Bench Test Samsung BN44-00621C Power Supply Board
  • Nicktronic
    • Mar 2023
    • 247
    Hey!
    I've got this power supply board that's had some components replaced and I'd like to confirm all the voltages before I install it.
    This is what I have when I plug in the board on the bench;
    1 - N.C. - 0 VDC
    2 - PWM_DIM4 - 0 VDC
    3 - N.C. - 0 VDC
    4 - PWM_DIM3 - 0 VDC
    5 - GND - 0 VDC
    6 - PWM_DIM2 - 0 VDC
    7 - B13V - 0 VDC
    8 - PWM_DIM1 - 0 VDC
    9 - B13V - 0 VDC
    10 - ECO_ON/OFF - 0 VDC
    11 - Vamp - 0 VDC
    12 - BLU_ON/OFF - 0VDC
    13 - Vamp - 0 VDC
    14 - GND - 0 VDC
    15 - GND - 0 VDC
    16 - GND - 0 VDC
    17 - B5V - 0 VDC
    18 - A5V - 5.3 VDC
    19 - B5V - 0VDC
    20 - PS_ON/OFF - 3.3 VDC
    Since there is voltage on the PS_ON/OFF, I assumed a High to Low enable and shorted the 3.3 to GND. Heard a relay click, but no other voltages appeared on any of the pins above. Is there something I'm missing?
  • R_J
    • 9583
    Re: Bench Test Samsung BN44-00621C Power Supply Board
    What are the components that were replaced? You seem to only have standby voltage, check the voltage across one of the main filter caps, (CP803) The voltage should be 165vdc in standby and around 385vdc when ON if the pfc circuit is working.
    I suspect the main switching section is not working, check that CP814 is not burnt (likely covered in silicone) also check that solder connections on both transformers TM801CS and TM802CS
    • Nicktronic
      • Mar 2023
      • 247
      I bought this repair kit because the TV was not turning on sometimes. Sometimes it would turn on but turn off after an hour or two. Also, could hear relays clicking on/off, but the TV wouldn't turn on.
      https://www.shopjimmy.com/samsung-bn...nt-repair-kit/
      The items in the repair kit are:
      ICM801S
      QP801C
      QP802C
      CS854
      RS807
      ICS801CS
      CM868
      CS851
      CM850
      CM853
      ICP801S
      DS804
      DS807
      DS808
      DS810
      DS812
      I tried what you said R_J, in Standby, filter caps read 389VDC. When I short the PS_ON 3.3VDC to GND, a relay clicks and the voltage on the filter caps slowly discharge to OVDC. CP814 is NOT burnt. Solder joints on the TXFMRs look good.
      • R_J
        • 9583
        The board will be turned ON normally, when you ground PS_ON you are turning the board OFF, 389vdc on the main filter indicates the pfc circuit is working. So with the PS_ON high, check if you have B5v and B13V
        If you are still having problems I would likely change CS806, CP820 & CS804, and maybe CS851, they are in the standby circuit and can dry up over time. Other caps I might change in the primary circuit are the four small electrolytics around and including CM807.
        • Nicktronic
          • Mar 2023
          • 247
          Thanks R_J. With PS_ON high, the results are what I indicated in Post #1, so I guess I will go with the caps replacement.
          • Nicktronic
            • Mar 2023
            • 247
            Ordered the caps from Digikey. Be a few days, but I'll let ya know how it goes...
            • R_J
              • 9583
              Have you tried the board back in the tv? Here is a similar schematic (BN44-00622B), not exact but might help, If the power supply board worked before but was intermittent It should be the same now, so check your work to make sure there are no bad connections or shorted pins on an ic etc.
              • Nicktronic
                • Mar 2023
                • 247
                Yeah, it did work (intermittently) before. I did check my work, but will look again.
                • Nicktronic
                  • Mar 2023
                  • 247
                  So my work looks good. I didn't explicitly mention this, but in Standby (5VDC and 3.3VDC available), the VDC across the filter caps is 168VDC.
                  The FET driver ICs (ICM801S and ICP801S, i think?) don't have anything on Vcc to GND, any thoughts on where/how those voltages are generated? One of those generates the switching voltage for the two main TXFMRs right?
                  Apologies if I'm mixing things up, I'm trying to understand and explain at the same time!
                  • R_J
                    • 9583
                    IN post #3 you had 389v on the main cap, now it is 168v, When the voltage is 389v the PFC circuit is/was working, when the voltage is 168v the PFC is NOT working.
                    VCC for ICM801S and ICP801S comes from the standby transformer and is controlled by a transistor, In the schematic of the 622B (and on your board), DS802 is the supply diode, QS801 is the regulator/switch which supplies the VCC_AUX (17vdc) to those ic's and is controlled via PCS802S optocoupler. (PS_ON/OFF) controls QS861 which turns the optocoupler on/off
                    QS861 also energizes RL801S which supplies A/C to the main bridge BD801S
                    Remember that voltages on the primary side are reference to HOT ground, not COLD (chassis) ground
                    A correction to my post #2:
                    On this power supply RL801S controls the main supply voltage so in standby the main cap will have near 0 volts, not 165v
                    • Nicktronic
                      • Mar 2023
                      • 247
                      Ok, I'm going to try to explain what I know now.
                      First, ICP801CS got shorted (accidentally somehow) and was bad. I replaced it now have ~390VDC, so PFC is working.
                      Second, my board does not have the same ICM801CS chip as the schematic in Post #7. My board has an Fairchild FAN7621. This chip provides gate drive signals to a highside and lowside MOSFET (FDPF18N50T x 2). The HO gate drive signal (Pin 3) measured 14.2VDC on pin 3. The signal on the LO line (Pin 14) looks like a drive signal I think (See pic). The Drain of the lowside FET is connected directly to the source of the highside FET and also connected to TXFMR TM802CS. I've got ~390VDC at the Drain of the highside FET and GND at the source of the low side FET......
                      .....I'm thinking one of those FETs are bad? Gonna pull them and take some ohm readings..
                      • Nicktronic
                        • Mar 2023
                        • 247
                        Forgot the attachments for post #11..
                        • Nicktronic
                          • Mar 2023
                          • 247
                          FETs tested good. The NEW ICM801CS chip that I installed from the repair kit was bad, FML. I put the original back in and the board works fine now. I think what ultimately was causing my problem were the caps R_J said to replace in Post #4.
                          Thanks alot!!
                          • R_J
                            • 9583
                            Good to here it's working, hope that solved the intermittent problem
                            • Nicktronic
                              • Mar 2023
                              • 247
                              It did! Working beautifully now, thanks for your help.
                                09-07-2024, 05:50 AM
                              • cheeky2
                                Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                                by cheeky2
                                This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                                I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                                Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                                06-15-2025, 05:12 AM
                              • rabsonnjala
                                LENOVO IDEAPAD 100 works only on bench power supply
                                by rabsonnjala
                                Hie I have a Lenovo laptop
                                Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                                it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                                below are my readings
                                with the original charger only
                                JBATT1
                                PIN1 0.22V
                                PIN2 0.22V
                                PIN3 0.45V
                                PIN4 0.45V
                                PIN5 O.43V
                                PIN6 0V
                                PIN7 GND
                                PIN8...
                                11-20-2021, 08:32 AM
                              • Eniaro
                                Bench test a series X
                                by Eniaro
                                How do you bench test a series X? I was planning to find a defective PSU to use its connector, but before I go about doing this, I was wondering if there's any bench PSU to the series X connector adapter available
                                06-17-2025, 01:46 PM
