Samsung UN46D6050TFXZA turns itself off 30 seconds after start
  • MarkH8729
    • Jun 2023
    • 6
    The TV turns on fine. TV started turning off on its own about 30 seconds after I power it on a couple of days ago. Ran just fine about 5 hours before this started happening but had been off for those hours. Problem started the first time after that. I have turned it on from the remote and from the front panel and see no difference in behavior.
    I have been able to turn it on multiple times and change channels and volume. The picture is good. The set just doesn't want to stay on.
    Based on info I found online, I have tried a soft reset (unplugged the TV for as much as 5 minutes, tried this more than once), changed the power cord from a surge protector to the wall outlet directly, and, although I had never configured them or used them since I bought the TV (since 2011), I made sure eco solution, sleep time and anynet+ were all turned off, all without any change. I had to make those menu changes in multiple startups because of the limited on-time. The TV always cuts out at about 30 seconds after the power button has been pushed. And the remote works fine to operate a TV I borrowed while repairing this one.
    Wanted to do a factory reset, but that option does not appear in my menus as suggested online.
    I don't believe the firmware has ever been upgraded and now the TV won't stay on long enough to even attempt it.
    Was able to find the service manual here: https://www.jabse.com/L1NhbXN1bmcvTE...Q2RDYwMDAucmFy
    and a Fast Track Troubleshooting Manual here: https://archive.org/details/Samsung_...t_track_guide/
    but neither explicitly address my issue, so I need some direction to get my TV working again. So, I believe I have good info available but as a novice it doesn't help me much. I don't see my issue addressed, but maybe someone can point it out to me. Never worked on a TV before but have had success with other appliances.
    I have a Klein Tools MM1000 multi-meter but only have experience using it to check continuity in various scenarios such as repairing a lamp and also checking the voltage of a car battery. I also have a Weller SP23 23-Watt soldering iron, if that helps. Any and all guidance greatly appreciated.
    Thanks, Mark
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    Re: Samsung UN46D6050TFXZA turns itself off 30 seconds after start
    Does it still have standby when it turns off? test all voltages coming out of the power supply while the TV is on and after it "shuts off".
    • lotas
      • Jan 2016
      • 4753
      • Russia
      The problem with this chassis and motherboard BN41-01587 (reboots every 30 sec.) is a problem with eMMC.
      • MarkH8729
        • Jun 2023
        • 6
        Yes, the red standby light illuminates when the set "shuts off."
        Is it okay to take the back cover off and leave the TV on the stand? Seems like that is what I would want to do to also be able to see the screen for testing purposes, such as the power supply, as you suggest. Just getting started on disassembly now...
        • MarkH8729
          • Jun 2023
          • 6
          Okay, I'm really green when it comes to this. I took the stand and back cover off to reveal these images. I've attached some images as my first next step: back, main, ip board, & tcon(?). As the power cord attaches to the ip board, is that where the voltage readings want to come from? I don't know which component is more or less significant that the next...
          • Biruslapio
            • Nov 2013
            • 552
            • Brasil
            Since they said shut down, I assume it did not reboot.
            If it is turning on and off in loop, it is as lotas said.
            • MarkH8729
              • Jun 2023
              • 6
              No, it definitely turns off and that is it. It does not try to reboot/restart on its own.
              • Biruslapio
                • Nov 2013
                • 552
                • Brasil
                It may still be the memory corrupted, try starting the tv in service menu by press on the controller remote:
                Mute + 1 + 8 + 2 + power on
                Then doing a factory reset there, it should take 10 seconds at most.
                This command has worked for all Samsungs I've tested.
                • MarkH8729
                  • Jun 2023
                  • 6
                  Okay, I've now started in Factory Mode multiple times. Finally, got the Option menu to load and selected Factory Reset. When I get to the Factory Reset button/page, nothing seems to happen when I select it or use the arrow keys on the remote. What more do I push to activate the reset process? OR How do I know that it has started/been run?
                  With the splash screen, it takes about 10 seconds to get the Factory Menu up. And maybe another 10 seconds to get through the Option Menu to the Factory Reset page. Then nothing happens and shut down after 10 more seconds.
                  Today I am getting better at navigating these menus which I don't recall being able to move through when I originally tried, and which led me to find these forums for help.
                  I've also attached an image of the SVC Menu which includes three items marked as "Failure". Not sure of their significance. I have always gotten my TV signal from a rooftop antenna. Also have a DVD player connected via the included AV Adapter and have watched various MP4s downloaded to a USB drive then attached to the TV.
                  • zklgfs
                    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                    by zklgfs
                    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                    08-11-2025, 02:14 PM
                    09-07-2024, 05:50 AM
                  • twonk9098
                    Lenovo Legion 5 high fan spin turns off after 34 seconds
                    by twonk9098
                    I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                    I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                    I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                    I have tried a few new bios but exactly...
                    07-14-2024, 11:19 AM
                  • EvansEssence
                    Samsung UN55D6003SFXZA TV turns off after 20-30 seconds
                    by EvansEssence
                    Hey guys! I saved an older Samsung tv from the recycle bin to tinker with as a hobby. Looking for some help as to what else to check/replace.
                    The issues it had at first was it would randomly reset its picture settings, this slowly devolved into it rebooting itself and the control board becoming unresponsive. Now it has finally gotten to the point where it no longer turns itself on when plugged in, but when I turn it on with the remote or power button it will boot to a blank input work for 15-20 seconds then turn itself off. I found if I pull up the menu it will actually freeze my...
                    02-04-2023, 08:49 AM
                  • eigma
                    Samsung UN40H5003 boot loop every ~8 seconds
                    by eigma
                    Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                    Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                    SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                    Main board: BN94-07592P / BN97-08922R...
                    11-20-2024, 10:31 PM
