Vizio M70-C3 LED Strip Repair
  • bscottjohnston
    • Aug 2023
    • 52
    Well, I'm kinda on a roll having fun fixing LED TVs. I have a question for those who have wandered into the arena of fixing your own LED strips. I bought a "cooker" on Amazon whereby it heats the strip so you can extract the LEDs. I successfully rebuilt the 10 of 16 that were bad. BUT - when I put the TV back together at certain times (white screen is really noticeable), I see what I would call a halo effect coming from some of the LEDs. The soldering station discolored the strip where I was working immediately.
    Have any of you encountered this and if so what caused it? I am thinking its either the discoloration OR I might not have glued the plastic lenses back onto the LED quite right. Could it be a slightly defective LED? I bought the Amazon specials for replacements (6V LED kit of 100)
  • Gjackson
    • Aug 2021
    • 134
    • Malta
    Re: Vizio M70-C3 LED Strip Repair
    Do the Halo's correspond to the positions of the dead LEDs? I'd expect some visual artifacts with 6 led's dead. A picture of the TV on a white screen might help.
      • 12235
      • U.S.
      Yep, usually means you didn't get the lens back on in the correct orientation, you only have the one spot right?
      • bscottjohnston
        • Aug 2023
        • 52
        It's a total of 6 bad spots. I think I could take the entire TV apart again, look at the orientation of the LED lenses that I didn't touch and try to get the 6 bad ones oriented correctly. I think I can use some white out on the strips where the soldering station left some discoloration while I am in there.
        Four of the spots are the "halos" - the other two are simply bright spots. Maybe I will simply "live" with those...
        Thanks for the advice on the orientation of what I would call "lenses". Is there a more technical term for those?
          • 12235
          • U.S.
          Nope, it's called a lens, it's for distributing the light evenly. You are correct, if they are not put on right you will get the halo effect, not advised to use super glue because a lot of the superglue has a chemical that will cloud the lens and mess up the light distribution.
          • bscottjohnston
            • Aug 2023
            • 52
            ugh - exactly what I used...
            • Pipolups
              Corsair K70 LUX RGB dying LEDs
              by Pipolups
              Hi there !
              I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
              Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
              10-08-2024, 11:58 AM
            • edugimeno
              Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
              by edugimeno
              Hi There!
              I'm trying to help my friend who owns a restaurant be just bought.
              He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
              It's stuck using, I guess, the 2 sided tape that comes with the strip
              The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
              09-05-2024, 09:34 AM
            • mrtek
              Vizio M65-C1
              by mrtek
              Hi.
              picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
              When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
              This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
              07-14-2025, 07:28 PM
            • DXseekerMO
              Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
              by DXseekerMO
              Hello everyone!
              Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
              I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
              Yes
              0%
              1
              All backlight strips are the same quality
              0%
              1
              No
              0%
              0
              12-16-2021, 03:58 PM
            • benareeno
              Adjustable dc power supply and tcl led strip
              by benareeno
              I wonder if i shorted the whole strip...where to put pos and neg to just light up a single diode...or the entire strip. The strip lit for a second...so maybe i fried it? What say you?
              I have an adjustable dc power supply and was trying around 9 volts.
              I have a pic of a single diode...where to put pos and neg terminals to light it up?
              Pic of middle of strip..is this where i light the entire strip?
              And pic of end...or does this light the entire strip?
              Where to put pos and neg for single diode..multiple diodes and the entire...
              07-11-2021, 02:31 PM
