with the jumpers in place prove the power board is ok then Davi?
                                  The fault could be coming back from the tcon?
                                  And can you tell me what I should be observing during the screen test.
                                  I’ll look on YouTube to see if I can find an example as well.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4516
                                    • Italy - Milan
                                    #37
                                    1) is ok
                                    2) i don't understand, back to what??
                                    3) usually are screen filled with 1 colour and cycling colours.. you must check uniformity, don't be so doubtful, do it and see
                                    • Donny2derby
                                      • Apr 2023
                                      • 228
                                      • Uk
                                      #38
                                      Ok Davi the screen test has not performed well.
                                      There is no change of image on screen. It remains black. There is an audible sound of a relay and 3 blinks of a the standby LED (approx 1 second intervals) then the relay switches again and no further change of state on screen.
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4516
                                        • Italy - Milan
                                        #39
                                        Sorry my mistake, you have to leave alone the main board if not the three jumper doesn't take effect, so detach it..
                                        • Donny2derby
                                          • Apr 2023
                                          • 228
                                          • Uk
                                          #40
                                          Ok Davi now I just have the power board plugged in and nothing has taken effect.
                                          There is no ribbon cable to main board or tcon only the 3 jumpers in place.
                                          Now I get nothing at all.
                                          But I wouldn’t expect to surely? With no ribbon cables to either main board or tcon there can’t be an expectation to get an image on screen because there’s no 12 or 24v going to either board.
                                          Have we got our wires crossed in translation here Davi?
                                          Yes Davi my mistake. The ribbon cables from main board to tcon remove. The jumper cables from power board to tcon remain in yes!!??
                                          Ok edit number 3. The same result. No change in state of the screen. An audible relay switching. The remote control knows it’s being used as the red power button illuminates when I press it but no LED standby light comes on and there’s nothing to observe on the screen at all.
                                          • Rav_tangle
                                            MacBook Pro 2011 turns on with keyboard light , screen dead
                                            by Rav_tangle
                                            Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
                                            I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
                                            Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
                                            is this...
                                            05-31-2024, 04:09 PM
                                          • NeilMcG
                                            Hp Elitebook - Dead Screen
                                            by NeilMcG
                                            Hello all,
                                            First time posting, so please be gentle 😂
                                            HP Elitebook 850 G2 Win 10 with Intel HD Graphics 5500.
                                            Screen dead, but booting.
                                            I connected it to an external monitor via both VGA & Display Port outputs and external monitor works fine, nothing with F4 or detecting another screen in settings.
                                            Got a replacement panel, still dead & still displayed to external screen as before.
                                            Removed CMOS & left it. CMOS reconnected, all as before, no panel, external monitor works.
                                            Got replacement cable...
                                            12-06-2024, 03:23 AM
                                          • reformatt
                                            by reformatt
                                            07-31-2025, 08:37 PM
                                          • smic717394
                                            by smic717394
                                            07-25-2024, 10:16 AM
                                          • Chrissygizmo
                                            by Chrissygizmo
                                            02-10-2025, 12:33 AM
