samsung ue55mu6192u dead signal LED
  • giova96
    • May 2023
    • 38
    • italia
    Greetings
    sorry for my English
    i have this samsung ue55mu6192u
    standby light missing, I disassembled and checked the boards, the power board seems to work with the backlight turning on and the presence of 12.8v
    reconnecting the main I notice that the 12.8v drop to 8.8v, but I don't notice any components on the main that heat up, everything is cold
    I also noticed that I have a vacuum on the power board connector
    on/off 4.5v
    pwmblue 3.1v
    poweron 4.5v
    ana dim 3.2v
    and when i connect them to main they all go down to 0
    I've read that this series has eeprom problems and shows the same symptoms (I don't know if there is a voltage drop in that case too)
    could it be an eeprom problem?
    where can i find the firmware?
    BN41-02568
    IC1604 Winbond 25q40clsip
  • lotas
    • Jan 2016
    • 4859
    • Russia
    Re: samsung ue55mu6192u dead signal LED
    Post your dump here, I'll fix it if it's a problem.
    • giova96
      • May 2023
      • 38
      • italia
      this is what i managed to recover
      It's the first time I've done these things, I'm not very practical
      Thank you
      • lotas
        • Jan 2016
        • 4859
        • Russia
        Try, do not forget to install and write down the Status Register (0x88, 0x42) after recording.
        • giova96
          • May 2023
          • 38
          • italia
          Status Register?
          In what sense? I did not understand
          I don't have much practice
          • kevvort
            • May 2023
            • 10
            • Italy
            Hi Giova, which program have you used for taking the dump?
            If you're using asprogrammer see the screenshot in attachment.
            Press the button on the side of the lock, show registers and then set the checkboxes for having 88 and 42 in the status registers.
            p.s: sono ita anche io, ciao!
            • giova96
              • May 2023
              • 38
              • italia
              program CH341A and an economic programmer
              p.s ciao
              • kevvort
                • May 2023
                • 10
                • Italy
                See my edited message above
                Basically you should find a form whre you can edit status register 1 and 2.
                If you can't find it in your program maybe you can try using "asprogrammer"
                • lotas
                  • Jan 2016
                  • 4859
                  • Russia
                  Try
                  • giova96
                    • May 2023
                    • 38
                    • italia
                    done (maybe )
                    i will go to try now
                    • kevvort
                      • May 2023
                      • 10
                      • Italy
                      Originally posted by giova96
                      done (maybe )
                      Looks fine and good luck!
                      Just a question based on your screenshot: why do you have W25Q80 instead of W25Q40 in your device type?
                      • giova96
                        • May 2023
                        • 38
                        • italia
                        in original device it is W25Q40 but i did not find it available
                        on the market I found the W25Q80
                        shouldn't change anything right?
                        • lotas
                          • Jan 2016
                          • 4859
                          • Russia
                          And why change it to 25Q80, write it down in your native 25Q40.
                          • giova96
                            • May 2023
                            • 38
                            • italia
                            because i thought it was broken initially, so i bought it new
                            I will try to write the original
                            • lotas
                              • Jan 2016
                              • 4859
                              • Russia
                              So you read the dump from it (from your native 25Q40), which you posted in the 3rd post?
                              • giova96
                                • May 2023
                                • 38
                                • italia
                                yes
                                • lotas
                                  • Jan 2016
                                  • 4859
                                  • Russia
                                  yes
                                  Ok.
                                  • giova96
                                    • May 2023
                                    • 38
                                    • italia
                                    Ok.
                                    it does not work
                                    when the TV is unplugged for a long time I see a red flash and then turn off immediately
                                    I noticed that on the IC I don't have the 3.3v
                                    the 5v yes
                                    before knowing this forum I had made another attempt but I got the wrong firmware, I had found the 50" on the net and I had missed that my 55"
                                    with that newly installed firmware I had the red LED, but the TV didn't start and after a few attempts the LED didn't light up anymore
                                    I probably broke something with the old firmware?
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4538
                                      • Italy - Milan
                                      when reprogramming memories one must always make a backup of old fw, now if you have that you must provide it to Lotas
                                      • lotas
                                        • Jan 2016
                                        • 4859
                                        • Russia
                                        You erased your old firmware and wrote a firmware from "50" diagonal to it, it didn't work for you and you already made a backup with another firmware from "50", before manipulating firmware, you always need to make backups of old dumps. On this chassis, the diagonal does not play a role, the main thing here is that the SPI and eMMC software versions match.
                                          09-07-2024, 05:50 AM
                                        • glutton4punishment
                                          Samsung monitor Installed 1 cap wrong, now menu button dead, "no signal detected" msg
                                          by glutton4punishment
                                          Samsung synchmaster 226BW.
                                          Before I replaced 5 caps, the screen was dim.
                                          Sometimes it wouldn't turn on.
                                          I opened it up, and found 4 bad caps in the pwr supply section.
                                          I unfortunately installee one backwards, i.e. wrong polarity.
                                          When I turned it on, I head a loud pop, and I quickly shut it off.
                                          The replaced caps are 3 860uF 25V's, and 1 330u 35V.
                                          One of the 860uF blew.
                                          I didn't have another 860uF at home, so I tried it with a 1000uF 35V cap (I remember the reading of the 1k uF cap was close...
                                          03-18-2023, 12:49 PM
                                        • Ellos
                                          Samsung s21 sim recognized but no signal
                                          by Ellos
                                          I'm just starting out with smartphone repairs and picked up a Samsung S21 to work on. Everything functions perfectly except there's absolutely no cellular signal. The SIM card is recognized, WiFi works fine, but zero network signal.
                                          I've tested my SIM in another phone and it works perfectly with good signal, so it's definitely the phone.
                                          From what I've read online, this issue is usually caused by the network chip needing to be desoldered and reballed since one of the solder balls might be cracked.
                                          I think I've located the SOC that...
                                          06-27-2025, 01:31 AM
                                        • Jacksoft
                                          Samsung 225MW EEPROM bootloop
                                          by Jacksoft
                                          I got an old Samsung 225MW TV with BN41-00825 motherboard.
                                          Since the TV has a buzzer when it starts it makes a beep. The main problem is that the TV goes in a sort of bootloop and beeps every 2-3 seconds.
                                          So I attached the VGA UART cable and read the debug data using a RT809H programmer:
                                          According to the Service Manual all the voltages looks good, so I made a backup of the internal flash and all the EEPROMs (1 Settings + 3 EDID) and cleaned the EEPROM.
                                          Now the TV boots but it's stuck on VGA. If I try to change the source it goes to TV, restarts...
                                          02-14-2025, 04:18 PM
                                          09-06-2024, 11:40 PM
