le40b530w colour problem and double letters
+ More Options
Posts
  • Xristakis795
    • Mar 2021
    • 162
    • Greece
    hi to all on the above model i have solarized picture and double letters
    it uses tcon board FHD60C4LV1.1
    i think as about as the double letters maby the problem is the same display
    but as about as the colours it likes as solarized picture
    i look to find the schematic for the above tcon card without success
    has anybody measure the voltages from the above tcon card to advice me how can i measure the gamma voltages ?
    thanks on advance
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    Re: le40b530w colour problem and double letters
    see what is getting hot and then freeze it and see what happens
    • Xristakis795
      • Mar 2021
      • 162
      • Greece
      its happen from the start
      when i turn on the tv
      • jason123
        Hisense 65R6E3 double-image / horizontal strips - TCON?
        by jason123
        Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
        07-19-2025, 08:07 AM
      • THXFX
        samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
        by THXFX
        Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
        I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
        When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
        What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
        I check capacitors and diodes and didn't find any short IN MAINBOARD.
        Measured all power supply...
        03-20-2024, 03:21 AM
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
      • x_orange90_x
        TCL 50S535 bad tcon or panel issue?
        by x_orange90_x
        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
        03-29-2025, 11:02 PM
      • advant
        by advant
        02-03-2020, 12:25 AM
